Try AnyMiro to mirror a Xiaomi Phone to a PC for free via USB and WiFi.
This guide provides four simple methods for screen mirroring Xiaomi phone to a PC or TV. You’ll find detailed steps on how to use tools like AnyMiro, Vysor, and ApowerMirror for your computer and Miracast for your TV. We recommend using AnyMiro, a reliable screen mirroring tool, for a smooth experience.
Mirroring your Xiaomi phone to a computer or TV allows you to see images, watch films, and even play games on a larger screen. This post will walk you through four simple ways to mirror your Xiaomi screen. We provide solutions for connecting to a PC using AnyMiro, Vysor, or ApowerMirror and for connecting straight to a TV via Miracast. Every technique is straightforward and includes detailed instructions that are easy to follow. Take pleasure in effortlessly screen mirroring Xiaomi phone to bigger screens.
Now, let’s explore the top 3 tools to screen mirror Xiaomi to PC:
AnyMiro is a strong screen mirroring tool that easily mirrors your Xiaomi phone to a PC. It delivers uninterrupted and highly stable mirroring functionality so users can game or stream for up to 10 hours straight. Featuring up to 4K mirroring, colors will not fade, and the visuals will be presented in high definition. AnyMiro also guarantees audio-video synchronization to help users live stream on Twitch, YouTube, and Facebook.
It’s easy to capture every live stream highlight with built-in screenshots and screen recording features. The ability to live annotate during screen mirroring adds an interactive layer, making it ideal for educators, content creators, and gamers. Whether you’re presenting, gaming, or creating art, AnyMiro ensures your phone’s content is shared smoothly and clearly.
Mirror iPhone to Computer
Key Features:
Here are the steps to use AnyMiro to screen mirror your Xiaomi phone to a PC:
Step 1. Begin the process by downloading and installing AnyMiro on your computer. Once the installation is complete, launch the AnyMiro app on your computer.
Step 2. Next, choose the “Android” option to connect your device.
Mirror Android to Computer
Step 3. Select “WiFi” to connect your Android device to WiFi.
Mirror Android to Computer via WiFi
Step 4. On your Android device, go to Google Play and search for “AnyMiro” to download the app.
Step 5. Open AnyMiro on Xiaomi and tap “Wi-Fi Connection.” Finally, choose the name of the computer you want to mirror to.
Tap WiFi Connection
Vysor is a straightforward screen mirroring tool for Xiaomi phones, making it easier to mirror your phone’s screen onto your desktop. Using Vysor, you can use your computer to play games, open apps, and manage your phone—whether you use iOS or Android.
Thanks to features like keyboard integration, you can use your desktop keyboard to type on your phone swiftly. The point-and-click feature lets you navigate with your mouse, making it simple to scroll or select items. The Vysor Share option lets you broadcast your phone’s screen to any other device. High-quality mirroring and wireless control make Vysor one of the most suitable options for controlling Xiaomi from a PC.
Key Features:
Check out the steps to use Vysor to screen mirror your Xiaomi phone.
Step 1. Download and install Vysor on your PC.
Download Vysor
Step 2. On your Xiaomi phone, enable “USB Debugging” from the developer options.
Step 3. Open the Vysor app on your PC and click “Find Device.”
Step 4. Once your phone is detected, select your PC name from the list. Your Xiaomi phone screen will now appear on your PC.
Select the Connect Button in Vysor
For Xiaomi owners who want to cast their phones to a PC, ApowerMirror is a great tool. With the help of ApowerMirror, users may mirror their devices in real-time with audio to a PC, making it a formidable tool for screen mirroring. In addition, it allows annotations during lectures or presentations, screen recording, and screenshotting. The program also enables remote control, so you can use your computer to operate your Android smartphone. For this reason, it is perfect for organizing content, doing multiple tasks, and creating engaging content.
Key Features:
To use this tool for screen mirroring:
Step 1. Download, install and launch ApowerMirror on your PC. Choose “Android” from the home screen.
Select Android
Step 2. Install and launch ApowerMirror on android device. Enable “USB Debugging” from developer options.
Step 3. On your phone, you’ll see a prompt saying, “Always allow this computer”. Check the box and press OK.
Tap OK
Step 4. Tap “Start Now” to begin the mirroring process.
Select Start Now
Do you want to screen mirror your Xiaomi phone to TV? Miracast is a wireless display standard that mirrors media content from your Xiaomi smartphone to a connected TV. Games, movies, and pictures can be played, watched, or transferred wirelessly from the Xiaomi phone to the TV or any other device without any leads.
Miracast provides high-quality audio and video streaming, which guarantees a smooth flow and an easy-to-follow procedure for setting up the connection. It can be used in different configurations because it supports most smart TVs and devices. Miracast transforms your viewing experience without much effort for screenings, movies, presentations, games, etc. Now, let’s explore the process of using Miracast:
Step 1. First, ensure your Xiaomi Mi 11 and your TV have the same Wi-Fi connection. This is essential for successful mirroring.
Step 2. For your TV, switch the input to “Wireless Screen Mirroring.”
Step 3. On your Xiaomi phone, go to “Settings,” then select “Connection & sharing,” and tap on “Cast.” Turn on the Cast feature.
Tap Cast
Step 5. Your phone will search for available devices. Tap on your TV’s name to start the mirroring process.
How can I improve the mirroring quality?
To enhance mirroring quality, ensure a strong Wi-Fi signal, use high-quality cables for wired connections, and close unnecessary apps on your device to reduce lag.
What tool can I use for better screen mirroring?
We recommend using AnyMiro for a smoother, high-quality screen mirroring experience. It offers reliable connectivity and seamless streaming.
How do I know if my TV supports screen mirroring?
Most modern TVs support screen mirroring. To confirm compatibility, check your TV’s manual or settings for “Wireless Display” or “Screen Mirroring” options.
To sum it up, you get a better experience with games, videos, or presentations when you screen mirror your Xiaomi device on a PC or TV. Some of the methods include Miracast, ApowerMirror, and Vysor because they enable one to easily set a connection between these devices. All of them have an individual setting, and one can adjust it according to the requirements, so sharing materials between the platforms is comfortable. For better performance and a user-friendly interface, we recommend using AnyMiro. It offers the best screen mirroring features along with its user-friendly interface.
