Screen mirroring iPhone/Android to the computer with AnyMiro.
Available for both Win & Mac
If you’re looking for ways for phone to laptop screen mirroring, you’re in luck. In this article, we will tell you everything you need to know about screen mirroring between smartphones and laptops and different methods to do so.
Phone to laptop screen mirroring is a helpful feature that lets you mirror your phone’s screen onto your laptop or computer. It’s all about making your life easier and more enjoyable!
Depending on your devices, you can connect your phone to your laptop using a USB cable or wirelessly through Wi-Fi or Bluetooth. Once connected, you can enjoy a larger viewing experience on your laptop screen.
Also Read: How-to Mirror Phone to Chromebook >
Connecting your phone to a laptop can be done in two ways: wired and wireless connections. Let us break it down for you:
To connect your phone to your laptop using a wired connection:
A wireless connection between a phone and a laptop offers more freedom. You can connect both devices wirelessly in two ways: Using Wi-Fi or via Bluetooth.
Wi-Fi
Bluetooth
It’s as simple as that!
However, sometimes due to compatibility issues, phone-to-laptop screen mirroring can be really frustrating. We’ve got you covered here! In the following section, we have put together 2 different ways to connect Android phones to a laptop for a smooth screen mirroring experience.
The first recommended phone to laptop screen mirroring method is via third-party apps like iMobie AnyMiro. In addition to mirroring iPhone screen to PC, AnyMiro also offers an exceptional solution for Android users looking to mirror their device’s screen to a PC. Let’s explore the features and benefits of AnyMiro as a third-party app for iPhone and Android screen mirroring.
Download AnyMiro now and check the steps of how to mirror Android to PC.
*With this method you need to download both the AnyMiro software and the mobile app.
Step 1. Download to get the AnyMiro desktop version, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro tells you how.
Mirror Android to Computer via USB
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your PC.
Select the Connection Method
Free download AnyMiro and check the steps of how to screen mirror iPhone to computer easily.
Step 1. Open AnyMiro and choose the “iOS/iPadOS” model.
Mirror iPhone to Computer
Step 2. Click USB and connect your iPhone to your computer with a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 3. Click the “Trust” button on your iPhone to continue the connection.
Trust Your Computer on iPhone
In addition to mirroring iPhone screen to PC via USB, you can also screen mirror the iPhone to a PC with Wi-Fi:
If you want to screen mirror your Android device to your laptop, you can do it using the built-in screen mirroring feature in Android or a third-party app. All Android smartphones come with a built-in screen mirroring feature that enables you to cast your phone screen to a laptop. For this method, you need to turn on Bluetooth on both devices.
Now follow these steps to enable phone to laptop screen mirroring:
Bluetooth Pairing Code
Click Projecting to This
Click OK to Confirm
Once you have confirmed the connection on both devices, your phone screen will be cast on your laptop.
While this is the best method for phone to laptop screen mirroring, many people might find it challenging to follow through with the steps. In that case, here’s an easy way out…
However, if you’re an iPhone user, the process of phone to laptop screen mirroring might differ a bit. An iPhone has different connectivity and compatibility features, compared to Android. Therefore, if you want to screen mirror your iPhone to your laptop, here is a way for it:
iPhones have a built-in feature for screen mirroring known as AirPlay. It is a technology developed by Apple that allows you to wireless display your iPhone to other compatible devices without additional software.
Steps to Screen Mirror iPhone to Mac Via AirPlay
Here’s how it works:
Tap on Screen Mirroring
And that’s all you need to cast your iPhone’s screen to your Mac!
However, if you want to screen mirror your iPhone to a Windows PC, you can always use a reliable third-party app for it.
While phone to laptop screen mirroring is quite a convenient feature, it comes with its share of issues. In the following section, we have discussed some common screen mirroring issues and how to resolve them.
If you have ever screen-mirrored your phone to your laptop, you must be aware that some common issues come with the process. For instance:
However, if you want a seamless and reliable screen mirroring experience without the headache of these common pitfalls, we suggest giving AnyMiro a try. It is a fantastic software designed to overcome connection problems, lag, display quality, and audio syncing issues.
1. Benefits of Phone to Laptop Screen Mirroring
The benefits of phone to laptop screen mirroring are incredible:
2. How to mirror Samsung phone to laptop?
To mirror your Samsung screen to a PC, you can use Smart View on a Samsung phone. Or you can use AnyMiro, a powerful tool that offers stable connections and high-resolution streaming. With AnyMiro, you can not only screen mirror Samsung phones but also mirror Huawei, Xiaomi, Vivo, OPPO, and Motorola phones easily.
There are several ways to cast your phone to your PC; however, common issues like connection problems, lagging, poor display quality, and video/audio syncing can arise.
However, with AnyMiro’s reliable and seamless screen mirroring experience, you can overcome these challenges and enjoy a smoother journey. So why not give AnyMiro a try? Experience its convenience and quality, and take your phone to laptop screen mirroring to the next level.
