How to Play PUBG Mobile on PC [5 Ways]
Try AnyMiro to mirror mobile phones to PC & Mac for free via USB and WiFi.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Home Screen Mirror How to Play PUBG Mobile on PC [5 Ways]
This tutorial shows you how to play PUBG Mobile on PC with or without an Android emulator. It also offers simple installation instructions and compares well-known emulators. We suggest using AnyMiro – a dependable screen mirroring tool – for the greatest experience without emulators for fluid-like gameplay on a larger screen.
Joy Taylor | Last Updated: Oct. 17, 2024
1702 words|5minute
Do you want to use your PC to play PUBG Mobile? For an immersive experience, many players want bigger screens and better controls. This article will walk you through switching from your phone to PC, whether you’re new to PUBG or not. We’ll look at two approaches: playing without an Android emulator and with one. These simple methods for how to play PUBG Mobile on PC allow you to choose the one that best meets your needs. Let’s get started!
Play PUBG Mobile on PC Using an Android Emulator
One of the easiest methods to play PUBG Mobile on your PC is through an emulator. Let’s find out how!
What is an Android Emulator?
Android emulators help you run/operate Android games and applications on your PC. They imitate a mobile device’s workings by having an Android-like operating system on the PC. Due to their larger screens for better visuals, smoother performance compared to mobile devices, and superior keyboard and mouse controls, emulators are quite popular among gamers. To enhance your gaming experience, you can tweak key mapping, FPS, and graphics using the configurable settings offered by certain emulators.
Here are some best Android Emulators for PUBG Mobile:
BlueStacks
Bluestacks Overview
Bluestacks Overview
One of the best Android emulators for PUBG Mobile on PC is BlueStacks, which has many features to improve your gaming experience. It offers the best performance and smoother gameplay by supporting settings unique to each game. For example, press the F1 to enable shooting mode, choose macros, and even customize their speed by assigning a number.
You can enjoy the gameplay at 240 frames per second and get a lag-free experience. It has smart controls, automation functions, and multitasking capabilities, and it’s geared for high-end gaming. BlueStacks is a dependable choice for gamers as it guarantees responsive gameplay even with modest system requirements.
Key Features:
NoxPlayer
Noxplayer Interface
NoxPlayer Interface
NoxPlayer is one of the best Android emulators, and it has the ultimate features like multi-touch support and ARM processing. NoxPlayer supports Microsoft Windows XP to Windows 10 and is compatible with different versions of Android, such as Android 6 and above.
It has configurable audio and keyboard options to set the controls conveniently. Moreover, NoxPlayer provides the best gaming experience with high FPS, allowing you to easily play famous games like Mobile Legends and State of Survival. You can play multiple games simultaneously using multi-instance, script recording, multi-drive for gacha games, and more.
Key Features:
Ko Player
Ko Player
Ko Player
Ko Player is an effective Android emulator designed to deliver a high-quality gaming experience on your Windows PC or Mac. Focused on providing a lag-free environment, it excels at running popular games like Call of Duty and Subway Surfers.
Ko Player supports device-free operation, allowing you to access all Android features without needing a separate device. With its Google Play integration, you can easily download any desired app. The emulator also includes video recording capabilities for capturing and sharing gameplay with friends.
Key Features:
Memu
Memu Interface
Memu Interface
Memu stands out as one of the most convenient Android emulators for PCs. Its easy installation and compatibility with Intel and AMD chips make it a solid choice. Memu supports multi-touch, ARM, and battery status features, ensuring a smooth mobile gaming experience.
It works on Windows XP SP3, 7, 8, and 10, allowing players to enjoy popular titles like Garena Free Fire and PUBG MOBILE. With an Android 7 or higher requirement, Memu also needs a system that meets its minimum specifications for optimal performance.
Key Features:
Comparison of Pros and Cons
Pros Cons
BlueStacks – Supports Android 11 for the latest features
– High FPS gaming (up to 240)
– Excellent multitasking capability
– Customizable controls and automation features
– Can lag on low-end PCs
– Ads present but can be disabled
NoxPlayer – Highly customizable with open keyboard mapping
– Supports multiple instances and gaming simultaneously
– Regular updates and bug fixes
– Good performance with lightweight design
– May lag with multiple windows open
– Security protocols are weak
Ko Player – Device-free operation for Android features
– Built-in Google Play Store for easy access
– User-friendly interface
– Supports video recording and gameplay sharing
– Limited customization options
– Customer support only via email
Memu – Easy installation and user-friendly
– Good support for Intel and AMD chips
– Virtualization support for improved performance
– Allows multiple accounts and game instances
– Performance issues on low-end computers
– Primarily focused on gaming only
Play PUBG Mobile on PC without Android Emulator
AnyMiro is a tool for playing PUBG Mobile on a PC without using an Android emulator. It is a multifunctional app that allows Android or iOS users to share their displays with a computer while gaming. You can stream multiple devices simultaneously, showcasing different content as you play.
Furthermore, you can easily capture your best gameplay moments by recording them in real-time during the mirroring process. AnyMiro also lets you live stream your gameplay audio to platforms like YouTube and Zoom, which is perfect for sharing with friends or followers. Choose your preferred connection method, which is via Wi-Fi or USB, for ultimate convenience.
Key Features:
Now, let’s explore the simple steps to use AnyMiro for screen mirroring your Mobile to PC:
Via USB
Step 1. Begin by free downloading and installing AnyMiro on your computer. Then, open the AnyMiro app on your PC.
Step 2. Select the “Android” option to set up the connection.
Mirror Android to Computer
Step 3. Click on the “USB” icon and connect your phone to your computer using a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 4. Enable “USB debugging” on your mobile and choose “MTP Mode” when prompted.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Your phone’s screen should now be displayed on your computer, showing that mirroring is successful!
Via Wi-Fi
Step 1. First, install AnyMiror on your computer and open the app. Choose the “Android” option from the main menu.
Step 3. Click on the “Wi-Fi” icon to begin the wireless connection.
Mirror Android to Computer via WiFi
Step 4. On your phone, find AnyMiro on Google Play or scan the QR code to download the app.
Step 5. Open the AnyMiro app on your phone and select “Wi-Fi Connection.”
Select the Connection Method
Step 6. Pick your computer’s name from the list to mirror your phone’s screen.
FAQs on How to Play PUBG Mobile on PC
Can I use my phone’s microphone while playing PUBG Mobile on PC?
Absolutely! You may play PUBG Mobile on PC and use the microphone on your phone. You can effortlessly stream audio from your phone to your computer using AnyMiro.
Is using third-party software safe when playing PUBG Mobile on a PC?
Using third-party software can be safe if you pick reliable ones. AnyMiro is a good choice; it keeps your account secure while you play.
Does playing PUBG Mobile on a PC require a fast internet connection?
A fast internet connection is important for playing PUBG Mobile on a PC. A strong connection helps reduce lag, making the game more fun.
Final Words
In conclusion, playing PUBG Mobile on your PC can improve your gaming experience. You can enjoy smoother controls and better graphics compared to mobile. Using tools like AnyMiror allows you to play without needing an emulator. AnyMiror has great features like easy device connection, live audio streaming, and screen recording.
Joy Taylor
