Home Screen Mirror How to Play Call of Duty Mobile on PC
One of the entertaining ways of playing Call of Duty Mobile is on a PC with better controls and more screen space. In this tutorial, we’ll teach you how to play Call of Duty Mobile on PC by either using an emulator or AnyMiro. Both provide a simple setup and easy gameplay. To easily improve your COD Mobile game experience on your PC, follow these steps.
Joy Taylor | Last Updated: Nov. 19, 2024
1439 words|5minute
Playing Call of Duty Mobile on your computer allows you to experience a new dimension. You get more precision with controls when using a keyboard and mouse and a wider screen through which you can see the happenings on the field. Wanting to improve your gameplay or have a preference over game consoles, getting Call of Duty Mobile on your computer is pretty easy and simple. Within minutes, you can jump into action to play Call of Duty Mobile from your computer. Let’s explore how to play Call of Duty Mobile on PC in detail!
Also Read: How to Play iOS Games on PC >
What is a Call of Duty Mobile Game?
Call of Duty Mobile is a first-person shooter specially designed for mobile devices and brings some of the most familiar actions from Call of Duty into mobile phones. Some of the best features of CODM are:
Can You Play Call of Duty on PC?
Playing Call of Duty on a computer can use any screen mirroring tool or emulator. First, download the game from a source, followed by easy installation instructions. Some system requirements for this game are:
Minimum Specs Recommended Specs
Operating System Windows 10, 64-bit (version 1709+) Windows 10, 64-bit (latest version preferred)
Processor Intel Core i3-4340 / AMD FX-6300 Intel Core i5-2500K / AMD Ryzen R5 1600X
Memory (RAM) 8GB 16GB for smoother gameplay
Graphics Card NVIDIA GTX 670 / GTX 1650 / Radeon HD 7950 NVIDIA GTX 1080 / RTX 2070 SUPER for high detail
How to Play Call of Duty Mobile on PC?
Now, let’s discuss the methods to play Call of Duty Mobile on PC:
Play Call of Duty Mobile on PC via AnyMiro
AnyMiro makes playing Call of Duty Mobile on PC easy and smooth by mirroring your phone screen with a stable, lag-free connection for up to 10 hours. Its clear graphics may exceed 4K and provide an unbelievable image quality that unveils all the details of your game on a large display. It also supports low latency audio sync for synchronized reproduction and matching of audio and video that will enrich the gaming experience.
AnyMiro has screenshot and recording options for streamers, allowing you to instantly save and share memorable moments. The live annotation feature is a great addition, enabling you to highlight important points directly on the screen and making for interactive and dynamic streams.
Key Features:
Here are the simple steps to use AnyMiro for playing Call of Duty Mobile on PC:
From iPhone to PC & Mac Via USB:
Step 1. Free download AnyMiro on your computer. Launch AnyMiro on your PC or Mac and select “iOS/iPadOS.”
Mirror iPhone to Computer
Step 2. Click the “USB connection” option to start the connection. Continue by linking your phone to the computer with a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 3. To connect, hit “Trust” on your iPhone or iPad.
Trust Your Computer on iPhone
Step 4. Your device will be prepared for mirroring once you enter your passcode when requested.
From Android to PC & Mac Via Wi-Fi:
Step 1. Free download AnyMiro on your computer and open it.
Step 2. Select “Android” from the main menu.
Mirror Android to Computer
Step 3. Click the “Wi-Fi” icon to initiate the wireless connection.
Mirror Android to Computer via WiFi
Step 4. On your Android device, download the AnyMiro app from the Google Play Store or scan the QR code.
Download AnyMiro App on Your Phone
Step 5. Open the app on your phone, then select “Wi-Fi Connection.”
Select the Connection Method
Step 6. Pick your computer’s name from the list to begin screen mirroring.
Select Your PC to Access Android from PC
Play Call of Duty Mobile on PC with Emulator
The most popular emulator that can be used to play shooting games such as CODM on your PC is BlueStacks. With it, you can use a keyboard and mouse to control your games and enhance your overall game capability and gameplay flexibility. This is one of BlueStacks’s key features because it’s possible to map keys for most controls and change them with choice. With high-definition games and better graphics than mobile devices, CODM can be enjoyed in further detail. Another is its multi-instance feature that allows the user to launch many games or multiple accounts simultaneously.
Step 1. Install BlueStacks on your PC.
Step 2. Launch the software on your PC and use the search bar in BlueStacks to find Call of Duty Mobile.
Search The Game
Search The Game
Step 3. Click the “Install” button to download the game from the search results.
Click Install
Click Install
Step 4. If you skipped the sign-in step earlier, log in to Google to complete the installation.
Step 5. Open Call of Duty Mobile from your home screen to begin playing.
FAQs on How to Play CODM on PC
Does playing CODM require a powerful PC?
Although a high-end computer is not necessary to play CODM, performance can significantly improve with a good processor and at least 8GB of RAM. An efficient graphic card also helps improve the visual impression of the games.
Can I play CODM on a PC using my phone screen?
You can play CODM on a PC by mirroring your phone’s screen using AnyMiro. This app connects your phone to the computer wirelessly or through USB, allowing you to play without an emulator while maintaining good quality and performance.
Is there a way to improve my gameplay controls on PC?
Yes, you can customize the controls using an emulator like BlueStacks. It lets you map the keyboard and mouse for better precision and comfort, giving you a more competitive edge during gameplay.
Final Words
By using screen mirroring software or emulators such as BlueStacks, Call of Duty Mobile may now be played on the computer easily. Emulators can customize your controls, making your games smooth and natural. At the same time, screen mirroring apps such as AnyMiro help you connect your phone to your PC for direct connection where real-time games may unfold. You may enjoy CODM on a larger screen with better controls using either the ease of screen mirroring or the versatility of emulators. For an optimal experience, we recommend using AnyMiro because of its stable connection and smooth mirroring features, which are perfect for gamers who want to play without lag.
AnyMiro – Real-Time Screen Mirroring Tool
  • More than 10 hours of stable screen mirroring connection.
  • Up to 4K resolution providing a stunning visual experience.
  • Integrates with live streaming tools such as OBS and Streamlabs.
  • Auto-sync video and background audio with timestamp adjustments.
100% Clean & Safe
100% Clean & Safe
Joy Taylor
