Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Have you ever encountered a situation when the PC screen keeps going black for a second? This article mainly describes why this happens and how to fix this issue.
“My PC screen keeps going black for a second for every minute. Any idea what’s causing this and what can be done to fix it?”
Whether you use a desktop computer or a laptop, the situation where the screen goes black has become a common annoyance. From the data collected on the Microsoft community, many users have experienced similar problems as follows:
Experiencing a sudden black screen on your monitor can be extremely frustrating. However, there is no need to worry as I have prepared a comprehensive guide that will help you identify the possible causes and provide solutions for this problem.
When a PC screen keeps going black for a second or flickers, it can be caused by various factors, to diagnose the exact issue, and fix PC screen going black issue. You are required some troubleshooting. Here are some common reasons why a PC screen might go black for a second:
No matter what kind of black screen you encounter, you can try the following 5 methods. We believe these methods can help you solve the problem effectively. Before trying these fixes, you should:
1. Ensure that all your cables are properly fitted, especially if you use a desktop.
2. Check and replace the monitor connection cable to see if it can be restored to normal.
If the PC screen keeps going black for a second caused by driver issues, you can follow these steps to address and potentially fix the problem:
Step 1. Update Graphics Drivers.
Step 2. Clean Install Graphics Drivers (if updating doesn’t work).
Step 3. Check for Windows Updates: Go to “Settings” > “Update & Security” > “Windows Update.”
Windows Update PC Screen Keeps Going Black for A Second
Step 4. Test with Default Graphics Drivers.
Step 5. Roll Back Drivers (if the issue started after a driver update).
Step 6. Use System Restore (if the issue started after a recent driver update or software installation).
You may also resort to checking power management settings to fix pc screen going black issue
Step 1. Access Power & Sleep Settings.
Open the Windows “Settings” by pressing Win + I on your keyboard or clicking on the “Start” menu and selecting “Settings”; Then in the Settings windows, click on “System.”; Next, on the left sidebar, select “Power & sleep”.
Step 2. Adjust Screen and Sleep Settings.
Step 3. Change Advanced Power Settings.
Step 4. Adjust Display and Sleep Settings in Advanced Power Options.
Step 5. Restart Your PC.
Step 6. Test for Improvement.
It’s essential to perform a thorough malware scan to detect and remove any potential threats. Here’s how to do it:
Malware PC Screen Keeps Going Black for
A Second
Step 1. Use Antivirus Software.
Step 2. Perform a Full System Scan.
Step 3. Quarantine or Remove Detected Threats.
Step 4. Perform Additional Scans.
Step 5. Update Operating System and Software.
Step 6. Monitor for Further Issues and Prevent Future Infections.
If you suspect that hardware issues may be causing your PC’s screen to go black for a second, it’s essential to perform some diagnostic tests and potentially make hardware adjustments or replacements. Here are steps to address hardware-related problems:
Step 1. Check Connections.
Step 2. Monitor Temperature and Cooling.
Step 3. Check for GPU Issues.
Step 4. Check the Power Supply Unit (PSU).
Step 5. Inspect the Motherboard and Other Components.
Step 6. Check for Software Conflicts: Sometimes, software conflicts can mimic hardware issues. Ensure that your operating system and drivers are up to date.
If your PC’s screen is going black for a second and you suspect it might be related to Windows updates, you can follow these steps to address the issue:
Step 1. Check for Windows Updates: Go to “Settings” > “Update & Security” > “Windows Update.”
Update Windows to the Latest Version
Step 2. Review Update History: Review the list to see if any recent updates coincide with when the black screen issue started. If you suspect a particular update is causing the problem, you can try to uninstall it.
Step 3. Uninstall Problematic Updates.
Step 4. Pause or Defer Updates
Step 5. Update Drivers and Software.
Step 6. Create a System Restore Point and Monitor for Improvement.
We’d like to recommend you a new screen mirroring tool AnyMiro, which is a powerful and stable screen casting app that allows users to mirror their iPhone or Android screens to Windows/Mac via USB/Wi-Fi. It supports various screen mirroring functionalities, such as streaming videos, showcasing presentations, and displaying mobile apps on larger screens. AnyMiro will present you an:
You can download Anymiro from the following button:
1. Why does my monitor keep going black when gaming?
Most of the time, the problem occurs because of outdated graphics drivers, a problem with the monitor connection, improper power-saving settings, prolonged hardware stress, excessive heat generation, or misconfigured game settings.
2. Why does my laptop screen go black randomly Windows 11?
If you have issues, check drivers, cables, and power. Test with new hardware or seek professional help if the problem persists or if it’s a hardware issue.
3. Why does my computer keep going black and then coming back on?
If your monitor goes black and then comes back on, it could be due to a loose cable, outdated/corrupted graphics driver, failing backlight, or power supply issues. Please provide more information for better assistance.
The issue of the PC screen keeps going black for a second can be quite frustrating. However, with the right troubleshooting steps outlined in this guide, you can often identify and resolve the problem. In this article, we also recommend a screen mirroring app AnyMiro to mirror your phone on your PC. It is the easiest way to enjoy screen mirroring your phone on your PC when streaming or sharing content in your personal and professional life. Give it a try and enhance your digital experience!
