Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Have you used OBS? Using OBS to capture and display phone screen content can bring many benefits. To achieve open phone screen capture on OBS, you typically need to download a screen mirroring app. This article tells you how to open phone screen capture on OBS.
OBS is a free and open-source multimedia streaming software. It allows users to create high-quality live streaming, recording, education, entertainment, presentations, and technical support and capture their computer screens.
Originally designed for game streaming, OBS has gained popularity as mobile gaming became more widespread. People now enjoy live streaming their mobile games to PC using OBS, integrating their smartphone screen content into this powerful multimedia streaming software. This requires establishing a connection between the smartphone screen and OBS. In this post, we will write how to open phone screen capture on OBS.
Before we embark on the goal of “Open phone screen capture on OBS,” it’s important to ascertain whether there’s a way to achieve this functionality. Generally, you would need to connect your phone to your computer first. Typically, this involves using a screen projection or mirroring tool to transmit the images from your phone screen to your computer, then setting up OBS to capture this window or region, thereby displaying the phone screen’s content in your video content.
By utilizing a screen mirroring app, you can stream Android to OBS. In the following section, we will guide you on how to open phone screen capture on OBS using a screen mirroring app.
Another way to capture your phone screen on OBS is to record it. In addition to live streaming, OBS supports you in capturing and recording the screen. In the following section, we will provide a detailed guide to tell you how to screen record in OBS.
As mentioned above, in order to open phone screen capture on OBS, it is usually necessary to utilize a screen mirroring app to establish a connection between the smartphone and the computer.
Here is how to open phone screen capture on OBS:
To achieve the goal of opening phone screen capture on OBS, you’ll need to choose a reliable third-party screen mirroring software, and AnyMiro is indeed an excellent choice. AnyMiro is a free and user-friendly screen mirroring software that supports mirroring Android and iOS devices to your computer via Wi-Fi or USB cable. AnyMiro offers a highly stable connection, and it responds in less than 10 milliseconds. AnyMiro excels in providing a stable connection performance compared to other screen mirroring software.
With AnyMiro, capturing your phone screen and seamlessly streaming it to platforms like Twitch, YouTube, Facebook, or custom RTMP becomes a breeze. You can mirror the Android screen to OBS via USB or Wi-Fi. It ensures 100% color accuracy and preserves the image quality without any visual distortions. Moreover, AnyMiro will simultaneously cast both audio and screen, making your live streams more engaging and captivating.
Here are the key features of AnyMiro:
Here is the step-by-step guide to how to use AnyMiro to mirror phone screen:
Step 1. Click the download link of AnyMiro on your Windows computer or Mac.
Step 2. After the download is complete, open the main interface. Select either an iOS or Android device. In this case, choose an iOS device and click “Next.”
Mirror iPhone to Computer
Step 3. Next, select the Wi-Fi mode for connection. Ensure that both your phone and computer are connected to the same Wi-Fi. If you have a USB cable, you can also choose that option.
Step 4. Now, open the Control Center on your iPhone/iPad. Tap on “Screen Mirroring” and select your computer’s name when it appears.
Step 5. Finally, your phone’s content will now be mirrored onto your computer.
Mobile Screen Mirrored on the Computer with AnyMiro
When you have mirrored your phone screen onto your computer, the next step is to connect the phone screen capture to OBS.
Step 1. Open OBS Studio on your computer. In the Scenes panel, right-click and select “Add” > “Window Capture.” Choose the window that corresponds to the mirrored phone screen, which would be the AnyMiro window in this case.
Open Phone Screen Capture on OBS – Window Capture
Step 2. Once you have added the Window Capture source, you can adjust the size and position of the captured screen. Modify the source settings to ensure that the mirrored screen is perfectly presented within your OBS scene.
Another demand for capturing phone screens on OBS is to make a screen record. To screen record mobile phones on OBS, other guides will require you to download compatible apps to use your smartphone as a webcam. However, with AnyMiro, you don’t need to download more apps. It supports both screen mirroring and screen recording, making it easy and light.
Follow the steps below to see how to screen record with OBS on iPhone and Android.
Step 1. Follow the steps in Part 2 to use OBS to display your iPhone or Android screen.
Step 2. Click the Settings icon on the top to set up the screen record settings.
Click Screen Mirror Settings Icon
Step 3. AnyMiro supports saving screen recordings in MP4 and MOV formats. You can also choose to record system sound only, microphone sound only, or a combination of both.
Set up screen record settings
Step 4. After finishing the screen record setting up, click the screen record button. Now you can make a screen record with AnyMiro at the same time you use OBS to capture your iPhone or Android screen.
Screen recording your phone screen
Here are some common scenarios of opening phone screen capture on OBS.
1. Gameplay Streaming:
Streaming mobile games has become increasingly popular. Recording your mobile game screen and streaming it on platforms such as Twitch or YouTube brings a fresh element to the gaming community.
2. Educational Tutorials:
Educators and online course creators can leverage phone screen capture to enhance their tutorials. Whether you’re showing how apps work, guiding through step-by-step tasks, or explaining mobile concepts, OBS helps teachers make interesting and informative content.
3. App Demonstrations:
App developers and marketers can benefit from capturing phone screens to showcase their applications. OBS allows for interactive presentations, where app features and user experiences can be seamlessly shared with potential users or clients.
To open phone screen capture on OBS, we rely on a screen mirroring app. Therefore, we recommend using AnyMiro for screen mirroring. Whether you have an Android or iOS device, you can effortlessly project your screen onto your computer. AnyMiro offers a remarkably stable connection. Download and give it a try today.
