Stream your mobile gaming with ease! This ultimate guide to mobile gaming streaming setup explores the best techniques with AnyMiro.
Streaming mobile game to PC with the help of screen mirroring app
Available for both Win & Mac
Have you ever wished to share your thrilling gaming experience with others? Or perhaps you’re an aspiring gamer ready to turn your passion into a profession.
No matter the situation, many gamers want to show off their skills to the world. And they can easily do that by streaming their gameplay!
This brief guide walks you through making a mobile gaming streaming setup. We’ll show you how to stream mobile games on PC as well as on mobile phones.
But before we get started, let’s see what tools we need to stream mobile games.
If you want to stream your mobile games on a PC, there are two main steps you need to follow. First, you need to shift your mobile screen to the computer. And then stream the mirrored screen from the computer.
And while you are doing this, here are some tools you need to stream mobile games.
Tools to Use
A screen mirroring software will allow your PC to display the activities on your mobile device screen.
You will need a USB cable or a stable WiFi connection to mirror your Android to your PC.
Software like OBS and Streamlabs is the core of your streaming setup if you stream via your PC.
A mobile streaming app is required if you prefer to stream directly from your mobile device.
And that’s all!!!
Now let’s delve deeper into the setup process. We’ll first see how to stream mobile games on PC.
To stream mobile games on a PC, our first step is to mirror the mobile game on the computer.
1. Mirror Mobile Game to the Computer
As discussed earlier, your computer first needs to detect the mobile phone to stream it. And a screen mirroring tool can help you with that. It allows the visual content of your mobile game to be displayed on your PC screen.
For this purpose, we recommend using AnyMiro.
AnyMiro is a popular Android mirroring tool. It was engineered by iMobie, with 10+ years of development experience.
AnyMiro delivers high-quality & smooth audiovisual streaming. There’s also a 24/7 service team of AnyMiro ready to answer all your queries anytime. And all purchases of AnyMiro come with a 60-Day money-back guarantee.
Anymiro Official Webpage Interface
Why Choose AnyMiro?
Here are some compelling reasons you should choose AnyMiro for your mobile game streaming setup.
The visual detail is important if you are streaming gameplay. And AnyMiro supports up to 4K resolution. So your audience gets to enjoy your gameplay in all its graphical glory.
The reliability of your stream is crucial. AnyMiro ensures this with its capability to stay connected for 10+ hours using USB 3.0 and the AirPlay protocol. This level of stability prevents unwanted disruptions to your stream.
Any gamer knows the frustration of latency issues. Your stream will run smoothly with AnyMiro’s fast response time of 10 ms. It also gives a refresh rate of 120Hz and a 60fps frame rate.
AnyMiro offers flexibility by supporting both USB and WiFi mirroring methods. So you choose the most convenient connection method based on your specific requirements.
Now are you ready to use AnyMiro for your mobile gaming streaming setup? Let’s dive into the details of how to do it.
How to Mirror Mobile Game to PC with AnyMiro
Here’s how you can mirror your mobile game to your PC using AnyMiro:
Step 1. Install AnyMiro on Your Computer
Download and install AnyMiro on your computer. Once installed, launch AnyMiro and select whether you want to mirror an iOS or Android device.
Select the Device to Continue
Step 2. Connect Your Android Device
You have the flexibility to connect via a USB cable or Wi-Fi.
For a USB connection, tap the USB icon. Then connect your Android device using a USB cable. Ensure USB debugging is turned on and select the MTP mode.
Connect your device with a USB cable
For a Wi-Fi connection, tap the Wi-Fi icon. Follow the prompts on your device and AnyMiro to establish a connection.
Connect Your Screen to the Computer via Wi-Fi
Step 3. Install AnyMiro App on Your Android Device
You’ll need the AnyMiro app on your Android device for Wi-Fi connections. You can download this from the Google Play Store or scan the QR code from the desktop AnyMiro application.
Scan the QR Code to Download the AnyMiro App
Step 4. Start Mirroring
Once the connection is successful, your device’s screen will be mirrored onto your computer.
AnyMiro Streaming Mobile Gaming on PC
After this, the first step of our mobile game streaming setup is complete.
Now you’re ready to start streaming your mobile game.
2. Set Up Streaming on Streaming Service
The next important mobile gaming setup phase involves establishing your streaming service. OBS is popular due to its comprehensive feature set and open-source nature.
So let’s see how to stream mobile games on PC with OBS!
Here’s how you can set up your mobile game streaming using OBS:
Step 1. Install OBS
Begin by downloading and installing OBS Studio from the official website onto your computer. After installation, launch the program.
Step 2. Create a New Scene
In OBS; scenes represent different setups for your stream. Click the “+” button under the “Scenes” box. Now name your scene, and click “OK.”
Step 3. Add Sources
In the “Sources” box, click the ‘+’ button and select “Window Capture.”
Selecting the AnyMiro Screen as the Source in OBS
Name this source, select the AnyMiro window from the dropdown menu, and click “OK.”
Step 4. Arrange Your Sources
Drag and resize your sources within the preview window to arrange your stream’s layout.
Step 5. Configure Streaming Settings
Now, navigate to Settings > Stream and select your streaming service from the dropdown menu.
Selecting the Streaming Source from the OBS Settings
Step 6. Enter Stream Key
Then enter your stream key, which you can obtain from your streaming service’s dashboard.
Enter the Stream Key
Step 7. Start Streaming
Click “Start Streaming” to go live. Monitor your stream from the “Controls” box in OBS.
Start Your Game Streaming
And that’s it! The mobile gaming streaming setup is all set on this PC.
Now that you’ve learned how to stream mobile games with OBS, let’s move on. We’ll now show you how to make a mobile game streaming setup using the streaming apps.
In contrast to streaming mobile games via a computer, there’s also a direct way. And it’s appealing if you want to stream on the go. This easy method takes the help of mobile streaming apps. Let’s take the popular Twitch mobile app as an example and create a mobile game streaming setup.
Step 1. Download and install the Twitch app from the Apple App Store or Google Play Store.
Installing Twitch from Google Play Store
Step 2. If you already have a Twitch account, log in. If not, create a new account.
Step 3. Tap on your profile icon in the top-left corner of the screen.
Step 4. This “Go Live” option will be located in your profile dashboard. Tapping on this will open the “Stream Setup” page.
Starting Streaming from the Twitch App
Step 5. Here, you can choose the game you’ll be streaming. After that, set your stream’s title and every other detail. Then click on the done button at the top right corner.
Step 6. Now adjust some other settings and hit the large purple “Start Stream” when ready to go live. To end the stream, tap “End” at the top of the screen.
Adjusting the Setting of Our Game Streaming
Streaming directly from your mobile device provides a portable solution for mobile game streaming. However, this method might not offer the same level of customisation & control that you’d get from a PC-based setup.
So, after all this discussion, here are some important takeaways on mobile gaming streaming setup.
It’s important to remember some key points while setting up your mobile gaming streaming setup.
Now before we end our guide, here are some frequently asked questions about mobile gaming streaming setups.
1. Can you Stream Games from Phone to PC?
Yes, you can stream games from your phone to your PC. But for this, you will need the help of a mobile mirroring app to mirror your mobile display on a PC. And AnyMiro can do it in no time.
And after you have successfully mirrored your mobile phone, just use any streaming tool to stream your gameplay. You can opt for OBS as it’s free and open-source.
2. Do I Need a Capture Card to Stream Mobile?
A capture card is a device that takes video input and translates it into digital signals. It is often employed when streaming footage from a DSLR camera or gaming from consoles. Some cutting-edge mobile devices are also compatible with capture cards for PC streaming. However, it’s not a necessity!
You can effectively stream without using software like AnyMiro and OBS. These tools negate the need for additional hardware while delivering high-quality streaming experiences.
3. How Do I Stream Mobile Games with OBS?
First, you must mirror your mobile screen onto your PC. Then, within OBS, you create a new “window capture” source and select the mirrored screen to capture your gameplay. After that, just start streaming with OBS.
4. How Do I Connect My Phone to OBS Via USB?
You’ll need a USB screen mirroring tool to connect your phone to OBS. AnyMiro is an excellent choice as it supports a USB connection. It also provides a stable, high-resolution screen mirroring experience.
Starting a mobile gaming streaming setup can be daunting. But with the right tools, it becomes a breeze.
The pivotal step involves mirroring your mobile screen onto a PC. And this feat can be easily achieved with AnyMiro. This app provides seamless, high-resolution screen mirroring that harmonizes with your chosen streaming service. So if you’re a streamer, AnyMiro ensures your gaming experience reaches your audience effectively. Don’t wait; start your mobile gaming streaming journey today with AnyMiro.
