How-to: Mirroring Phone to Chromebook (iOS & Android)
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror How-to: Mirroring Phone to Chromebook (iOS & Android)
Learn how to display your entire iOS or Android screen on your Chromebook computer by following our detailed guide on: mirroring phone to Chromebook.
Joy Taylor | Last Updated: Nov. 07, 2023
1706 words|5minute
Are you looking to share your mobile screen on Chromebook? Look no further!
Chromebook isn’t like the popular computer systems- Mac and Windows that most people know of. Even though it comes with quality features, such as portability, sleek design, and more, the functionalities are limited, and that makes it difficult for many users to execute several operations on it.
One of the major challenges with Chromebook is difficulty with mirroring a mobile screen on it. If that’s the same issue you are currently faced with, then this is the right place to be. In this article, we will discuss the various approaches to mirroring phone to Chromebook in detail.
Can I Mirror My Phone to Chromebook?
Sure you can! You can always mirror your phone to Chromebook following the traditional screen mirroring technique, which involves the use of built-in features, such as AirPlay as in the case of iPhone, USB connectivity, or the installation of third-party apps that supports mirroring phone to a computer system. Of all the aforementioned traditional screen mirroring techniques, we recommend the installation of third-party apps for mirroring phone to Chromebook.  It’s the easiest, fastest, and most secure option to use.
Enable USB Debugging – Android Phone Mirroring Preparation
As a criterion to use Chromebook screen mirroring, you might have to activate USB debugging on the mobile device you want to share the screen from. However, mind you, only selected operating systems, and third-party apps support this feature.
For instance, iOS devices don’t require USB debugging for mirroring phones to Chromebook. But if you own an Android smartphone, you need to enable USB debugging for the corresponding third-party app you want to use.
You can activate USB debugging on your Android smart device by following the guide given below:
Step 1. Unlock your Android smartphone, and navigate to the Settings menu page by hitting the gear ⚙️ icon.
Step 2. Next, head down the page and click on System. Select Advanced on the next screen that follows, then click Developer Options to proceed.
Tap Developer Options
Step 3. Now another screen should come up. Kindly click the reappropriate button to enable USB debugging on your device.
Enable USB Debugging on Android
The Advanced icon is only available on Android 9 and higher versions. If your phone runs on Android 8/7 or lower version, you might just have to proceed to Developer Options.
Mirroring Android Phone to Chromebook – Vysor Extension
Vysor Extension is a popular screen mirroring tool dedicated to sharing Android screens on any computer system, including Chromebook. This lightweight program lets you display whatever you have on your Android phone on your Chromebook computer via USB connectivity.
It’s a very simple tool with a straightforward approach to mirror your Android phone on a larger screen like Chromebook. Follow the instructions given down here to do this:
Step 1. On your Chromebook computer, visit the Vysor Extension page. Click on Browser to continue.
Download Vysor Browser Version
Step 2. Next, click the Install icon situated in the Omni bar at the top right corner of the page. Vysor Extension should install on your Chrome computer in no time. Once completed, proceed to the next step that follows.
Install Vysor Extension on Your Chrome
Step 3. Now activate USB debugging mode on the Android phone just as we’ve previously explained. After that, establish a connection between the Android phone and Chromebook using the appropriate USB.
Activate USB Debugging
Step 4. On the Vysor Extension page, find and click on Connect USB Device.
Click Connect USB Device in Vysor Extension
Select the connected Android device on the next screen, then tap on the blue Connect icon.
Select Connect Button in Vysor
Step 5. Once Vysor Extension connects with your Android smartphone, click the red Play button to activate Chromebook screen mirroring.
Play Phone Screen Mirroring
The corresponding content appearing on your Android screen will automatically appear on your Chromebook.
Limitations of Using Vysor Extension
Mirror Phone to Chromebook with USB
As earlier mentioned, USB connectivity is among the traditional screen mirroring techniques available for Chromebook screen mirroring. This method is one of the most straightforward and cost-free that you can employ to share your mobile screen.
It works for both Android and iOS operating systems. No USB debugging is required for this approach. If you wish to showcase what you have on your phone screen on a larger screen like Chromebook, follow the stepwise guide below to do so with a USB cable:
Step 1. Turn on the Chromebook computer system, then unlock your iPhone. Once done, connect your USB lightning cord to the appropriate ports, one to the iPhone and the other, to your computer system.
Step 2. Next, a notification will immediately come up on your iPhone requesting whether or not you want to grant the computer access to your device. Click Allow.
Step 3. Next, navigate to where you have Files on your Chromebook computer, click on it, and select Apple iPhone from the tabs that appear.
Once done, everything you have on your iPhone will come up on your Chromebook screen.
Mirroring the Android screen to Chromebook via USB cable follows a similar approach as in the case above. This approach doesn’t showcase your mobile screen, instead, it lets you access and view the content on it by clicking on the appropriate buttons.
Mirroring iPhone to Chromebook
Besides the use of a USB cord for Chromebook screen mirroring on iPhone, there are other approaches you can follow to accomplish the same result. A popular one is via a third-party application like Mirroring360.
Mirroring360 is amongst the notable screen mirroring tools available for iPhone users to share their screens with a computer system like Chromebook. This tool permits you to showcase whatever you have on your iOS screen on another PC without a USB connection. Rather mirroring the phone to Chromebook occurs via a wireless connection and AirPlay.
You can mirror iPhone to Chromebook via the Mirroring360 tool following the simple instructions below:
Step 1. Firstly, connect your iPhone and Chromebook to the same WiFi source. After that, install and launch the Mirroring360 Sender app by clicking on the corresponding link.
Step 2. Launch the Control Panel on your iPhone by swiping down from the upper right corner of your screen (if you own iPhone X or a later generation). If you own iPhone 8 or lower generation, kindly swipe up from the bottom to access the same page. Tap on the Screen Mirroring icon ( also known as AirPlay on some iPhones).
Step 3. On completing the step above, your iPhone will start sourcing for a nearby mirroring device to share your screen with. Click on your Chromebook computer name to establish a connection. In no time, your iPhone screen should start showing on the Chromebook computer.
Mirror Phone to Laptop Choice – AnyMiro
Our focus has been on mirroring phone to Chromebook computers. For the sake of folks with other computer operating systems, we will like to shift the discussion into screen mirroring on Windows and Mac.
AnyMiro is the ultimate screen mirroring solution for mirroring your phone to laptop. With this software, you can share your iOS or Android display screen on Windows and Mac computer systems without stress. It stands out among others, as it offers smooth, fast, and costless screen-sharing services.
Mirror iPhone to Computer
AnyMiro works well on both Windows and Mac computers, and it enables users to mirror iPhone and Android screens to the computer. The supported connection methods include USB cable and WiFi. What’s more, AnyMiro has made the mirroring experience more stable and smooth than ever.
What You Can Get from AnyMiro:
If you’re interested in this software, download it now and have a free try!
Mirroring phone to Chromebook is a simple yet cost-free and secure approach to accessing your data on a large screen. This article has introduced at least three ways to bring whatever content you have on your mobile to Chromebook screen. Which do you prefer?
And we also recommend the use of AnyMiro to share your screen on Windows or Mac computer systems. The software is known for great mirroring services for both Android and iPhone. AnyMiro is worth trying out. You should invest in the tool without hesitation.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
