How to Mirror iPhone to PC via USB
Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Home Screen Mirror How to Mirror iPhone to PC via USB
This article walks you through simple methods to mirror iPhone to PC via USB. You will discover how to install appropriate software and change a few settings on your device for this process. For a hassle-free experience and advanced features, we recommend using AnyMiro – an efficient screen mirroring tool – for seamless connectivity and quality display.
Joy Taylor | Last Updated: Nov. 15, 2024
1267 words|4minute
Do you want to share the iPhone screen using USB with your computer? You won’t believe how simple it is! You can experience gaming, photographs, and movies on a wider screen through iPhone screen mirroring to a computer using the right programs. Whether you want to give a presentation or enjoy your favorite apps, this guide will walk you through the process step by step. This post will guide you through a step-by-step process on using the best programs to mirror iPhone to PC via USB. So, let’s get started!
Why Mirror iPhone to PC via USB?
Using USB to mirror your iPhone to a PC has many advantages that improve user experience. Whether you’re sharing media, presenting critical information, or enjoying entertainment, this method offers a dependable way to conveniently and easily utilize your iPhone’s functions on a bigger screen. It is the best approach because of:
A USB connection securely links your iPhone and PC, preventing disruptions during important tasks.
Mirroring via USB gives crystal-clear images and videos, making everything look fantastic on your bigger screen.
USB mirroring ensures quick response times, so your actions on the iPhone show up instantly on your PC.
Connecting your iPhone to a PC with a USB cable is quick and straightforward, allowing you to start mirroring without hassle.
How to Mirror iPhone to PC via USB?
Now, let’s explore the simple methods to mirror iPhone to PC via USB:
Method 1. Mirror iPhone to PC via AnyMiro
You can explore the full potential of screen mirroring with AnyMiro, the ultimate screen mirroring app for PC. This powerful tool allows you to stream your gameplay and creative content seamlessly on your computer. With a focus on stability and smoothness, AnyMiro provides an enjoyable mirroring and streaming experience. You can achieve up to 10 hours of lag-free streaming, ensuring a rock-solid connection and stunning HD visuals that make every pixel pop.
The program supports high-resolution mirroring up to 4K, which is ideal for Android and iPhone users. Its low-latency audio-visual sync enhances real-time streaming, which is perfect for platforms like Twitch and YouTube. With features like live annotation, screenshot capability, and easy integration with popular streaming services, AnyMiro empowers gamers and content creators to elevate their streaming experiences.
Key Features:
Now, let’s explore the steps to use AnyMiro to mirror iPhone to PC:
Step 1. Download and open AnyMiro on your PC, then select “iOS/iPadOS” from the main menu.
Mirror iPhone to Computer
Step 2. Select the “USB” on the screen’s left side. A connection guide will then appear.
Connect Your iPhone/iPad with a USB Cable
Step 3. Tap the ”Trust“ button on your iPhone to mirror your screen onto your PC.
Trust Your Computer on iPhone
Method 2. Apple Lightning to USB 3 Camera Adapter
For mirroring an iPhone to a PC, the Apple Lightning to USB 3 Camera Adapter is a useful accessory. By reflecting the computer’s screen and enabling a steady, quick, and dependable connection, it links the iPhone to the system. It also supports faster data transfers for a smoother and more responsive experience when gaming or showing presentations.
This tool enables high-quality media transfers while mirroring your iPhone on your PC. The widely used JPEG and RAW photo formats as well as H.264 and MPEG-4 video codecs are supported by the Apple Lightning to USB 3 Camera Adapter. This versatility ensures that your mirrored content maintains excellent quality without any lag or loss in detail.
Product Lightning to USB 3 Camera Adapter
Ports USB-A, Lightning
Compatibility JPEG, RAW
Photo Formats H.264, MPEG-4
Video Formats USB 3 (for most devices), USB 2 (for older models)
Data Transfer Speeds Connects digital camera to iPhone/iPad
Functionality Connects digital camera to iPhone/iPad
Power Support Can be powered using a USB Power Adapter
To use this method:
Step 1. Plug the Lightning to USB 3 Camera Adapter into your iPhone.
Step 2. Connect a Lightning cable to the adapter’s Lightning port and plug it into a power source like a charger or your PC.
Step 3. Use the USB-A port on the adapter to connect a USB to HDMI adapter and an HDMI cable.
Step 4. Plug the HDMI cable into your monitor. Your iPhone screen should mirror automatically.
Step 5. If it doesn’t, swipe down from the top-right of your iPhone to open “Control Center.”
Open “Control Center”
Step 6. Tap “Screen Mirroring” and choose your monitor or TV from the list.
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Find and click on the AirPlay Icon (aka Screen Mirroring)
FAQs on Mirroring iPhone to PC via USB
Do I need special software to mirror my iPhone to my PC?
Yes, you typically need software to facilitate screen mirroring. Various applications, like AnyMiro, can help you mirror your iPhone to your PC easily. These tools provide instructions and support for a smooth mirroring experience, making it simple for anyone to get started.
Is it safe to mirror my iPhone to a PC?
Yes, mirroring your iPhone to a PC is safe using trusted software. Download applications from reputable sources to protect your device and data. Using well-known tools like AnyMiro ensures that your privacy and security are maintained during the mirroring process.
Can I control my iPhone from my PC while mirroring?
While some mirroring applications allow limited interaction, most focus on displaying content from your iPhone to the PC. You typically need to use your iPhone to navigate. However, applications like AnyMiro enhance the experience by allowing additional features, making presenting or sharing content easier.
Final Words
In conclusion, mirroring your iPhone to a PC via USB offers a reliable and high-quality way to share and view content. Tools such as the Apple Lightning to USB 3 Camera Adapter or even software solutions make it very easy to accomplish the task with a smooth experience. For the best results and ease of use, we recommend using AnyMiro. Its features facilitate smooth mirroring and enhance your overall experience, making it a top choice for anyone looking to connect their iPhone to a PC effectively.
Joy Taylor
