Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
Available for both Win & Mac
If you want to mirror iPhone to PC free, worry not! Below you will find several apps that will help you seamlessly mirror your iPhone screen to your PC via a USB or without it wirelessly.
Imagine watching an intense football match or a thrilling movie on your iPhone with a group of friends. Everyone’s huddled close together, trying to catch every moment. This might sound fun, but do you know what’s better? Having the same experience on a bigger screen!
This is where the need to mirror iPhone to PC for free comes in! Not only does one need to mirror their iPhone screen to a PC for a larger display, but this feature also comes in handy if you want to:
In this article, we will take you through the steps of screen mirroring your iPhone to a PC and show you some of the best iPhone to PC screen mirroring apps.
We know it’s the age of wireless technology and all; however, a USB connection offers some serious advantages:
So the very first method to mirror iPhone to PC for free is by using a USB, and for this, we recommend trying out AnyMiro.
AnyMiro is a free mirroring app for iPhone to PC, perfect for those moments when you want a bigger display and all the convenience that comes with it. The best thing about this tool is its user-friendly interface and easy setup. So, even if you’re not the most tech-savvy person around, you’ll have no trouble getting started and enjoying the benefits of mirroring your iPhone to your PC.
AnyMiro lets you mirror your iPhone to your PC using a USB cable. With that sorted, let’s see how to screen mirror an iPhone to a computer with AnyMiro via USB.
Follow these steps to mirror your iPhone/iPad to your PC with AnyMiro:
Step 1. Download and Launch AnyMiro
Free download and launch AnyMiro on your PC > Select the “iOS/iPadOS” option from the interface.
Mirror iPhone to Computer via AnyMiro
Step 2. Connect iPhone via USB
Connect your iPhone to your PC using a lightning cable > Select “USB” from the options on the left.
Select the USB Option for Screen Mirroring iPhone to PC
Step 3. Trust the Computer
Once the PC recognizes your device, you will receive a pop-up on your iPhone whether you trust the computer > Select “Trust” to continue.
Trust Your Computer on iPhone
You can now see your iPhone’s screen on your PC.
But why should you use AnyMiro for iPhone screen mirroring to PC? Let’s see!
Using AnyMiro has its benefits, for instance:
Now that you know how to mirror iPhone to computer via a USB connection, let’s teach you the wirelessly way.
While USB provides stable connections, wireless screen mirroring also has its perks! For instance:
To screen mirror your iPhone to a laptop, especially when you’re using Windows which doesn’t natively support AirPlay, follow these simple steps:
Step 1. Download Screen Mirroring Software:
Choose and download a third-party AirPlay receiver software like Reflector or AirServer for your PC. Follow the provided instructions to install and configure the software on your computer.
Step 2. Access Control Center on iPhone:
On your iPhone or iPad, swipe up from the bottom of the screen or swipe down from the top right corner to open the Control Center.
Step 3. Enable Screen Mirroring:
Tap the “Screen Mirroring” or “AirPlay” button.
Click on the AirPlay Icon (aka Screen Mirroring)
Step 4. Select Your PC:
Your PC should appear in the list of available devices. Select it to establish the connection.
Step 5. Start Mirroring:
Once connected, your iOS device’s screen will be displayed on your computer, allowing you to enjoy content on a larger screen.
And here’s the best part: You can use AnyMiro to mirror your iPhone to your PC wirelessly as well!
Here’s how:
Step 1. Download and launch AnyMiro on your PC, and select “iOS/iPadOS” from the interface.
Step 2. Select the WiFi option on the left. You can see there is a connection guide.
Step 3. Connect your iPhone and your PC to the same Wi-Fi network.
Connect to the Same WiFi
Step 4. On your iPhone, go to the Control Center > Screen Mirroring and select your computer from the list of available devices.
And that’s it! You’re all set to screen mirror iPhone to PC for free wirelessly using AnyMiro!
However, if you would like to try other screen mirroring apps, we’ve reviewed some of the top free iPhone-to-PC screen mirroring apps in the following section.
You will find a ton of screen mirroring apps for iPhones in the market; however, not all are considered top-notch or reliable. Therefore, we have narrowed down the list to 4 best free apps to mirror iPhone to PC.
If you’re looking for a free mirroring app for iPhone to PC, we suggest trying out LonelyScreen. We recommend this app because you don’t have to go through any complicated installation processes or deal with technical headaches. It’s designed to be user-friendly, so you can get started with mirroring your iPhone screen to your PC in no time.
The best part about LonelyScreen is that it supports audio mirroring as well. It is perfect for enhancing your multimedia experience and enjoying your favorite music, videos, or podcasts.
LonelyScreen Works as AirServer Alternative
Limitations
Pricing Plans
If you’re wondering how to screen mirror iPhone to Windows 11, try AirDroid Cast! It is a screen mirroring app that not only casts the screen of your iPhone and Android devices to a PC but also enables you to mirror your PC on another PC wirelessly. However, if you’re old-school and wireless casting is not your cup of tea, it also has a USB connection feature for a stable screen mirroring session.
AirDroid Cast
Limitations
The free version only lets you mirror your screen. You’ll have to get the paid version to use advanced features like file transfer or remote control.
Pricing Plans
Another free mirroring app for iPhone to PC is Mirroring360. It is a versatile app compatible with Windows, Mac, iOS, Android, and Chromebook.
The standout feature of Mirroring360 is its web link that allows you to broadcast your PC to up to 40 participants. How convenient that is!
Mirroring360 Interface
Limitations
Pricing Plans
Reflector 4 is a famous app to wirelessly mirror iPhone to PC free. It has a bunch of impressive features, with a user-friendly interface that offers a seamless screen mirroring experience between devices.
But that’s what all screencast apps do, right? What sets Reflector 4 apart is its personalization features that enable users to adjust the frame rate, customize device frames, and add watermarks to their shared screens.
Reflector Interface
Limitations
Pricing Plans
Our Recommendation
While all 4 of these screen mirroring apps are good options to mirror iPhone to PC free, if we have to choose one, we would hands down go for Reflector 4. Why? Because it offers a one-time purchase option for a lifetime of access, while you have to renew your subscription for the other apps every month or year. Secondly, it has more personalization options, which help you optimize your screen mirroring setup.
AnyMiro or Reflector 4? Which one is it going to be? Here’s a head-to-head comparison of both tools to help you choose the one that best fits your needs.
AnyMiro | Reflector 4 | |
Compatibility | iOS, Android, Windows & Mac | iOS, Android, Windows & Mac |
Connection Method | Wireless & USB | Wireless |
Price | Free Trial Version Pro: $15.99 |
Free Trial Version Pro: $21.99 (charges separately for Windows and Mac) |
Ease of Use | Easy to use, even for beginners | Easy to use but has a steeper learning curve than AnyMiro |
Recommendation | Versatility and compatibility | Professional use with customization options |
So, if you’re looking for versatility and compatibility, we recommend going for AnyMiro; however, if you’re a professional and would like to do things your way, Reflector 4 is a better option. Now that you know all there is to know about screen mirroring, let’s move on to some common queries by our users.
1. Is It Possible to Mirror iPhone to PC without Software?
Yes, it is possible to mirror iPhone to PC free without software using the AirPlay feature. However, this method only works for Mac. But, if you have a Windows PC, you’ll need a supporting third-party app due to compatibility issues.
2. Can I mirror my iPhone to my PC?
Yes, you can mirror your iPhone to a Windows PC with third-party screen mirroring tools. Options such as AnyMiro, AirDroid Cast, and ApowerMirror are great choices. AnyMiro supports WiFi and USB screen mirroring methods, making iPhone-to-PC screen mirroring more flexible and convenient, just like AirPlay iPhone to Mac.
3. How to mirror iPhone to a TV?
You can mirror an iPhone to a TV wirelessly via the built-in AirPlay feature, which is compatible with Apple TVs or AirPlay-enabled speakers. If you don’t have an Apple TV, you can use Lightning Digital AV Adaptor that plugs into your iPhone’s Lightning port and outputs an HDMI signal.
4. How to mirror iPad to PC?
Just like an iPhone, you can mirror an iPad to PC using AirPlay, in case it’s a Mac. For Windows, you’ll need to install a third-party app like AnyMiro that acts as a gateway between your iPhone and PC to enable screen mirroring.
Wrapping up, the need to mirror your iPhone to a PC has never been more relevant. For a seamless and high-quality mirroring experience, AnyMiro is the go-to solution that combines ease of use with advanced features.
Ready to enhance your screen mirroring? Download AnyMiro and enjoy the freedom of displaying your iPhone on a larger screen with just a few clicks.
