Top 4 Methods to Mirror iPhone to MacBook Bluetooth
iPhone to MacBook screen mirror helping tool – AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror Top 4 Methods to Mirror iPhone to MacBook Bluetooth
Free yourself from the hassle of wires, and embrace wireless screen mirroring! In this article, we have discussed 3 apps to mirror iPhone to MacBook Bluetooth.
Joy Taylor | Last Updated: Nov. 07, 2023
1983 words|6minute
Mirroring your iPhone to your MacBook brings several incredible benefits and opens up a world of possibilities for users.
First and foremost, it’s all about convenience; you can mirror iPhone to MacBook Bluetooth to benefit from the larger screen.
Moreover, this feature is a game-changer in many scenarios. For instance:
Overview of Screen Mirroring iPhone
Screen mirroring is a great way to display the contents of one device’s screen on another, turning your PC screen into a mirror image of your smartphone.
However, today the topic in question is how to screen mirror iPhone to MacBook wirelessly; therefore, we will first discuss screen mirroring on iPhone.
Where is Screen Mirror on iPhone?
You can find the screen mirroring option in an iPhone in the Control Center. Swipe down from the top-right corner to open the Control Center, and tap the icon indicated by two boxes to enable screen mirroring.
If you’re mirroring an iPhone to another Apple device, the screen mirroring option will automatically enable the AirPlay feature.
So…
What is AirPlay and How Does it Work?
AirPlay is Apple’s wireless technology that connects your iPhone to other Apple devices like MacBooks or Apple TVs. It works by connecting both devices wirelessly via Wi-Fi. Therefore, your iPhone, Mac, or Apple device must be connected to the same Wi-Fi network for this feature to work.
However, here’s the catch! Not all iPhone and Mac models support AirPlay. So, if you want to mirror iPhone to MacBook, here’s a list of supported iPhone/Mac models or iOS/macOS versions:
With the basics sorted, let’s take you through the different methods and apps to mirror iPhone to MacBook Bluetooth.
Mirror iPhone to MacBook with Bluetooth – AirPlay
As we discussed earlier, Apple has a built-in feature AirPlay, that enables connecting iOS devices.
Here’s a detailed step-by-step guide on how to use the built-in AirPlay feature to mirror iPhone to MacBook:
Step 1. On your iPhone, swipe down from the top-right to open the Control Center and tap the Bluetooth icon to enable it.
Enable Bluetooth to Mirror iPhone to MacBook
Step 2. On your MacBook, go to Apple Menu > System Preferences > Bluetooth” and turn it on.
Turn On Bluetooth to Mirror iPhone to MacBook Bluetooth
Step 3. Open the Control Center on your iPhone, and tap the icon with two boxes to enable screen mirroring via AirPlay.
Enable Screen Mirroring to Mirror iPhone to MacBook Bluetooth
Step 4. Select your MacBook from the list of available devices.
Select MacBook from Available Devices to Mirror iPhone to MacBook
However, if you are unable to screen mirror iPhone to MacBook Bluetooth via AirPlay, you can try the following method.
Mirror iPhone to MacBook with Bluetooth – QuickTime
Another easy way how to screen mirror iPhone to MacBook wirelessly is by using QuickTime.
QuickTime is a multimedia framework and player developed by Apple Inc. It supports various audio, video, and image formats, for playing and viewing media content on iOS devices that are old and not supported by AirPlay. It is a popular choice for both Mac and Windows users and is included by default on most Apple devices.
Users can use QuickTime when they need to:
Steps to Mirror iPhone to MacBook via QuickTime
Follow these steps to mirror iPhone to Mac QuickTime:
Step 1. Enable Bluetooth on your iPhone and MacBook, and pair both devices.
Step 2. Launch QuickTime on your MacBook, and go to “File > New Movie Recording.”
Select New Movie Recording to Mirror iPhone to Mac QuickTime
Step 3. Next, select your iPhone from the list of available devices to initiate screen mirroring your iPhone to your MacBook.
And that’s how to mirror iPhone to MacBook Bluetooth using QuickTime.
In this section, we discussed Apple’s built-in features to mirror iPhone to MacBook. However, did you know that many third-party apps can help you mirror iPhone to MacBook?
Let’s have a look.
Mirror iPhone to MacBook with Bluetooth – AnyMiro
If you start searching, you’ll find hundreds of screen mirroring apps claiming to take your iPhone-to-MacBook mirroring experience to the next level. However, not all deliver their promises, which brings us to AnyMiro.
AnyMiro is a free screen mirroring app that enables you to mirror iPhone to MacBook Bluetooth. It provides an excellent 4k resolution screen mirroring quality, delivering crystal-clear visuals and seamless performance.
And the best part is AnyMiro lets you mirror your iPhone to your MacBook using a USB cable! This option can be a game-changer for those seeking a more stable connection, especially when Wi-Fi signals get a bit shaky.
How to Mirror iPhone to MacBook Bluetooth via AnyMiro
Follow these steps for a seamless iPhone-to-MacBook mirroring experience:
Step 1. Download and launch AnyMiro on your PC, and select the “iOS/iPadOS” tab from the interface.
Mirror iPhone to Computer
Select iOS/iPadOS to Mirror iPhone to MacBook
Step 2. Enable Bluetooth on your iPhone and Mac, and connect both devices to the same Wi-Fi network.
Step 3. On your iPhone, go to the Control Center > Screen Mirroring” and select “AnyMiro” from the list of available devices.
Select AnyMiro to Mirror iPhone to MacBook Bluetooth
And that’s about it! Your iPhone display will start mirroring on your MacBook for a convenient large-screen experience.
Why Recommend AnyMiro?
Here are some key features of AnyMiro that make it one of the best screen mirroring apps out there:
AnyMiro has flexible mirroring methods, as it supports wired and wireless screen mirroring.
With AnyMiro’s USB connection, you get up to 10 hours of uninterrupted mirroring with a fast response time of 10ms.
It offers a 4K resolution resulting in crystal-clear visual quality. Plus, it has an audio mirroring feature that also mirrors sounds from your iPhone.
AnyMiro’s audio-video sync feature keeps the audio and video in line and synced.
While AnyMiro is a great option for screen mirroring, it is not the only one available. Another popular option is LonelyScreen.
Mirror iPhone to MacBook with Bluetooth – LonelyScreen
LonelyScreen is a free and open-source screen mirroring tool that works with both Windows and Mac computers. It is a user-friendly and reliable screen mirroring solution that breaks free from device model limitations, ensuring compatibility with all iPhone models, and making sure everyone can join in on the mirroring fun!
How to Mirror iPhone to MacBook Wirelessly via LonelyScreen
To mirror iPhone to MacBook using LonelyScreen, here’s what to do:
Step 1. Download and install LonelyScreen on your MacBook.
Step 2. Once installed, you don’t need to run a setup, as LonelyScreen will run automatically.
Step 3. Enable screen mirroring on your iPad from the control center, and tap on “LonelyScreen” or the name you set.
Enable AirPlay to Mirror iPhone to MacBook
This will instantly share your iPhone’s screen on your MacBook, and you can continue from where you left off, but on a bigger and better display!
Now that you know 3 different ways how to mirror iPhone to MacBook wirelessly, let’s compare them and see who comes out on top!
AirPlay vs. AnyMiro vs LonelyScreen
AnyMiro   AirPlay LonelyScreen
Compatibility iOs, Android, Windows & Mac iOs & Mac iOS, Android, Windows, & Mac
Connection Method Wireless & USB Wireless Wireless
Price Free Trial Version
Pro: $15.99
Free Free Trial Version
Personal: $14.95/year
Business: $29.95/year
Ease of Use Easy to use, even for beginners Easy to use Easy to use but may require some tech experience
Our Recommendation?
After comparing AirPlay, AnyMiro, and LonelyScreen in terms of screen mirroring, we hands-down recommend AnyMiro!
It has a user-friendly interface and supports all platforms, including iOS, Android, Windows, and Mac. Moreover, it takes the lead as it supports Wi-Fi and USB connectivity.
Therefore, if you’re looking for the utmost convenience, stable connectivity, and high-quality visuals, AnyMiro it is!
FAQs About Mirroring iPhone to MacBook
1. Can I mirror my iPhone on my MacBook?
Yes, you can mirror your iPhone on your MacBook using the built-in AirPlay feature. However, it does come with device model limitations, which can hinder you from experiencing the true essence of mirroring. Therefore, we recommend using a third-party screen mirroring app like AnyMiro.
2. How do I mirror my iPhone wirelessly?
You can mirror your iPhone wirelessly by enabling Bluetooth on both devices and making sure they are connected to the same wireless network. Now, you can either use the built-in AirPlay feature or use an app like AnyMiro or LonelyScreen to mirror it.
3. Why can’t I AirPlay from iPhone to MacBook?
There could be several reasons for you to be unable to AirPlay from iPhone to MacBook. For instance:
There you have it, three different methods of how to mirror iPhone to MacBook Bluetooth!
And while mirroring your iPhone to MacBook via AirPlay or LonelyScreen seems easy, we cannot deny that AnyMiro can make screen mirroring a breeze. From supporting wired and wireless mirroring to offering 4k resolution video quality and 45 minutes of free screening every day, AnyMiro has got it all.
So, if you’re looking for top-notch quality and a visually stunning mirroring experience, AnyMiro is the way forward.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
