Mirror iPhone to Mac with USB
Break the barrier: mirror iPhone to Mac with USB via AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror Mirror iPhone to Mac with USB
Got to mirror iPhone to Mac? Discover the fastest way to mirror iPhone to Mac with USB to expand your view following the techniques provided in this article.
Joy Taylor | Last Updated: Nov. 07, 2023
1779 words|6minute
No doubt, Apple has one of the best smart devices worldwide. The interconnectivity of their mobile and computer systems is one of the greatest strengths the company has over others in the same industry. End-users can easily cast or mirror content from iPhone to Mac screen with minimal difficulty. Some of the content you can share include; photos, videos, gameplay, and live streams.
You can mirror your screen from iPhone to Mac via USB cable or WiFi. However, this article will focus on the USB cable approach. Read on as we share our comprehensive guide with you!
What You Need to Connect iPhone to Mac with USB
If you’re familiar with iOS and Mac, you might know that there is a built-in screen mirroring feature of Apple devices called AirPlay. Generally, when iPhone users want to cast the phone screens to a Mac, the first method they will think about is AirPlay. However, not all of the iOS and macOS support AirPlay. Only iPhones with iOS 14 or later and Macs with macOS Monterey or later can mirror each other’s screens using AirPlay. If you’re not sure whether your iPhone and Mac support AirPlay, you can check the following chart.
AirPlay System Requirement
If you don’t find your iPhone and Mac in the above chart and want to use a more stable screen mirroring method, you can try a wired connection, also known as a USB cable. However, there are important things you need to put in place for this to occur.
Some of the things needed include:
Once you have all of the above in place, you are one step from mirroring your iPhone to Mac. The next thing you’ve got to set is to get a professional mirroring app to mirror iPhone to Mac with USB.
Although there are several apps you can use, here are the trusted ones:
1. QuickTime Player
QuickTime Player is a system app established, and integrated by Apple into Mac devices to help stream videos. You can also use it for other activities such as taking screenshots, screen recordings, listening to audio recordings, and more.
This tool also comes in handy when you need to mirror iPhone to Mac via a USB connection. It offers a simple approach to casting iPhone screens on Mac, and it’s absolutely free to use. However, QuickTime Player isn’t without its limitations when it comes to mirroring iPhone to Mac.
QuickTime is no longer supported on the latest version of Mac OS, precisely macOS 10.15 Catalina or later. You can only use it to mirror on a Mac running on macOS 10.14 Mojave or older.
2. AnyMiro
AnyMiro is another incredible mirroring app to cast your mobile screen to PC/Mac via a USB cable. It’s the complete solution to mirror iPhone to Mac with a USB cable without hassles.
This mirroring app permits you to display content like pictures, videos, audio, etc., from your iPhone screen to your computer. Besides USB cable, AnyMiro also offers wireless connectivity to cast for you to mirror content from a smaller screen to a bigger surface.
3. LonelyScreen
Lastly, we’ve got LonelyScreen to mirror iPhone to Mac with USB. The app permits you to cast your iPhone screen on Mac without interruption. However, you need to be wary of bug attacks while using this app.
How to Mirror iPhone to Mac with USB
Having introduced the requirements to mirror iPhone to Mac with USB, let’s proceed to the how-to guide. Below we have the instructions for each of the screen mirroring applications mentioned above:
Method 1: Use QuickTime Player
Step 1. Connect your iPhone to a Mac computer with the appropriate USB cable. After that, launch the QuickTime Player app on the Mac computer.
QuickTime Player App
Step 2. Head to the top of the screen, and select File. A flyout menu will pop up with several buttons, and click New Movie Recording.
Click New Movie Recording on File Menu
Step 3. Next, tap on the drop-down menu Best the Red circular icon. The response page down here will come up:
Response Page With Your iPhone Name
Locate and click on your iPhone name. Screen mirroring will commence immediately, and everything on your iPhone screen will come up on Mac.
Method 2: Use AnyMiro
Step 1. Download and run AnyMiro on your Mac.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to the Mac with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Method 3: Use LonelyScreen
LonelyScreen is also a screen mirroring app for iPhone and iPad. However, the working mechanism of  LonelyScreen is different from that of AnyMiro. Once installed LonelyScreen and finished the setup process, you can turn your Mac into an AirPlay receiver, even if your Mac model doesn’t support AirPlay. Here are the steps of how to mirror iPhone to Mac via USB using LonelyScreen.
Step 1. Get the latest version of LonelyScreen installed on your Mac computer system. To do that, kindly visit the official website for LonelyScreen and click on the appropriate buttons.
Step 2. Connect your Mac computer and iPhone via a USB cable. After that, navigate to the Settings tab on your iPhone and click on Personal Hotspot.
Toggle the Personal Hotspot Icon to Turn It on
Step 3. Now connect your Mac computer to the Personal Hotspot via WiFi. Once done, allow your Mac computer to access LonelyScreen through the firewall.
Step 4. Open the Control Center on your iPhone by swiping down from the upper left corner of your screen (if you use iPhone X or later), or from the bottom of your screen (if you use iPhone 8 or older model).
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Step 5. Wait for your iPhone to scan for nearby devices. Once your Mac computer appears, click on it and start mirroring your screen.
Start Mirroring
Start Mirroring
Why AnyMiro the Best to Mirror iPhone to Mac
Of all the three apps introduced in the article, AnyMiro is the best and most outstanding. We’ve selected this mirroring app to mirror iPhone to Mac with USB for the following reasons:
AnyMiro isn’t limited to mirroring iPhone to Mac. You can also use it to expand your view from your Android, or iPad to a Windows computer system without limitations. Thus, we can describe it as an all-in-one screen mirroring solution.
While mirroring content from iPhone to Mac via AnyMiro, you get the best video and audio quality. It provides up to 4k resolution and promises to reproduce the best color accuracy/.
AnyMiro comes with a simple and clear user interface, you can easily handle this tool without a training process.
If you want to live stream a mobile game playing on YouTube or Twitch, you can also use AnyMiro to help. With it, you can mirror your iPhone screen to the computer, and then use live streaming tools like OBS to detect the mirrored screen to stream mobile games to PC.
Bonus Tip: Mirror iPhone to Mac Wirelessly
You can also connect your iPhone to Mac for screen sharing via a wireless connection. This can be achieved via the native feature, AirPlay. AirPlay lets you link your iPhone to Mac wirelessly via WiFi, so you can expand your view and enjoy whatever content you are casting on a larger screen.
The procedure required isn’t lengthy. Here’s the quick guide you need to follow to mirror iPhone to Mac wirelessly:
Step 1: Connect both your iPhone and Mac to the same WiFi network, then get ready to share your screen.
Step 2: Navigate to the Control Center panel on your iPhone. You can do that by swiping from the upper right corner of your screen (for iPhone X or later), or swiping from the bottom of your screen (iPhone 8 or older generation).
Step 3: Click on the AirPlay tab to search for a nearby Mac computer. Once your Mac is detected, the name will pop up on your iPhone. Click on the name to establish a connection.
Step 4: Now enter the AirPlay passcode if requested and start mirroring iPhone to Mac in no time.
Mirroring your iPhone to Mac screen is one of the best ways to enjoy your video and audio content without interruption on a larger screen. You can do this either via USB or wireless connection. Both approaches have been described in the article. Kindly choose the one that suits you. However, we choose and recommend the AnyMiro app to mirror iPhone to Mac with USB. The app casts your iPhone to Mac without issues.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
