Getting content from your iPhone onto an Android Tablet via mirroring is hassle-free. Apart from easily mirroring to a PC or Mac through AnyMiro, it is fabulous that we get to show you some easy ways to mirror your iPhone onto an Android tablet using apps like AirScreen and Mirroring360. Let’s get started!
Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
Suppose you have an Android tablet nearby and want to share pictures or videos from your iPhone. The good news is that you can mirror iPhone to Android Tablet! Apps like Mirroring360 and AirScreen make mirroring your iPhone to an Android tablet simpler. These apps facilitate screen sharing by bridging the gap between Android and iPhone devices. Also, you will learn how you can employ AnyMiro to mirror your iPhone to a Mac or PC. Let’s make sharing your screen simple and smooth!
Here are the methods you can use to mirror iPhone on Android Tablet:
AirScreen lets you connect your iPhone and Android tablet and display content on a larger screen. Your devices must have the same WLAN; you can wirelessly stream or share information from your iPhone. AirScreen also has high-quality streaming; hence, mirroring images or movies will provide you with clear pictures and smooth playback. It also has encryption for privacy protection, which keeps your data safe. Most customers find AirScreen accessible and simple to set up, and it works with Android devices running OS 4.2 or later.
Key Features
To use AirScreen:
Pre-requisites:
Mirror iPhone to Android Tablet Using AirScreen:
Step 1. Open the AirScreen app on your Android tablet and set it up to receive a screen mirror.
Step 2. Swipe on your iPhone to open the Control Center and choose “Screen Mirroring.”
Select Screen Mirroring
Step 3. Select your Android tablet from the list of available devices for mirroring.
Choose a Device
Step 4. To mirror a specific video, tap the “Share” button on the video, then select “AirPlay.”
Step 5. When you see the AirPlayicon in any app, tap it to instantly mirror the content from your iPhone to your Android tablet.
Select AirPlay Icon
It is possible to mirror your iPhone screen to an Android tablet using Mirroring360. This program is not limited to presentations but also includes seamless device-to-device media sharing. Users consider it convenient because it works without any cables.
Additionally, Mirroring360 supports various devices, so linking iPhones, Android phones, and tablets is quite easy. It also has screen-sharing features that let users share content with others. Ensure to connect both devices to the same Wi-Fi network for seamless screen mirroring. It also allows you to record the screen while mirroring to save content for later use. For this method:
Mirroring360 Official Website
Key Features
Pre-requisites:
Mirror iPhone to Android TabletUsingMirroring360:
Step 1. Once both apps are installed, open the Mirroring360 sender app on your iPhone.
Step 2. Swipe to open the Control Center and click “Screen Mirroring.”
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Step 3. Choose your Android tablet’s name from the available devices list to start mirroring your iPhone screen to the tablet.
AnyMiro is a flexible program that makes it simple to mirror your iPhone’s screen to a Mac or PC. It ensures the mirrored screen appears clear and colorful, supporting up to 4K resolution for a more precise image. It is also ideal for game players and video content creators since it contains an audiovisual sync, showing low latency. Thus, gaming or live streaming will not be disrupted in any way.
Depending on your platforms, you can stream your phone for free on other websites, such as Twitch and YouTube. The real-time annotation tool also allows interactive streaming, which is perfect for teaching or presentations. AnyMiro’s ease of use and color accuracy make it the go-to choice for mirroring your iPhone to a PC or Mac.
Key Features:
Now, let’s explore simple steps to mirror iPhone to PC & Mac:
Step 1. Begin by free downloading and installing AnyMiro on your computer. Open the AnyMiro app and select “iOS/iPadOS.”
Mirror iPhone to Computer
Step 2. Next, click on the option for “USB connection.” Connect your iPhone to the computer using a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 3. Tap “Trust” on your iPhone to allow the connection.
Trust Your Computer on iPhone
Step 4. If prompted, enter your passcode. Your device will now be ready for seamless screen mirroring.
Step 1. Launch the AnyMiro app on your computer and select “iOS/iPadOS.”
Step 2. Click the option for “Wi-Fi connection.”
Step 3. Check that all devices have the same Wi-Fi network.
Step 4. Open the Control Center on your iPhone or iPad, tap “Screen Mirroring,” and choose “AnyMiro_Computer Name.”
Step 5. Once your device is detected, enjoy high-quality screen mirroring instantly!
Why isn’t my iPhone mirrored on my Android tablet?
If your iPhone isn’t mirroring, check that all devices have the same Wi-Fi network. Additionally, ensure the necessary program is loaded and set up properly on both devices for screen sharing.
Will screen mirroring impact the performance of my phone?
The performance of your iPhone shouldn’t be greatly impacted by screen mirroring. However, if you’re streaming HD movies or using many apps, you may experience lag or a lower battery life. Make sure your Wi-Fi connection is consistent to maximize its benefits.
Is AnyMiro the best option for mirroring my iPhone to a PC or Mac?
AnyMiro is one of the best options for seamless and hassle-free mirroring. It offers a stable connection through USB or Wi-Fi, ensuring minimal lag during video streaming or presentations. We highly recommend AnyMiro for smooth and high-quality screen sharing.
Several methods for mirroring your iPhone screen to an Android tablet were covered in this guide. We reviewed how to use basic and user-friendly applications like AirScreen and Mirroring360. To begin mirroring, these methods require installing apps on both devices, connecting them to the same Wi-Fi network, and following a few instructions. AnyMiro is our top pick for the greatest iPhone-to-PC or Mac screen mirroring experience. It offers smooth, high-quality mirroring with USB and Wi-Fi connection options, making it an excellent choice for reliable screen sharing.
