Screen mirroring iPad to PC via USB using AnyMiro
Available for both Win & Mac
Whether you want to mirror iPad to PC via USB, wirelessly, with or without software, we have put together 3 different ways to do so. Each method is explained in detail with step-by-step instructions for your better understanding.
Have you ever studied for an exam while flipping through study material? It’s quite a task to go back and forth while taking notes. Wouldn’t it be better if all your documents and research material were displayed on your PC while you use your iPad to take notes?
It’ll give you a spacious workspace, enhance your productivity, and minimize the need to switch between apps and devices.
Sounds good? It’s possible if you mirror your iPad to a PC via USB! If you’re eager to learn more about the process and discover how to make the most of this powerful feature, keep reading this article.
How to Mirror iPad to PC with USB
Yes, it is possible to mirror iPad to PC via USB. However, the process may differ for Windows and Mac PCs.
For Windows
As iOS is incompatible with Windows, you’ll need a USB-C lightning cable to connect both devices. However, in addition to a USB cable, you will also require a third-party screen mirroring app, like AnyMiro, to act as a platform enabling connectivity between your iPad and PC.
For Mac
As far as Mac users are concerned, you can easily mirror iPad to PC for free via the AirPlay feature. This feature allows you to wirelessly mirror your iPad to PC without getting tangled in a wirey mess!
With that sorted, let’s look at the 3 methods to mirror iPad to PC via USB, wirelessly, and without using any software.
If you’re looking for a simple and easy way how to mirror iPad to Windows 10, we recommend using AnyMiro.
AnyMiro is a screen mirroring app that enables screen mirroring iPhone and iPad to PC using a USB and wirelessly. We have put this amazing tool on our recommendation list for several reasons:
Even though AnyMiro has limited features, it provides top-notch visual quality and advanced features, making it a good choice to mirror iPad to PC free.
Here’s how to mirror iPad to Windows 10 using AnyMiro:
Step 1. Download and launch AnyMiro on your PC, and select the “iOS/iPadOS” option from the interface.
Mirror iPad to Computer
Step 2. Connect your iPad to your PC using a lightning cable and select “USB” from the options on the left.
Mirror iOS Device to Computer via USB
Step 3. Once the PC recognizes your iPad, you will receive a pop-up on your device whether you trust the computer. Tap “Trust” to continue.
Trust Your Computer
And that’s about it! You can now see your iPad’s screen on your PC.
Features of AnyMiro
We’re sure you’re wondering why we are emphasizing so much on AnyMiro. Why shouldn’t we? It’s not every day you find a free screen mirroring app with so much to offer!
Here are some features of AnyMiro to help you understand its versatility:
Now that you know all there is to know to mirror iPad to PC via USB using AnyMiro, let’s take you through the steps to mirror iPad to PC free wirelessly.
We all know about Apple’s AirPlay feature that allows screen mirroring iPhone or iPad to other Apple devices, like Apple TV or Mac. However, did you know you can also use this feature on your Windows PC?
It’s pretty simple! You just need to:
However, if this method does not work for some reason, you can mirror iPad to PC free wirelessly using LonelyScreen!
LonelyScreen is a screen mirroring app that enables screen mirroring iPhone and iPad to your PC wirelessly. It has a hassle-free installation process, which, combined with its user-friendly interface, makes it a good option for new and seasoned users.
You can turn your Windows PC into an AirPlay receiver with LonelyScreen in 3 easy steps:
Step 1. Download and install LonelyScreen on your Windows PC.
Download and Install LonelyScreen
Step 2. Once installed, you don’t need to run a setup. The app with run automatically, indicated by a pop-up screen, from where you can change the name of the receiver.
Step 3. Enable screen mirroring on your iPad from the control center, and tap on “LonelyScreen” or the name you set.
And that’s it! Your iPad screen will be cast on your PC instantly.
Now, if you don’t want to get into the hassle of using USB cables or downloading any third-party apps, you can still mirror iPad to PC free without software.
Many users want to mirror their iPhone or iPad directly to their PC without going through the fatigue of downloading apps. Well, that’s possible, but only for Mac!
You see, all Apple devices can be wirelessly connected to each other via Apple’s built-in AirPlay feature.
Here’s how to go about it:
Step 1. Connect your iPad and Mac to the same Wi-Fi network.
Step 2. Open the control center on your iPad, and tap the “Screen Mirroring” option.
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Step 3. Select your Mac from the list of available devices to start the screen mirroring process.
And that’s how you mirror iPad to PC free using AirPlay!
Now let’s answer some common queries on how to mirror iPad to PC via USB.
1. Can you screen mirror through USB?
Yes, you can screen mirror iPad to PC via USB. It provides a more stable and smooth screen mirroring experience. However, you’ll need a third-party app like AnyMiro to act as a hub that connects both devices.
2. Do you need WiFi for screen mirroring?
You don’t need a Wi-Fi network for screen mirroring via a USB connection. But, if you’re screencasting wirelessly, Wi-Fi is necessary, as both devices must be connected to the same Wi-Fi network for the screen mirroring process to work.
3. How can I mirror my iPad to my computer without WiFi?
If you want to mirror your iPad to your computer without Wi-Fi, you can do so via USB. Connect your iPad to your PC using a compatible USB cable, download a screen mirroring app like AnyMiro, and you’re all set to screen mirror iPad to PC free.
4. How do I use AirPlay on Windows?
AirPlay is an iOS/macOS-only screen mirroring feature. You can’t apply AirPlay for Windows directly. However, some third-party screen mirroring tools can work like an AirPlay receiver for you to AirPlay your iPhone or iPad to a Windows computer.
Whether you want to mirror your iPad to PC via USB or wirelessly, AnyMiro is the best choice! Why? Because it’s free, has a user-friendly interface, and is great for beginners. Plus, with its audio syncing feature, you never have to worry about mismatched audio and video.
So, what are you waiting for? Download AnyMiro now and take your screen mirroring experience to the next level!
