How to Mirror Broken Screen Android to Mac
Have a try on a handy screen mirroring tool – AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror How to Mirror Broken Screen Android to Mac
A cracked smartphone screen is one of the most common issues. However, even if you are not able to use it, you can still mirror it! In this guide, we have discussed 2 ways in which you can mirror broken screen Android to Mac.
Joy Taylor | Last Updated: Sep. 24, 2024
1677 words|5minute
Have you ever experienced an Android device with a damaged screen? It can be frustrating and limiting when you can’t access your device’s content. But don’t worry! Screen mirroring from your Android device to a Mac can be a lifesaver.
With this feature, you can access your device’s content on a larger, functional Mac screen despite the physical limitations of your phone or tablet. Even if your screen is completely shattered or partially unresponsive, we have got you covered.
In this guide, we will walk you through the steps required to mirror broken screen Android to Mac.
Why Need to Mirror A Broken Android Screen to Mac?
There could be several reasons for you to use broken phone on PC. For instance:
Is It Possible to Mirror a Broken Android Screen to Mac?
Yes, it is possible to mirror a broken Android screen to a Mac. There are a number of different ways to do this, but the most common is to use a third-party screen mirroring app.
However, as Android and Mac are not compatible with each other, you might face several issues when attempting to mirror broken screen Android to Mac.
Some common issues include:
Now that you know why you may need to use broken phone on PC and what issues you might have to face, let’s see how we can mirror broken screen Android to Mac.
Fix Here: Mirror Broken Android Screen to Mac
If you want to mirror your broken Android screen to a Mac, the very first solution is to use AirDroid Cast.
AirDroid is an easy and efficient way to manage your Android device. With this amazing tool, you can control your Android device remotely and even mirror its screen on your Mac. This comes in handy, especially when your phone’s screen is unresponsive or broken.
In short, AirDroid is a must-have for anyone who wants to cast their broken Android screen on a Mac without any compatibility or connectivity issues.
Steps to Mirror Broken Screen Android to Mac
Below is a step-by-step guide on how to mirror a broken Android screen to your Mac using AirDroid:
Step 1. Download and install AirDroid on your Mac, and log in to your AirDroid account to start using the app.
Sign in with Your AirDroid Credentials
Step 2. Connect your Android device to your Mac using a USB cable. You will get a notification on your device to enable USB Debugging. Tap “OK” to allow it.
Choose the USB Mode in AirDroid Cast
Step 3. Once the connection is in place, AirDroid will detect your device. Select the “Cable” option and your Android device from the list of available devices.
And that is all you need to do for quick and seamless screen mirroring from your Android to Mac.
However, if you are looking for a tool that enables casting your Android screen to your Mac with high-quality visuals and no interruptions, we have a better solution for you!
Recommendation: Stable & Lag-Free Screen Mirror Tool – AnyMiro
While AirDroid does a reasonable job in mirroring Android screens to Mac, our recommendation is iMobie AnyMiro.
Why? Because AnyMiro is an amazing screen mirroring tool that allows you to easily connect and interact with your Android device on your Mac. One of the things that sets it apart is its outstanding screen mirroring quality, which provides a seamless and immersive screen mirroring experience for users.
AnyMiro – Real-Time Screen Mirroring Tool
  • More than 10 hours of stable screen mirroring connection.
  • Up to 4K resolution providing a stunning visual experience.
  • Integrates with live streaming tools such as OBS and Streamlabs.
  • Auto-sync video and background audio with timestamp adjustments.
100% Clean & Safe
100% Clean & Safe
Main Features of AnyMiro
Why are we so intent on suggesting AnyMiro for screen mirroring Android to Mac? Because it has some amazing features that make it stand out from other apps:
And that is what AnyMiro is all about!
How to Mirror Android Screen to Your Mac via AnyMiro
Step 1. Download both the AnyMiro software and the mobile app, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, the guide at the beginning of this article tells you what to do.
Allow USB Debugging on Your Phone
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your Mac.
Mirror Android to Computer via USB
Let’s enjoy the seamless and feature-rich experience of mirroring your Android screen to your Mac with AnyMiro!
It can be quite frustrating when your Android screen cracks, making it difficult to use it. However, there is no need to worry! Till the time you get a new device, you can screen mirror broken screen from Android to Mac.
In this article, we have discussed 2 renowned screen mirroring apps, AirDroid and AnyMiro. And while both of them offer quick and easy screen mirroring features, we hands-down recommend AnyMiro.
Because, it is a powerful screen mirroring tool that offers high-quality screen mirroring, fast response time, seamless sync of visuals and sound, and compatibility with live streaming tools.
So, whether you are into gaming or simply need to mirror Android to Mac, AnyMiro delivers top-notch quality, responsiveness, and compatibility. It is the ultimate choice for mirroring your Android device to your Mac!
Joy Taylor
