Learn how to mirror your Android device to a PC without Wi-Fi using a USB connection. Discover the recommended apps like AnyMiro for stable and lag-free screen mirroring. Enjoy high-quality resolution and seamless experience with these reliable solutions.
Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Nowadays, having the ability to mirror an Android device’s screen to a PC can be incredibly useful. Whether you want to view content on a larger screen, share your screen with others, or simply enjoy a more immersive experience, mirroring your Android to a PC can provide added convenience.
Wi-Fi connection is a convenient and popular method to help mirror your Android device to a compatible computer. However, what if you don’t have access to a Wi-Fi network? Is it still possible to mirror your Android device to a PC? The answer is yes, and you can cast your Android phone screen to your computer with a USB cable. In this article, we will explore 3 best ways to achieve this.
YES, it is indeed possible to mirror your Android device to a PC without a Wi-Fi connection: by using a USB cable.
USB connection is a reliable and secure method that offers a stable connection for screen mirroring. The direct wired connection minimizes the chances of disruptions or lags during the mirroring process, resulting in a smoother casting experience.
Mirror Android to PC with USB
There are several advantages of the USB connection:
The advantages of the USB connection make it a reliable choice for users. Let’s see how to mirror Android to PC via USB.
One of the best apps that allows you to mirror your Android screen to a PC without Wi-Fi is AnyMiro. With AnyMiro, you can seamlessly share the display of your Android device on a larger screen, providing a convenient way to present content, play games, browse the internet, or showcase apps to a wider audience.
Here are key features of AnyMiro:
Now you may want to know how to mirror Android to PC via USB. To get started, follow these steps:
Step 1. Download both the AnyMiro software and the mobile app.
Step 2. Run AnyMiro and enter the Android mirroring path.
Mirror Android to Computer
Step 3. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro that tells you how.
Allow USB Debugging on Your Phone
Step 4. Then open the AnyMiro app on your phone and tap Start in USB connection. Wait a few seconds, AnyMiro will automatically detect your Android device, and you can now mirror your Android screen to your PC.
Enable USB Debugging and MTP Mode for a USB Connection
Vysor is another screen mirroring app that doesn’t require Wi-Fi. It offers a user-friendly interface and delivers fast display responsiveness. With Vysor, you can easily mirror your Android screen onto your PC, granting you the convenience of using various apps, capturing screenshots, and even playing games seamlessly on a larger screen.
Here’s how to mirror Android to PC with Vysor:
Step 1. Download Vysor onto your PC and connect your Android device to your PC using a USB cable.
Step 2. Once the devices are connected, you may receive a USB debugging prompt on your mobile device. Grant permission for USB debugging, and then open the Vysor installer file on your PC.
Step 3. After getting a notification from the software, click on the ‘View’ tab within the Vysor interface to start the mirroring process. Then you can enjoy mirroring your Android screen on your PC.
Vysor Interface
ApowerMirror is a brilliant application that lets you mirror Android to PC without Wi-Fi. You may follow these steps to get started:
Step 1. Start by downloading and installing the ApowerMirror application on both your Windows computer and Android device.
Step 2. Access the developer options on your Android device and enable USB debugging. This will allow the necessary permissions for the screen mirroring process.
Step 3. Connect your Android device to your PC using a USB cable. When prompted, allow the USB debugging prompt on your Android device to establish the connection between the two devices.
Step 4. Open the ApowerMirror app and tap on the “START NOW” option to grant the necessary permission to capture the screen and initiate the screen mirroring process.
ApowerMirror Sharing Android Screen to PC
By following these steps, you can easily set up and initiate screen mirroring with ApowerMirror, ensuring a seamless connection between your computer and Android device.
1. Does screen mirroring use Bluetooth?
While Bluetooth is a popular method for wireless connectivity, it is not used for screen mirroring. Instead, screen mirroring typically uses either WiFi or a wired connection.
2. Are there any limitations to mirroring without Wi-Fi?
While mirroring without Wi-Fi is possible, it’s important to note that it requires a physical USB connection between your phone device and PC. Additionally, some apps may have limitations on specific features or may not be compatible with all devices.
3. What should I do if the mirroring connection is unstable?
If you experience an unstable mirroring connection, ensure that you are using a high-quality USB cable or check your Wi-Fi network. Additionally, restarting both your Android device and PC can sometimes resolve connectivity issues.
Mirroring an Android device to a PC without Wi-Fi is indeed possible through a USB connection, which provides a stable and reliable connection for users. Powerful screen mirroring apps like AnyMiro will offer easy setup, stable screen mirroring, 4K resolution, and no lagging experience. So, go ahead and give these apps a try, and enjoy a seamless mirroring experience even without a Wi-Fi network!
