A Complete Guide on How to Mirror Android to PC with Sound
Try the Android screen mirror tool – AnyMiro to mirror with sound.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror A Complete Guide on How to Mirror Android to PC with Sound
Experience screen mirroring like never before with AnyMiro! Learn how to mirror Android to PC with sound from our step-by-step guide.
Joy Taylor | Last Updated: Aug. 21, 2024
1454 words|5minute
Are you looking for a way to enhance your mirroring experience? Do you want to mirror your content with sound? If yes, then this guide is for you! In today’s digital world, smartphones are a big source of entertainment. However, the small screen doesn’t do justice sometimes. That’s where screen mirroring comes in!
But it’s not just about watching something or playing games on a bigger screen; it’s about feeling every moment. With sound, you can make your mirroring experience even better. This article will explore how to mirror Android to PC with sound. We will also walk you through a complete step-by-step guide to make it happen.
Let’s get started!
Does Screen Mirroring Transmit Audio?
As the name suggests, screen mirroring replicates your mobile device’s screen on another display. However, the question that comes to mind is if it also transmits the sound. Well, it depends upon the tool and device you are using. Let’s break it down for you!
Mirroring to a TV:
When you mirror your phone’s display on a TV, like a Smart TV or a device like Chromecast, you can hear the sound, too. Developers understood that there is not enough use of mirroring without sound. Therefore, they incorporated the sound feature as well.
Now, most new TVs can send both the video and the sound from your phone. There is no need to perform extra steps to mirror Android to TV with sound. So, when you watch a video, play music, or do anything with sound on your phone, it should also come out of the TV.
Screen Mirroring Android to a TV
Mirroring to a Computer:
Now, let’s talk about mirroring to a computer. This is where things can vary depending on your setup. If you’re using a screen mirroring app, like AnyMiro, it may automatically mirror the audio. You don’t need to do anything extra to mirror Android to PC with sound.
Some apps also offer the option to choose whether you want the audio to play on your computer or stay on your phone. So, yes, you can transmit audio during screen mirroring to a computer. However, you should configure it according to your preferences.
Screen Mirroring Android to a Computer
Now that we know it is possible to Mirror Android to PC with sound, let’s see how to do it!
Mirror Android to PC with Sound: The Best Screen Mirror App
When it comes to mirroring Android to PC with sound, one name stands out: “AnyMiro.” It goes beyond the ordinary by turning your Android and PC into a dynamic duo. It is the perfect fusion of visuals and sound, ensuring you don’t miss a pixel, beat, or moment. With AnyMiro, you can take your mirroring experience to new heights by getting the best of both worlds.
However, the magic of AnyMiro doesn’t end here. It comes with several other benefits. It allows you to mirror any app of your Android/iOS to PC/Mac without limitations. Moreover, you don’t need to perform complex steps to set up AnyMiro for screen mirroring. Just a few clicks and it is done. Let’s shed some light on a few other features of AnyMiro:
Key Features of AnyMiro
The key features of AnyMiro that make it stand out are as follows:
These amazing features surely got you excited, and now you might be wondering how to use AnyMiro. Let’s see how to use AnyMrio to mirror Android to PC with sound.
Steps to Mirror Android to PC using AnyMiro (Via USB)
Here is how you can mirror Android to PC with sound using AnyMiro:
Step 1. First, Download and install AnyMiro’s Software on your PC.
Step 2. Then, launch the AnyMiro Software. On the homepage, select Android as your mobile type.
Mirror Android to Computer
Step 3. Now, select USB as a connection mode, then connect your Android to your PC via a USB cable.
Mirror Android to Computer via USB
Step 4. After you plug in the USB cable, enable USB debugging and select the MTP mode.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Download the AnyMiro app on your Android, then tap the USB connection.
Select the Connection Method
Once your Android device is connected, you will see its screen displayed on your PC. Also, the sound of your mobile content will be automatically mirrored to your PC with AnyMiro.
Let’s explore something more you need to know about screen mirroring.
You May Want to Know More
What is the free mirroring app for Android to PC with audio?
If you are on the hunt for an app for screen mirroring with audio Windows 10, then AnyMiro is the solution! It is a powerful tool with everything that you need to enhance your mirroring experience. It is available for both Mac and Windows.
You can download the free version of AnyMiro to enjoy your mirroring. It supports popular streaming tools. You can use both Wi-Fi and USB as connection modes. However, the free version may have some limitations, such as a watermark and mirroring duration.
How can I record Android screen with audio?
Now, most of the Android phones have a built-in feature for screen recording. The method of doing so is also the same across most of the devices. You can follow the below steps to screen Android phone screen with audio:
  1. Unlock your Android phone.
  2. Swipe down the notification bar and find Screen Recorder or a similar button.
  3. Tap on Screen Recorder and allow permission to record the screen.
  4. You will be asked if you want to record with or without sound.
  5. Select as per your preference, and a countdown of the recording will start.
Screen Recording on Android
However, if you don’t have a Screen Recorder button or a similar option, you can try another way. There are various screen recording apps available. Just install the one with the best ratings from Google Play and record your phone’s screen with audio.
Screen mirroring is not only about convenience. It’s about enhancing your digital experience. We hope this article has helped you to learn how to mirror Android to PC with sound. With the help of the right tool and knowledge, you can easily mirror Android to PC to enjoy your content on a bigger display.
While various screen mirroring apps are available, they can be complex to set up. Therefore, we recommend using AnyMiro! It is a user-friendly and reliable solution for screen mirroring. You don’t need to be a tech expert to use AnyMiro.
So, download AnyMiro today for a bigger, better, and uninterrupted mirroring experience.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
