Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Unlock the Magic to miscast iPhone to PC. Discover tools like LonelyScreen and AnyMiro. Turn your iPhone into a big screen experience on your PC. Learn how now!
Have you ever wanted to miracast iPhone to PC? Imagine if your iPhone screen could jump right onto your PC! Sounds exciting, doesn’t it? But can my iPhone do that? You might be thinking. With a bit of tech magic and a pinch of know-how, yes, it can!
We’re going on a fun journey with tools like LonelyScreen and the new one AnyMiro. So are you ready to turn your tech world upside down? Buckle up, and let’s get your iPhone on the big PC screen!
Miracast allows you to show multimedia wirelessly. It’s like a wireless cable. So, it helps you show what’s on one screen (source screen) to another (display screen). Many Android phones and Windows computers use this technology.
But, here, the question must arise: does iPhone use Miracast?
No, it doesn’t. Instead, iPhones use a different system called AirPlay. It lets you show what’s on your iPhone/iPad on devices that can work with AirPlay, like Apple TV.
You might be confused about “Can an iPhone screen mirror to PC?”
Yes, but not directly. iPhones can’t use AirPlay to show their screen on a Windows computer. However, other apps can help.
Getting interesting? Let’s have a look at that other alternative.
If you’re wondering what are the ways to miracast iPhone to PC, this part will answer your question.
There are several ways to mirror the screen of your iPhone onto another device. These include third-party applications and some hardware solutions. These options bridge the gap for how to miracast iPhone to laptop and allow iPhone users to mirror their screens onto other devices.
One of the handy iPhone screen mirroring tools recommended here is AnyMiro, it is designed for both iPhone and Android users to miracast the phone screen to a computer. Let’s take a further step to check what you can get from AnyMiro.
Now that you know what you can get from AnyMiro. If you’re ready, click the download button here to get AnyMiro. Then follow the steps here to see how to miracast iPhone to PC with AnyMiro.
AnyMiro supports both USB mirroring and wireless screen mirroring with WiFi. Here we will take the mirroring with USB connection as an example.
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
That’s it, with only three simple steps, you can miracast iPhone to PC successfully. Now, whether you want to play games on a bigger screen or stream your iPhone content to YouTube/Twitch, you can go one step further.
Apart from AnyMiro, there are many other iPhone miracast tools you can rely on, one such tool is LonelyScreen. LonelyScreen is software that can turn your PC into an AirPlay receiver. This means it allows your PC to bypass Apple’s restriction and receive AirPlay signals from an iPhone, thus enabling screen mirroring from iPhone to PC. Keep reading and see how to mirror iPhone to PC with LonelyScreen.
Step By Step Guide to Using LonelyScreen
Step 1. Download and Install LonelyScreen on your PC.
Step 2. Connect both iPhone and PC to the same WiFi connection.
Step 3. Go to the settings on your phone and turn on the “screen mirror.”
Go to the “Screen Mirror” Option on your iPhone
Step 4. Hold and long press the Screen Mirror button until it shows all the available devices. Now click on LonelyScreen.
Click on “LonelyScreen”
Step 5. Now, you will see your iPhone screen on your PC.
Let’s keep the momentum going and discuss more on how to miracast iPhone to PC.
Screen mirroring can be a handy feature. However, as with all technology, there may be some security concerns. Let’s discuss this and then look at some tips for keeping your data safe while using screen mirroring apps.
The following are some potential security concerns during miracast iPhone to PC.
The following tips can help you to miracast iPhone to PCsafely.
In conclusion, you can’t directly miracast iPhone to PC. But with third-party apps like AnyMiro and LonelyScreen, it’s possible to satisfy your needs. AnyMiro is a light and easy-to-use screen mirroring tool that works for both Windows and Mac users. Download it and have a try now!
Free download AnyMiro to miracast your iPhone screen to a Windows PC
