A Comprehensive Guide to Live Stream Mobile Legends on PC
Mirror mobile game to PC first with AnyMiro for live streaming
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror A Comprehensive Guide to Live Stream Mobile Legends on PC
Indulge in the intense battle with your enemies on Mobile Legends Bang Bang! And if you want to show the world your strength and let everyone see your victory, you can always live stream your gaming session. In this article, we will tell you everything there is to know about how to live stream Mobile Legends on PC.
Joy Taylor | Last Updated: Nov. 07, 2023
1629 words|5minute
Welcome to the chaotic battlegrounds of Mobile Legends: Bang Bang! Where heroes clash, epic spells are cast, and friendships are forged in the heat of battle.
But playing such an intense battle on your mobile screen can get a bit boring at times. This calls for taking your gaming experience up a notch to your PC screen!
But here’s the catch: Mobile Legends is a mobile-based game! So, if you want to play it on a bigger screen or stream your battle, you will have to mirror your phone to your PC. And this is where we come to the rescue!
In this article, we will take you through the steps of how to live stream Mobile Legends on PC, complete with tips to create the perfect setup!
Can I Stream MLBB on a Computer?
Yes, you can stream MLBB on your computer by mirroring your mobile screen to the computer. Once your phone starts mirroring to your PC, you can use any streaming software, like OBS, to stream MLBB to YouTube, Twitch, or Discord.
How to Live Stream Mobile Legends on PC?
As mentioned earlier, if you want to livestream Mobile Legends on PC, you’ll have to go through two steps. The first step is to mirror your phone to your PC, and the second step is streaming your gameplay to YouTube or any other platform using streaming software.
Let us have a look at the details of both the processes, complete with step-by-step instructions. With these two introduced processes, you can set up any mobile game streaming with no hassle.
Step 1: Screen Mirror Mobile Legends on PC
Whether you’re playing Mobile Legends on Android or iPhone, you will have to mirror it to your PC if you want to live stream it to online platforms.
And, if you’re looking for a seamless way to stream your mobile gaming adventures on your computer, look no further than AnyMiro, the ultimate screen mirroring tool designed to elevate your streaming experience.
With AnyMiro, you can effortlessly mirror your mobile’s screen to your computer and unlock a world of possibilities for streaming Mobile Legends: Bang Bang.
Why Use AnyMiro?
With so many screen mirroring tools available in the market, why should you choose AnyMiro as your go-to choice?
Here is why:
Steps to Screen Mirror Mobile Legends to PC Using AnyMiro
Here’s how to screen mirror Mobile Legends from your phone to your PC in 3 simple steps:
Step 1. Download and install AnyMiro on your PC, and select “Android” from the interface.
Mirror Android to Computer
Step 2. Now connect your Android device to your PC using a USB cable, and click on “USB” from the menu on the left.
Mirror Android to Computer via USB
Step 3. You will get a notification on your device asking to allow USB Debugging. Tap “Allow” to continue.
Enable USB Debugging and MTP Mode for a USB Connection
Step 4. Once you enable USB Debugging, tap USB connection on the AnyMiro app, and your Android screen will start mirroring on your PC.
Select the Connection Method
Now that you have successfully completed the first step to live stream Mobile Legends to PC. Let’s move on to the final step: How to stream Mobile Legends on YouTube and other streaming platforms.
Step 2: Live Stream Set Up for Mobile Legends
Screen mirroring Mobile Legends to PC? Check! Now, the only thing left to do is to livestream your gaming session.
First, you need to decide which online platform you are streaming to. Will you be going live on YouTube, Facebook, Twitch, or Discord? Once that’s sorted, you just need a video streaming tool from where you can broadcast your PC screen online. While there are many streaming software available online, we will choose one of the best ones: OBS Studio.
How to Stream Mobile Legends Using OBS
OBS is a free and open-source tool accessible to everyone. It works on Windows, macOS, or Linux, so compatibility is not an issue!
Here are the detailed steps on how to set up and use OBS Studio for live streaming:
Step 1. Download and install OBS Studio, and run the auto-configuration wizard from the “Tools” option in the top menu bar.
Opening Auto-Configuration Wizard
Step 2. On the right side of the interface, you will see several options. Click on “Settings > Audio” and adjust the audio settings to capture desktop audio or microphone audio.
OBS Audio Settings
OBS Audio Settings
Step 3. Under the “Sources” tab, you will see a “+” sign. Click on it to select your video sources. As we are live streaming Mobile Legends, select the “Game Capture” option to record only the game screen.
Step 4. Click “Start Streaming” from the right menu to go live.
Open the Stream Tab from Settings
And that’s about it!
Bonus Tip: How to Live Stream MLBB on Twitch
You all know about Twitch, right? It is a popular live streaming platform primarily focused on video game live streaming.
However, recently, Twitch launched its mobile app. This app makes it convenient for gamers to stream their gaming sessions on popular platforms via their devices without going through the hassle of first mirroring it to a bigger screen and then using third-party software to stream it.
Therefore, if you are looking for ways to stream Mobile Legends on YouTube or Discord, here is how to do it via the Twitch app:
Step 1. Download the Twitch App on your device from the Google Play Store or Apple Store.
Step 2. Launch the app, and log in to your account. Convert the mode to the Create mode from the top right corner. Then choose Go Live.
Select the Go Live Option
Step 3. Tap on “Stream Games” and select “Mobile Legends: Bang Bang” from the list of games.
Select the Stream Games Option
Step 4. Give a title to your stream, select the language and other details, and tap “Launch Game” to begin.
Select Streaming Games from the Menu
Add the stream info, and that is how you can directly stream Mobile Legends from your smartphone using the Twitch app.
FAQs About Mobile Legends Live Stream
Now that you know how to live stream Mobile Legends on PC, let’s answer some frequently asked queries by our users:
1. Do I need a capture card to stream mobile games?
No, you do not need a capture card to stream mobile games. Capture cards are often used to capture gameplay from gaming consoles or PCs, where the gameplay is displayed on a separate device, like a TV or monitor.
However, you’re already playing directly on your mobile device’s screen for mobile games.
2. Do PC streamers need a capture card?
PC streamers do not necessarily need a capture card if they are streaming content directly from their PC. Capture cards are primarily used when you want to capture and stream content from external devices, such as gaming consoles or other PCs.
In this article, we have discussed the complete process to live stream Mobile Legends on PC. The first part includes steps of screen mirroring your smartphone to your PC using AnyMiro and then further streaming the mirrored content online using a streaming tool like OBS.
We have also added the steps of live streaming Mobile Legends directly from your mobile using the Twitch app.
So, whether you want to stream using a larger screen or directly from your smartphone, you will learn all the ins and outs of streaming with the help of this comprehensive guide!
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
