Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
This article will explore the common reasons behind iOS 14 screen mirroring not working and provide effective solutions for users. Let’s dive into our step-by-step guide to fix your problems.
Screen mirroring is a feature that allows users to display the contents of their smartphone, tablet, or computer screen on another larger screen, such as a TV, monitor, or projector. This technology has become increasingly popular as it allows for a more immersive viewing experience, enhanced collaboration in professional settings, and easy sharing of content with others.
The iOS 14 has numerous wonderful features to enhance the user experience, including screen mirroring. However, some users have reported facing issues with screen mirroring on iOS 14, which is dispiriting.
If you are experiencing the same problem and wondering how to fix iOS 14 screen mirroring not working issues, you have come to the right place. Whether you are using an iPhone, Apple TV, or Mac, we have got you covered with step-by-step instructions to fix your problems.
If you are using an iPhone 5/5Plus or 6/6 Plus, your device is not compatible with iOS 14 screen mirroring. The screen mirroring feature is available only on iPhone 7/7 Plus, 8/8 Plus, X, XR, XS Max, XS, 11, 11 Pro, 11 Pro Max, and iPhone 12. Most iPads also support AirPlay mirroring. Therefore, you should make sure your device supports the screen feature before using it.
A stable network connection is essential for screen mirroring. If screen mirroring doesn’t work on iOS 14, you may need to verify that both devices are connected to the same Wi-Fi network and that the network connection is stable and strong.
Sometimes, screen mirroring issues can occur after a software update. In such instances, try resetting your device by force restarting it and resetting the network settings. Go to Settings > General > Reset > Reset Network Settings. This should resolve the issue if it was caused by the iOS 14 software update.
Another reason is that a firewall or antivirus software on either device is blocking the screen mirroring connection. You can temporarily disable such software and try screen mirroring again to see if screen mirroring is working.
Usually, the MacOS software update and the Firewall are the main factors contributing to the screen mirroring not working issue for many users, which may prevent the system from establishing a screen mirroring connection. Here is a step-by-step guide on how to resolve the Firewall issue:
Step 1. Open System Preferences and go to the Security & Privacy section.
Step 2. Enter the administrative login, select the Firewall tab, and then go to the Firewall option.
The Firewall Option
Step 3. Deselect the option Block all incoming connections.
Deselect the Option
Step 4. Ensure the option automatically allow downloaded signed software to receive incoming connections is selected.
Once you have made these changes, attempt to connect your iOS 14 device with your Mac to verify if the issue has been resolved.
If you are experiencing screen mirroring issues on Apple TV, follow these steps:
Step 1. Connect both your iPhone and Apple TV to the same Wi-Fi network.
Step 2. Update your Apple TV to the latest version.
Update Apple TV
Step 3. Restart your iPhone running iOS 14 and your Apple TV.
Restart Your Devices
Step 4. Turn off restrictions on your iPhone.
Turn off Restrictions
Step 5. Reset network settings on your iPhone.
Now you may reconnect and mirror your screen to check if it works.
The screen mirroring app that comes with the phone often has compatibility issues. Therefore, we recommend a third-party screen mirroring tool – AnyMiro – to achieve projection without facing compatibility issues.
Anymiro is compatible with various operating systems, including iOS, Android, Windows, and macOS, making it accessible to a wide range of users. With AnyMiro, you can mirror your device to a larger screen without worrying about the screen mirroring not working on your iPhone.
Features of AnyMiro
Here are the main features of AnyMiro:
How to Mirror iPhone to PC Using AnyMiro
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror Android to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Mirror iPhone to PC wirelessly
Step 2. Go to the iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Connect to the Same WiFi
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring the iPhone.
Mobile Screen Mirrored on the Computer with AnyMiro
1. Does iOS 14 have AirPlay?
Yes, your iPhone 14 is capable of streaming video straight to a television. This is made possible with the iOS AirPlay feature.
2. Why is screen mirroring not working on my iPhone iOS 16?
You may not be connecting your devices to the same Wi-Fi network. Remember, Airplay will only allow you to share your iPhone screen to a device when using the same Wi-Fi network on both devices. Therefore, you’ll need to check the network of both devices.
3. How do I turn on screen mirroring on my iPhone?
If you have an iPhone X or newer or an iPad running iOS 12 or later, swipe down from the upper-right corner to reveal the Control Center. Otherwise, swipe up for Control Center instead. Tap the screen mirroring button, which looks like two overlapping boxes. Now you have turned on the screen mirroring feature. And you can use free screen mirroring apps for iPhone to connect your iPhone and PC.
Screen mirroring is a convenient feature that allows users to display the contents of their smartphone, tablet, or computer screen on a larger display. If you are facing screen mirroring not working issues on iOS 14, it can be frustrating. You may use the step-by-step instructions we have discussed in this article to fix them. We also recommend using third-party screen mirroring apps for iPhone like AnyMiro, to cast your screen that supports multiple operating systems without any compatibility problems.
