Turning on the screen mirroring option for devices is a piece of cake, but is turning it off also that easy? In this complete guide on how to turn off screen mirroring, we have put together steps to disable this feature on your PC, iOS, Android, and TV.
Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
We have always read articles and guides on how to enable screen mirroring, but only a few on how to turn it off. This leaves many users in confusion when it comes to disabling this feature on their PCs, smartphones, or TVs.
Therefore, to make things easier for everyone, we have put together a comprehensive guide outlining methods on how to turn off screen mirroring on various devices. So, let’s get straight to it!
Have you ever wanted to show your friends or family photos or videos on your phone or computer but found it hard to share the small screen? Well, say hello to screen mirroring!
With this feature, you can now easily display your device’s content on a bigger screen like a TV or monitor!
Screen mirroring, also called screen casting or sharing, is a useful technology that duplicates whatever you’re doing on one screen to another in real-time. You can use it to show off your latest vacation pictures, play mobile games on a larger display, or even give presentations at work.
Plus, there are wireless options like Wi-Fi Direct, AirPlay, and Google Cast that let you connect without messy cables. And if you prefer wired connections, all you need is a simple USB cable.
What is Screen Mirroring
In short, it is a super versatile and convenient way to share your content with others!
However, there are times when you may want to turn off screen mirroring, such as when you are sharing sensitive information or when you don’t want others to see what you are doing.
Therefore, in the following sections, you will find step-by-step instructions on how to turn off screen mirroring on Android, iOS, PCs, and TV.
iPhones and iPads use the AirPlay technology to cast their screens on other Apple devices wirelessly. However, to pair them up with a non-Apple device, you’ll have to use a third-party screen mirroring app.
Regardless of which method you are using to screen mirror your iPhone or iPad, here are the steps on how to turn off AirPlay on your device.
Here’s what to do:
Step 1. Open the Control Center on your iPhone or iPad by swiping down from the top-right corner of the screen.
Step 2. If you are not currently screen mirroring your device, simply tap on the “Screen Mirroring” icon indicated by 2 rectangles.
How to Turn Off AirPlay on iPhone
However, if you are in between a screen casting session, you’ll see the AirPlay icon next to the media file title. Tap on it to disable it.
And that’s how to turn off AirPlay or screen mirroring on your iPhone or iPad.
As the Mac is an Apple device, it also uses the AirPlay feature for screen mirroring. Therefore, if you want to turn off screen mirroring on a Mac, follow these steps:
Step 1. On your Mac, click on the Apple Menu > System Preferences.
Step 2. Select “Displays” from the menu on the left, and choose “Off” for the AirPlay Display option.
How to Turn Off Screen Mirroring on Mac
Just like iOS devices have the AirPlay feature, similarly, Android devices also have a built-in screen mirroring feature called Miracast. This feature runs on Android version 4.2 and later and enables seamless wireless screen mirroring across devices.
To turn off the screen mirroring Android, all you have to do is:
Step 1. On your Android smartphone, go to “Settings > Screen Mirroring.”
Note that different Android models use different names for screen mirroring. For instance, Smart View, Cast, SmartShare, Quick Connect, etc.
Android Screen Cast Option
Step 2. Tap on the screen mirroring option to see a list of devices currently or previously connected. Disconnect all devices, and turn the toggle off for screen mirroring.
Turn Off Cast on Android
Many Smart TVs come with a screen mirroring feature, making it possible to cast your smartphone or PC screen on it. Disabling screen mirroring on a Smart TV is quite a straightforward process.
Let us show you how to turn off screen mirroring on a Smart TV:
Step 1. Go to the “Settings” on your Smart TV using the remote control.
Step 2. Now look for Screen Mirroring, Cast, AirPlay, or Smart View option in the “General” or “Display” settings, and turn it off.
Stop AirPlay Screen Mirroring on TV
In this section, we went over 4 ways to turn off screen mirroring on iPhone/iPad, Mac, Android, and Smart TVs.
So, if you’re still with us, here’s a BONUS tip for you!
Do you want to screen mirror or go live from your mobile but want to do so from the luxury of a bigger screen? If yes, then AnyMiro is here to save the day!
AnyMiro is not only powerful and versatile, but it is also super easy to use. You can even use it to stream live videos!
If you’re wondering why you should choose AnyMiro over other similar tools, let us tell you that it offers a number of advantages! For instance:
High-Quality Visuals
With AnyMiro, you can mirror your screen in high quality with up to 4K resolution. This is quite important, especially if you’re live streaming, as it guarantees that your audience will enjoy a crystal-clear and top-notch viewing experience.
Low Latency
AnyMiro has incredibly low latency! There’s hardly any delay between what you see on your phone and what shows up on your computer screen. This feature makes it an excellent screen mirroring and live streaming tool because it ensures your audience sees everything happening in real time!
Integration with Streaming Tools
Did you know what sets AnyMiro apart? The fact that it can easily integrate with popular streaming tools like OBS Studio and Streamlabs! Using this feature-packed tool, you can effortlessly live stream your mobile phone screen to your viewers and share your content in an engaging way.
100% Clean & Safe
100% Clean & Safe
If you are screen mirroring your smartphone screen to another device, chances are that it will detect the device if it’s in near proximity in the future.
Why is that an issue? Because your smartphone may automatically pair with the device and start mirroring your screen. But there’s a way to avoid this hassle: You can disable screen mirroring altogether!
In this article, we have discussed how to turn off screen mirroring on various devices, including iPhones, iPads, Androids devices, Macs, and Smart TVs. So, the next time you’re having trouble with screen mirroring, you can always disable it by following the steps mentioned in this guide.
