Available for both Win & Mac
If you’re looking for a user-friendly and free mirroring app for iPhone to PC, you’re at the right place. In this article, we have discussed detailed steps on how to stream iPhone screen to PC using AnyMiro and Reflector 4.
As our lives revolve around smartphones, we all want more ways to connect and have fun. Streaming your iPhone screen to a PC is just the ticket!
It is a great way to share your content with others, use your iPhone as a second monitor, or troubleshoot problems. But that’s not the only thing streaming does! With this feature, you can also enjoy videos and games or make stellar presentations on a bigger screen.
In this article, we will take you through the easy steps of how to stream iPhone screen to PC using two of the best streaming apps, AnyMiro and Reflector 4. So, get ready to level up your iPhone experience and dive into the awesome world of screen streaming!
While streaming your iPhone screen to Mac or other Apple devices is as simple as ABC, streaming it to a Windows PC is another story altogether!
Why? Because you’ll be faced with compatibility issues. You see, iPhone and Windows are incompatible; therefore, if you’re wondering how to screen mirror iPhone to Windows 11, you’ll require a third-party app, like AnyMiro.
AnyMiro is a screen-mirroring app that helps you mirror your iPhone, iPad, or Android device to your PC or Mac with high-quality visuals. With this tool, you can screen mirror your device to your PC wirelessly or using a USB connection.
You need only 3 simple steps to stream an iPhone screen to PC using AnyMiro. Here’s what to do:
Step 1. Download and launch AnyMiro on your PC, and click “iOS/iPadOS” from the interface.
Mirror iPhone to Computer
Step 2. Connect your iPhone to your PC using a USB-to-lightening cable. Now select the “USB” option on the left.
Mirror iOS Device to Computer via USB
Step 3. Once both devices are connected, you will receive a notification on your iPhone. Tap “Trust” to continue.
Trust Your Computer on iPhone
Your iPhone screen will start streaming on your PC. Now you can easily do your work, make presentations, or share your screen with an audience with ease.
We are sure you’re wondering why you should choose AnyMiro out of all the screen-mirroring apps available online. Let’s make it easier for you to decide…
Why You Should Choose AnyMiro?
AnyMiro is a free mirroring app for iPhone to PC that comes with several benefits. For instance:
However, if you want to explore other screen streaming options, let us introduce you to another screen mirroring app for iPhone to PC: Reflector 4.
Reflector 4 is a screen mirroring and streaming receiver software that allows you to mirror your iPhone, iPad, Android, Chromebook, Mac, and Windows devices to your PC or Mac wirelessly. It supports AirPlay, Google Cast, and Miracast.
It is a powerful and user-friendly tool that can be used for a variety of purposes, like sharing your content with others, troubleshooting problems, or recording your screen.
If you’re looking for an easy way how to screen mirror iPhone to Windows 11 wirelessly, follow these steps:
Step 1. Download and launch Reflector 4 on your Windows PC.
Reflector 4 Screen Mirror
Step 2. Now connect your iPhone and PC to the same Wi-Fi network.
Step 3. On your iPhone, open the Control Center, tap on the screen mirroring icon, and select your PC’s name from the list of available devices.
Stream iPhone Screen to PC with Reflector 4
And that’s all! In 3 simple steps, your iPhone screen will start wirelessly streaming to your PC.
But, the million dollar question is…
Why You Should Choose Reflector 4?
If you are looking for powerful and easy-to-use screen mirroring and streaming receiver software, then Reflector 4 is a great option. Here’s why:
Reflector 4 is a good choice for a free mirroring app for iPhone to PC; however, it comes with its own share of limitations.
Top Critical Reviews
Following are some areas where Reflector 4 requires improvement:
With that sorted, let’s answer one of the most common questions users have regarding Reflector 4…
Can I Mirror iPhone to MacBook?
That would be a yes! As mentioned earlier, Reflector 4 is compatible with many devices, including Macbooks, Windows, etc. Therefore, if you want to mirror iPhone to Macbook, Reflector 4 is a good option.
Now that you know how to stream iPhone screens to PC using AnyMiro and Reflector 4, it’s time to decide which is the best and preferred choice.
So, between the battle of the screens, which screen mirroring app comes out as the winner? Only a head-to-head comparison can tell!
AnyMiro | Reflector 4 | |
Compatibility | iOS, Android, Windows & Mac | iOS, Android, Windows & Mac |
Connection Method | Wireless & USB | Wireless |
Price | Free Trial Version Pro: $15.99 |
Free Trial Version Pro: $21.99 |
Ease of Use | Easy to use, even for beginners | Easy to use but has a steeper learning curve than AnyMiro |
Our Recommendation?
When it comes to screen mirroring, AnyMiro takes the lead with its exceptional features and user-friendly experience. It supports both iOS and Android devices, providing versatility and compatibility for a wide range of users. Whether you prefer wireless or wired connections, AnyMiro offers both options, giving you the flexibility to mirror your screen in your preferred way.
1. Can I mirror my iPhone on my Windows PC?
Yes, you can mirror your iPhone on your Windows PC using a third-party app, like AnyMiro. This tool acts as a hub that enables connectivity between your iPhone and PC.
2. How do I mirror iPhone to a TV?
You can mirror your iPhone to a TV in several different ways:
3. Is It possible to mirror iPhone to PC without software?
Yes, it is possible to mirror iPhone to a Mac PC without software using the AirPlay feature. But, if you have a Windows PC, you’ll need a third-party app to enable screen mirroring.
4. What is the best free screen mirroring app for iPhone to PC?
If you are looking for a free mirroring app for iPhone to PC that’s reliable, safe and offers seamless connectivity, we recommend AnyMiro. It supports wired and wireless screen mirroring while offering no lag or latency and up to 10 hours of uninterrupted and stable connection via USB.
If you own an iPhone and a Windows PC, your major concern is how to stream iPhone screen to PC. The answer is third-party software!
However, even though there’s a multitude of screen-mirroring apps out there, AnyMiro emerges as the clear winner. And why shouldn’t it? With support for both iOS and Android devices and compatibility with wireless and USB connections, it offers you the flexibility to mirror your screen in your preferred manner.
So, don’t miss out on the best screen mirroring solution available! Elevate your mirroring experience and enjoy a larger-than-life view of your iPhone content on the big screen!
Download AnyMiro now!
