How to Remove AirPlay Device from iPhone (Easy Guide)
AnyMiro is one of the best AirPlay alternatives, download and try.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror How to Remove AirPlay Device from iPhone (Easy Guide)
Are you facing issues with AirPlay on your iPhone? Learn how to remove AirPlay device from iPhone. Plus, explore AnyMiro for more mirroring features.
Joy Taylor | Last Updated: Nov. 07, 2023
1946 words|6minute
Whether you are frequently interrupted by unwanted AirPlay pop-ups on your iPhone.
Or,
You may be facing issues with connectivity that AirPlay might be causing.
But no matter the situation, many people want to remove AirPlay from the iPhone. So, how to remove AirPlay device from iPhone?
We have answered this question here. This article will show how to remove AirPlay devices from your iPhone to resolve such challenges. But that’s not all. For those who want an alternative to AirPlay, we’ll also introduce you to AnyMiro.
But first, let’s see how to know if AirPlay is On.
How Do You Know If AirPlay Is On?
AirPlay is an in-built technology for wirelessly mirroring audio, video, and photos between Apple devices. Screen Mirroring is another subset of AirPlay that allows you to project the complete display of one Apple device onto another.
There are three methods to check the AirPlay.
How to Check if AirPlay is On:
Here is how you check if AirPlay is on.
Screen Mirroring:
Check Whether iPhone Screen Mirroring is On
Through Videos and Photos from Media Apps:
Check the AirPlay Icon to See its Activity
From AirPlay Audio Transition Icon in Control Center:
Check AirPlay Audio Transmission Icon
Knowing the status of AirPlay on your iPhone can help you take appropriate steps.
Now, let’s move on to our main topic.
Removing AirPlay from the iPhone is not a difficult process. You just need to change some settings, and you are done.
There are two methods you can choose. First, involve removing the AirPlay device using the Apple Account. The second involves changing the AirPlay settings.
Let’s see these two methods in detail.
1. Remove the AirPlay Device with the Apple Account
Here’s how to remove AirPlay device from iPhone with an Apple Account.
Step 1. Open the “Settings” app on your iPhone.
Step 2. Click on the Apple ID at the top and open your iCloud account settings.
Open iCloud Settings
Step 3. Scroll down, and you’ll see a list of devices connected to your Apple account.
Step 4. Locate the device that you wish to remove from AirPlay and select it.
Step 5. Once selected, click on “Remove From Account.”
Removing AirPlay Device from Apple Account
When you return, you’ll see that the selected device has been removed from the list. It will also clear AirPlay cache for that device.
2. Stop Automatically AirPlay on iPhone via AirPlay Setting
Here’s how to remove AirPlay device from iPhone so it doesn’t open automatically.
Step 1. Tap the Settings app on the iPhone’s home screen.
Step 2. Scroll down and select “General.”
Step 3. Under the General menu, tap on “AirPlay & Handoff.”
Go to Settings > General > AirPlay & Handoff
Step 4. You will see an option saying “Automatically AirPlay to TVs,” Tap on it.
Step 5. A list of options will appear. These are “Automatic,” “Ask,” and “Never.” If you want to disable automatic AirPlay, select “Never.”
Change the Connectivity Settings of AirPlay to “Never”
And that’s all!!!
Now, you can easily remove AirPlay from the iPhone. But we can’t ignore our Mac users, can we?
So let’s see how to remove AirPlay device Mac.
How to Turn Off AirPlay Receiver on Mac
If your Mac frequently becomes an unintended target for AirPlay streams, it might be a good idea to turn off the AirPlay Receiver. This change will ensure that your Mac won’t appear as an option when someone tries to use AirPlay.
Step-by-Step Guide to Turn Off AirPlay Receiver on Mac
Here’s a stepwise guide to removing AirPlay device Mac.
Step 1. Start by turning on your Mac and clicking on the Apple menu. It’s located at the top-left corner of your screen.
Step 2. From the dropdown, choose “System Preferences.”
Open System Preferences from Mac
Step 3. In “System Preferences,” find and click the “Sharing” option.
Open the “Sharing” section from System Preferences
Step 4. In the “Sharing” menu, locate and click on “AirPlay Receiver”.
Step 5. To disable the AirPlay Receiver on Mac, uncheck the box next to “AirPlay Receiver.”
Uncheck the “AirPlay Receiver” box
You are learning a lot, right?
Let’s keep the momentum and summarize how to stop AirPlay from popping up on an iPhone.
How to Stop AirPlay from Popping Up?
Unwanted AirPlay pop-ups are a significant disturbance. They occur when the AirPlay feature is set to activate automatically, and it can become a nuisance over time. Thankfully, there’s a simple way to stop this from happening.
The secret lies in changing the AirPlay settings on your iPhone so that it doesn’t connect automatically. If you’re looking for the steps to execute this process, you’ll find them in Part 2 of this article.
But if you have a Mac device that continuously connects with your iPhone, there’s another option. You can turn off the AirPlay receiver of the Mac device. This action will also prevent your Mac device from connecting to the iPhone.
Let’s keep in mind that AirPlay requires a wireless connection to mirror the screen as well as media files.reen and media files.
But another option for screen mirroring your iPhone to a PC that does not require can achieve this goal with a USB connection. So, if AirPlay does not meet your needs or lacks a compatible TV, here’s a new tool you can try.
New Tools Recommendation: AirPlay iPhone to PC with AnyMiro
AnyMiro is an amazing alternative to AirPlay for sharing your iPhone screen with your PC. It offers a stable, quick, and smooth connection. AnyMiro also supports up to 10 hours of uninterrupted mobile game or drawing streaming.
Notably, this tool from iMobie allows for screen mirroring of exceptional quality. You can mirror iPhone to PC with a resolution that can reach 4K. Even better.
Now, let’s see the key features of AnyMiro and the steps to use it.
Key Features:
Steps to Mirror iPhone to PC with AnyMiro
Here’s a stepwise guide to mirror iPhone to PC with AnyMiro.
Step 1. Download and install AnyMiro on your computer. Launch the tool and select the iOS/iPadOS option from the opening interface.
Mirror iPhone to Computer
Step 2. Now, decide whether you’d like to connect via USB or Wi-Fi.
Mirror iOS Device to Computer via USB
Note: If you encounter issues, update AnyMiro to the latest version. If the situation persists, try a different USB port or cable and restart your device.
Step 3. Once successfully connected via USB or Wi-Fi, your iPhone screen will appear on your PC. You can now enjoy a high-quality mirroring experience.
Mobile Screen Mirrored on the Computer with AnyMiro
Screen sharing from iPhone to PC with AnyMiro
Before we end our article, here are some frequently asked questions on removing the AirPlay device from the iPhone.
FAQs About AirPlay
1. Where is AirPlay on iPhone?
AirPlay can be found in the Control Center on your iPhone. Swipe down from the upper-right corner on iPhone X or later. You must swipe up from the bottom edge on iPhone 8 or earlier to access Control Center. Tap on “Screen Mirroring” or look at the AirPlay audio transmission icon to find AirPlay options.
2. How do we fix the AirPlay laggy issue?
If AirPlay is lagging, try restarting your iPhone and the device you’re mirroring. Ensure they’re both connected to the same stable Wi-Fi network.
If the issue persists, you may need to update your devices.
3. Do I need WiFi for AirPlay?
Yes, a Wi-Fi connection is generally required for AirPlay. However, if you’re looking for an alternative that doesn’t require Wi-Fi, AnyMiro is the answer. It can easily mirror your iPhone screen to a PC via a USB connection.
Unexpected AirPlay notifications can disrupt your flow in many situations. Whether you’re in a meeting, watching a movie, or enjoying downtime.
This article answered the key question “How to remove AirPlay device from iPhone.” And if you’re looking for an alternative for screen mirroring, you can consider AnyMiro. It allows you to connect your iPhone to your PC via USB without needing Wi-Fi.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
