How to Remote Control iPad from iPhone/Mac/PC
Try AnyMiro to mirror iPad to PC & Mac for free via USB and WiFi.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Home Screen Mirror How to Remote Control iPad from iPhone/Mac/PC
This guide explains remotely controlling an iPad from an iPhone, Mac, or PC. It includes using AnyMiro to screen mirror your iPad to a computer and control the operations, along with Switch Control for iPhone/Mac users. Each method is easy to follow, with step-by-step instructions. We recommend using AnyMiro, a reliable screen mirroring tool, to remote control iPad effortlessly.
Joy Taylor | Last Updated: Oct. 14, 2024
1322 words|4minute
Do you wish to use your PC, Mac, or iPhone to control your iPad remotely? It is more complex than you may think! There are easy ways to control apps, view notifications, and navigate your iPad’s screen from another device. This tutorial will walk you through managing your iPad with AnyMiro and Switch Control. These methods simplify maintaining control and connectivity, regardless of the device used, as they operate on iPhones, Macs, and PCs. These few steps to remote control iPad will allow you to access it through other devices with ease. Now, let’s get going!
Also Read: Free iPad Mirroring to PC Methods >
Remote Control iPad from PC&Mac via AnyMiro
With the help of AnyMiro’s robust screen mirroring program, you may easily operate your iPad remotely from your Mac or PC. AnyMiro provides a lag-free mirroring experience for up to 10 hours, making it ideal for streaming, gaming, and presenting creative work. Enjoy 4K high-resolution visuals with zero color difference, making it perfect for streaming games or live drawing sessions. With real-time audiovisual sync, your on-screen actions and audio stay perfectly aligned, ensuring a seamless experience. You can also capture screenshots, record highlights during live streams, or even use live annotations to engage your audience.
Key Features:
Here are the steps to remote control your iPad using AnyMiro:
Via USB
Step 1. Free download and install AnyMiro on your computer.
Step 2. Continue by connecting your iPad to the computer through a USB cable.
Step 3. Launch AnyMiro on your computer, and select “iOS/iPadOS” to continue.
Mirror iPhone to Computer
Step 4. Choose the USB connection mode.
Connect Your iPhone/iPad with a USB Cable
Step 5. To establish the link, you need to use a USB cord to connect your iPad to the computer. After that, a window to tap “Trust” will appear on the iPad screen. To unlock your iPad, tap “Trust” and input your passcode. Once linked, immediately begin high-quality screen mirroring of your iPad.
Trust Your Computer on iPhone
Via WiFi
Step 1. Launch AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Choose the Wi-Fi connection mode.
Step 3. Ensure your iPhone/iPad and computer are connected to the same Wi-Fi network.
Step 4. On your iPhone or iPad, open Control Center, tap “Screen Mirroring,” > and select “AnyMiro_Computer Name” from the list.
Step 5. Once your device is detected, start enjoying high-quality screen mirroring instantly!
Remote into iPad by Switch Control
You can access apps, navigate the screen of your iPad, and carry out other functions from a different device by utilizing Switch Control. This approach is easy to use and effective regardless you’re using a Mac or an iPhone. We’ll show you how to utilize Switch Control to set up remote access to your iPad in this part, which will make it simple to control your device from anywhere in your network.
Remote into iPad from iPhone/iPod Touch/iPad
Step 1. Ensure the iOS device in control is logged into the same Apple ID and has the same Wi-Fi as your iPad.
Step 2. Toggle Switch Control on by going to Settings > Accessibility > Switch Control on the controlling device.
Switch Control Section
Step 3. In Switch Control, tap on Switches > Add New Switch… > Source and select a source for your switch.
 Add New Switch
Add New Switch
Step 4. Use your new switch to navigate to “Switches,” then select Bluetooth Devices.
Select Bluetooth Devices
Step 5. Connect to the iPad you wish to control. You can now remotely access the iPad from your other iOS device.
Note: If the Switch Control button is grey and not working, go to Settings > Accessibility > Touch > AssistiveTouch and disable it. After that, return to Switch Control, and it should be active.
Remote into iPad from Mac
Step 1. Make sure your Mac and iPad are connected to the same wireless connection and signed in to the same Apple ID.
Step 2. On your Mac, click the Apple icon, navigate to “System Preferences,” and click on “Accessibility.”
Step 3. Select “Switch Control” from the options and turn on “Enable Switch Control“.
Select Switch Control
Step 4. Simultaneously, navigate to iPad’s Settings > Accessibility > Switch Control to enable it.
Switch Control on iPad
Step 5. Go back to the Switch Control panel on Mac and click on “Devices.” Find and select your iPad from the list, then connect. You can now control your iPad remotely from your Mac.
Add Devices
Add Devices
FAQs on Remote Control iPad
Is it safe to remote control my iPad?
Yes, it is safe to remote control your iPad if you use trusted apps like AnyMiro or built-in features like Switch Control. Always ensure your devices are secure and connected to a safe network to protect your information.
Do I need to install software to remote control my iPad?
Yes, you may need to install specific software or apps to remote control your iPad effectively. AnyMiro is the best option as it offers a good connection and has simple procedures to remote control your iPad.
What should I do if my iPad won’t connect to the remote control?
If your iPad isn’t connecting, be sure it and the other device are on the same network and verify your Wi-Fi connectivity. Restart both devices and try again. If the issue continues, consider using software like AnyMiro for better connectivity.
Final Words
In conclusion, controlling your iPad from another device can simplify operations. Several alternatives, such as Switch Control or apps like AnyMiro, are available to meet your needs. It is recommended that all connected devices should use the same WiFi, to ensure that the system runs properly. Think about utilizing AnyMiro for a flawless experience. It is a fantastic option for effortlessly controlling your iPad because it provides dependable connectivity, high-quality screen mirroring, and an easy setup process.
AnyMiro – Real-Time Screen Mirroring Tool
  • More than 10 hours of stable screen mirroring connection.
  • Up to 4K resolution providing a stunning visual experience.
  • Integrates with live streaming tools such as OBS and Streamlabs.
  • Auto-sync video and background audio with timestamp adjustments.
100% Clean & Safe
100% Clean & Safe
Joy Taylor
