Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Do you want to know how to enable AirPlay and mirror your iPhone to a larger screen? The following post will teach you how to AirPlay from your iPhone. Let’s get started!
AirPlay is a wireless mirroring tool developed by Apple that allows users to stream audio and video content from their iOS device or Mac computer to other compatible devices, such as Apple TV or AirPlay-enabled speakers. With AirPlay, users can easily mirror their iPhone’s screen or stream music, movies, photos, and more to a larger screen or better speakers for a more immersive experience.
But do you know how to operate AirPlay on your iPhone? How to turn on AirPlay and mirror your iPhone to a larger screen? Do you know what to do if AirPlay not working? If the answer is no, let’s move on to this article to learn about it.
It’s easy to turn on AirPlay on iPhone. Here are a few instructions for enabling AirPlay mode on an iPhone device:
Step 1. On your iPhone, swipe down from the top right corner of the screen (or swipe up from the bottom of the screen on older iPhone models) to open the Control Center.
Step 2. Tap on the screen mirroring icon, which looks like a rectangle with a triangle at the bottom.
How to Turn On AirPlay
Now AirPlay has been successfully enabled on your iPhone.
We already know how to turn on AirPlay on iPhone. Let’s see how to mirror iPhone to Apple TV using AirPlay.
Step 1. Connect both your iPhone and Apple TV to the same Wi-Fi network.
Apple TV WiFi Setting
Step 2. Ensure that AirPlay is enabled on your iPhone and Apple TV.
Step 3. Open the app or content you want to mirror on your iPhone.
Step 4. Swipe down (or up) from the bottom of your iPhone screen to open the Control Center.
Open iPhone Control Center
Step 5. Tap on the screen mirroring icon.
Step 6. Select your Apple TV from the list of available devices.
Your iPhone screen will now be mirrored successfully on your Apple TV.
Encountering AirPlay not working issue can be frustrating for many users. If you encounter issues with AirPlay, try these troubleshooting methods:
If the issue persists, you may contact Apple support for further assistance.
If you find there are some difficulties with AirPlay and want to use another screen mirroring app, you may consider AnyMiro to fulfill your needs effortlessly and without any compatibility issues.
AnyMiro is a powerful screen mirroring app that allows you to mirror the screen of your iPhone/Android to PC via USB or Wi-Fi, which enhances the functionality of your iPhone by seamlessly connecting it to other devices.
Let’s see the features of AnyMiro and how to use it.
Features of AnyMiro:
User-Friendly Interface: AnyMiro is designed with simplicity in mind, making it incredibly easy to use. Whether you are a beginner or a tech-savvy user, you can effortlessly mirror your phone’s screen to a PC with just a few simple steps.
Reliable and Seamless Screen Mirroring: AnyMiro ensures a stable and smooth connection between your phone and PC, allowing for seamless screen mirroring. You can enjoy up to 10 hours of mirroring without any interruptions or hassles.
High-Quality 4K Resolution: With AnyMiro, you can mirror your screen in stunning 4K resolution, preserving vibrant colors and ensuring exceptional visual clarity. Experience your content with accurate colors and lifelike details for a truly immersive viewing experience.
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a USB cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Mirror iPhone to PC wirelessly
Step 2. Go to the iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Connect to the Same WiFi
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring the iPhone.
Mobile Screen Mirrored on the Computer with AnyMiro
1. Can I mirror iPhone using USB?
Yes, you can mirror iPhone using USB via AnyMiro. AnyMiro supports both USB and Wi-Fi connections.
2. Why can’t I mirror my iPad to my TV?
There are many reasons. First, AirPlay-compatible devices are turned off and far away from each other. Second, the devices are not updated with the latest software. And third, they are not on the same Wi-Fi network.
3. Do you need Wi-Fi for AirPlay?
Yes, the two devices should be connected to the same Wi-Fi for AirPlay. But if Wi-Fi is not available, you can use Apple Lightning Digital AV Adapter to connect two devices.
In conclusion, this article provides step-by-step instructions on how to enable AirPlay on an iPhone and mirror iPhone to Apple TV using AirPlay. It introduces AnyMiro as an alternative screen mirroring app that offers a user-friendly interface, reliable and seamless screen mirroring, and high-quality 4K resolution. With AnyMiro, you can easily mirror your iPhone to a PC via USB or Wi-Fi. Download AnyMiro today and unlock a whole new level of seamless experience.
