Screen mirroring Android to the computer without root.
Available for both Win & Mac
Learn how to mirror Android screen to PC without root by reading through the comprehensive guide given in this post. There are 3 quality techniques introduced.
Screen mirroring is a popular feature that allows you to project your smartphone screen directly on a larger screen like TVs or computer systems. It comes in handy, as it offers a convenient way for you to expand your view on a smaller screen.
Mirroring is pretty simple but can be quite complicated for newbies, especially those with Android smartphones. To help out, we’ve curated a simple guide on how to mirror Android to PC without rooting the device. Let’s delve in!
Just before we discuss how to mirror Android to PC without root, it’s crucial you note that there are some prerequisites (settings) that must be fulfilled. These prerequisites are essential to facilitate a smooth connection between the Android device and PC before screen mirroring can occur.
Find below, these prerequisites:
1. Activate the Developer Options on the Android Phone
Your Android smartphone won’t connect with any PC for screen mirroring to occur unless you’ve been granted access by the developer, which isn’t possible. However, you can achieve this manually by activating the developer options from the settings panel.
Here’s a simple guide to doing that:
Android System about Phone
2. Enable USB Debugging on the Android Phone
Having activated the developer option, you are one step away from completing the preparation for casting your Android phone to PC. Now you need to enable USB debugging to successfully connect the Android phone to PC.
Below, we have how to enable USB Debugging:
Allow USB Debugging on Your Phone
Mirroring Android to PC without rooting the corresponding device can be achieved with the aid of the AnyMiro screen mirroring app. The app is one of the most sophisticated apps suitable for casting your Android screen to PC/Mac conveniently.
AnyMiro lets you project whatever content you have on your mobile screen to a larger surface in high quality. It is simple and free to use. Even if you’re new to this tool and can get along with it in a few minutes. This app isn’t limited to mirroring only Android devices, you can also use it to share or cast your iPhone screen on your computer.
What You Can Get from AnyMiro:
Follow the steps here to see how to mirror Android to PC via USB with AnyMiro:
*With this method you need to download both the AnyMiro software and the mobile app.
Step 1. Download to get the AnyMiro desktop version, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro tells you how.
Mirror Android to Computer via USB
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your PC.
Select the Connection Method
Besides USB cable connectivity, AnyMiro also enables users to mirror Android screen to PC via a WiFi connection. If you don’t want the screen mirroring to be limited by the USB cable distance, you can follow the steps here to see how to use WiFi to mirror the Android screen.
*You need to download both the desktop and mobile apps of AnyMiro in this method.
Step 1. Get AnyMiro on your computer, and enter Android mirroring.
Step 2. Connect your Android and computer to the same WiFi, then download the AnyMiro app on your Android phone.
Download AnyMiro App on Your Phone
Step 3. Open AnyMiro app, and tap the WiFi connection to search your computer.
Tap WiFi Connection
Step 4. Select your computer’s name, and a few seconds later the Android screen will be mirrored to your computer’s screen.
Instead of installing a third-party screen mirroring app, Android users can leverage the pre-installed screen mirroring feature on their PC to mirror their mobile screen. However, a precondition must be fulfilled for this to occur. Find below the condition:
If your Android device meets this condition, then you can proceed to share content to a larger screen via the pre-installed screen mirroring feature on your computer. Here’s how to mirror Android to PC without root via preinstalled mirroring feature:
Step 1. Hold down the hotkeys Windows Logo and I on your keyboard to launch the Settings menu panel on your PC.
Step 2. Next, navigate to System, select Projecting to this PC, and tap on Optional Features to proceed.
Step 3. On the next screen tap on Wireless Display > Install. Wireless Display will immediately install on your PC. Kindly ensure your data connection is stable and in close range for quick installation.
Projection Settings
Step 4. Once completed, a drop-down menu will come up. Click Available Everywhere> Launch the Connect app to project to this PC. The Connect app will automatically come up on your PC screen.
Step 5. Get on your mobile phone, open Settings, and select Enter Miracast (also known as Cast) in the search field.
Step 6. Tap on the Cast icon and click the three vertical dots at the upper right corner of your screen. Check the box next to Enable Wireless Display.
Step 7. Your phone will scan for nearby devices to mirror the screen on. Once the PC name shows, click on it and screen mirroring will commence.
Limitations
Chromebook owners looking to expand their view from a smaller screen like Android to a larger interface can do that using the Vysor app. Vysor supports screen mirroring from Android to PC with high resolution. It lets you share screens wirelessly with no stress.
Follow the stepwise guide given down here to mirror Android screen to Chromebook via Vysor:
Step 1. With an internet-enabled PC (Chromebook in this case), navigate to Google PlayStore and enter Vysor in the search box. Download the corresponding Vysor extension, and run it to add it to the Chrome browser.
Step 2. Once done, connect the Android phone to the Chromebook computer via a USB cable. Ensure all drivers on Chromebook are updated, then proceed to the next step.
Step 3. Click on the Vysor extension icon to open it. Vysor should detect your Android phone immediately. If not, try checking the USB Debugging again.
Step 4. After Vysor detects your device, head to project or cast your Android screen on Chromebook. You should start seeing your mobile screen on your Chrome computer.
Detect Your Device Through Vysor
Limitations
AnyMiro offers the best way to mirror Android to PC/Mac for a plethora of reasons. From the smooth connection process, whether USB or wireless connectivity to high-resolution content sharing, audio mirroring, and more. This tool is the complete screen mirroring solution you need to cast your Android screen to PC or Mac conveniently.
Now you have all the necessary techniques for how to mirror Android to PC without root, which option do you prefer to use? All options are free, simple to implement, and safe. However, the best is the one involving the AnyMiro screen mirroring app. The software mirrors your Android to PC with no rooting required. It offers excellent mirroring services, without compromising the device, or the data stored on it.
