Screen mirroring your Android to the computer with ease.
Available for both Win & Mac
In this article, we’ll show you how to mirror Android to PC via USB by the most popular tool step by step. And introduce several other mirroring apps with the function of Android to PC via USB for you in detail.
If you ever need to view a phone screen on pc via USB, there are a few ways to do it. One of the best options is to connect your Android phone to your PC using a USB cable. This method gives you fast and responsive mirroring with very little lag. In this article, we’ll show you step-by-step instructions on how to mirror Android to PC without Wi-Fi via USB using the most popular tool. And introduce several other mirroring apps with the function of Android to PC via USB for you in detail.
Yes, you can mirror Android to Windows PC via USB. This process is commonly referred to as “USB Debugging” or “USB Screen Mirroring.” Mirroring Android to a PC via USB offers several advantages including but not limited to the following:
Also Read: 2 Methods to Stream Android Phone Screen to OBS >
The steps and requirements for setting up an Android device may differ based on its make, model, and operating system version. However, they are generally the same or similar for most devices. You can follow the step-by-step guide below to screen mirroring Android phone by USB:
Note: The exact steps and terminology may vary slightly depending on your Android device’s manufacturer and software version. These instructions are based on stock Android settings.
Step 1. Unlock Your Android Phone: Make sure your phone is turned on and unlocked.
Step 2. Go to Settings: Open the “Settings” app on your phone.
Step 3. Find About Phone: Look for an option called “About Phone” or something similar and tap on it.
About Phone option in Settings
Step 4. Tap Build Number: In the “About Phone” section, tap on “Build Number” seven times quickly.
Tap the Build number 7 times
Step 5. Enable Developer Options: Go back to the main Settings menu, and you’ll see “Developer Options” (or “System”) now. Tap on it.
Step 6. Turn On USB Debugging: Inside “Developer Options,” find “USB Debugging” and switch it on.
Developer Settings on the Device
Step 7. Connect Your Phone to PC: Use a USB cable to connect your phone to your PC.
Step 8. Authorize the PC: If prompted on your phone, allow USB debugging for the connected computer.
That’s it! USB Debugging is now enabled on your Android phone, allowing it to communicate with your PC for various tasks like screen mirroring and app development. Remember to disable it when not needed for security.
After reading through the steps above on how to mirror Android to PC via USB. You have already mastered the skills of mirroring Android to a PC by debugging USB. Despite the advantages of mirroring Android to a PC via USB, you may need a more convenient and simple way to screen mirror your Android to a PC by USB. By the way, AnyMiro is also available only under Wi-Fi.
AnyMiro is specially devised for users to achieve smooth and successful mirroring wherever they are, and whenever you do, as long as you have a phone and PC by your side. Once, you have downloaded it, you will experience:
In this part, we will offer you a step-by-step guide on how to mirror Android to PC via USB through AnyMiro. Please note that you must download AnyMiro onto your computer before conducting any operation. You must maintain a stable network during the download and installation process.
Step 1. After completing the installation progress, please launch AnyMiro on your computer and select the Android option to connect the device.
Mirror Android to Computer
Step 2. Please tap the USB icon and connect your Android device with a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 3. Please turn on the USB debugging and choose the MTP Mode after you plug the USB cable.
Enable USB Debugging and MTP Mode for a USB Connection
Step 4. Then download the AnyMiro app, and tap the USB connection on your Android phone.
Select the Connection Method
After completing the steps above, you may enjoy the smooth mirroring experience now!
Vysor is a software tool enabling users to mirror and manage Android devices on their computer screens. Therefore, it acts as a connection between your Android device and PC, so you can effortlessly see and operate your Android device on your computer display.
Select Connect Button in Vysor
Depending on your software version, certain options may only be available with a paid upgrade. So, you may need to distinguish this app according to its pros and cons:
Pros:
Cons:
LetsView is a digital platform allowing seamless interaction across multiple screens and devices including screen mirroring, remote sharing, and enhanced overall user experience.
LetsView Interface
Pros:
Cons:
Mirroring360 is a third-party software that allows you to wirelessly broadcast your device with a target device to share the contents of your screen. You can read other articles to learn how to mirror Android to PC via USB. This program works with iPads, iPhones, Androids, Windows, Mac, and Chromebook computers and allows you to broadcast to up to 40 devices at a time.
Screen Mirroring iPhone Mirroring360
Pros:
Cons:
iMyFone MirrorTo is a great tool that allows you to mirror your Android or iPhone screen onto your computer. It comes with several controller options to manage your screen and provides good speed for uninterrupted gaming or movie watching. However, the virtual keyboard mapping feature is only available to paid users.
MirrorTo Sharing Android Screen to PC
Pros:
Cons:
1. What is the best screen mirroring app for Android to PC via USB?
AnyMiro is one of the most amazing tools for those who want to mirror their phone or tablet to their computer via USB. The connection is stable and seamless. Users love the fact that it’s compatible with both Android and iOS devices.
2. What is USB mirroring?
USB mirroring model allows you to mirror the screen of your smartphone onto the receiver’s screen via a USB cable connection. Enjoy high-quality pictures and accurate mirroring thanks to the built-in digital-to-digital USB converter.
3. Does my PC support screen mirroring?
Open CMD and type “netsh WLAN show drivers” to check the status of Wireless Display Supported. If it says, ‘Yes’, then it means your PC supports Miracast. Another way to check it is by opening the ‘Connect’ App and using the Connect to a wireless display option.
Alright, after a lengthy introduction on the topic of how to mirror Android to PC via USB, and highlights various tools for this purpose. I guess you already know how to debug USB to achieve mirroring Android to PC and how to use the most recommended software—AnyMiro, an optimal option, to achieve a smooth with the provided steps. What are you waiting for? Just download AnyMiro to cheer your life up!
