Top Ways to Mirror Android to Mac
Download and try AnyMiro to mirror Android to Mac with ease.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror Top Ways to Mirror Android to Mac
This article mainly introduces different methods of how to mirror android to mac through different apps.
Joy Taylor | Last Updated: Nov. 01, 2023
1569 words|5minute
People may mirror their phone screen on a larger screen such as a TV or PC in many scenarios and work according to different needs. For example, Business professionals often mirror their phones to a PC during meetings or presentations to share content like slides, documents, or demos with a larger audience; Watching videos or streaming content from a phone on a larger PC screen for a better viewing experience when we are in a group of friends.
When users encounter issues with their mobile devices, they may mirror their screens to a PC to seek help from tech support or to troubleshoot problems more effectively. However, many users can mirror iPhones to a Mac without knowing how to mirror Android to Mac. That’s easy to do if you read this article through!
How to Mirror Android to Mac with AnyMiro [Recommend]
AnyMiro is a screen mirroring app that supports both USB mirroring and wireless mirroring. What makes it stand out among other mirroring apps? Well, if you try this app you will straightforwardly experience:
Believe me, once you have tried it, you will be surprised by its function whenever and wherever you use it to mirror Android screen to Mac. Now, follow my steps of instructions to handle your devices in two ways.
Tips: With this method, you need to download both the AnyMiro software PC version and the mobile app. Make sure you have a USB cable if you choose to mirror via USB.
Mirror Android to Mac via USB
This part mainly tells you how to mirror Android to Mac via USB.
Step 1. Download to get the AnyMiro desktop version, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro that tells you how.
Enable USB Debugging and MTP Mode for a USB Connection
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your PC.
Select the Connection Method
Mirror Android to Mac wirelessly
If you want a more convenient way to mirror your Android device’s screen on your Mac. Or just because there is no USB cable by your side. Then you can use the WiFi method in AnyMiro.
Note: Your Android phone and your Mac need to connect to the same WiFi to ensure a successful connection.
Now, let’s dive into the step-by-step process of mirroring Android to Mac wirelessly.
Step 1. Connect your Android device to your computer (via WiFi).
Step 2. Run AnyMiro on Mac, and select the Android option to connect the device.
Step 3. Then, click the WiFi icon to connect your Android device to WiFi.
Mirror Android to Computer via WiFi
Step 4. Go to Google Play and search AnyMiro or scan the QR code to download the AnyMiro App on your Android device.
Download AnyMiro App on Your Phone
Step 5. Then, open the AnyMiro app on the Android device, select Wi-Fi Connection, and select the device name you want to mirror.
Tap WiFi Connection
Tap WiFi Connection
Mirror Android Screen to Mac via MirrorTo
MirrorTo is a wireless screen mirroring app that can be used to cast Android phones to PCs, and Macs with audio. Next, I’ll walk you through how to mirror Android to Mac.
Step 1. Download and install iMyFone MirrorTo on both your Android device and Mac computer.
Step 2. Connect your Android device and Mac computer with a USB cable.
Step 3. Launch iMyFone MirrorTo on your Mac. Choose “Android”.
MirrorTo Android Option
Step 4. On your Android device, go to Settings > Software information > click “Build number” 7 times.
Step 5. Then go to Developer options > enable USB cable. Now your Android screen can be shared on your Mac.
How to Mirror Android Screen to Mac Using LetsView
LetsView is another free screen mirroring tool that is compatible with multiple platforms. It supports cross-platform screen mirroring.
Step 1. Download and install LetsView on both your Android device and Mac computer.
Step 2. Connect your Android device and Mac computer to the same Wi-Fi network.
Step 3. Open LetsView on your Mac computer and click on the “Computer Screen Mirroring” button at the bottom of the screen.
Step 4. Open LetsView on your Android device and tap on “Scan to Connect” at the bottom of the screen.
Step 5. Scan the QR code displayed on your Mac computer.
Step 6. Your Android screen should now be mirrored to your Mac computer.
LetsView Sharing Android Screen to Mac
Mirror Android to Mac with AirDroid Cast
AirDroid Cast is an application with mirroring screen features. This app allows users to remotely screen mirror and control the devices. Here are steps to show you how to mirror Android to Mac.
Step 1. Download AirDroid Cast on the official website and install it both on your Android phone and Mac.
Step 2. Launch the AirDroid Cast app on both Android and Mac devices. You can choose either casting with a QR code or casting with a 9-digit (a random number) casting code.
Choose the Connection Method in AirDroid
Step 3. Click on Start Casting (grant permission for casting when the permission pops up if you are the first user).
AirDroid Start Casting
Step 4. Now your Android to Mac mirroring process is completed.
FAQs
1. How do I mirror my Android to my Windows computer?
Here’s a step-by-step guide on how to connect your device to a PC using the Connect app, a Windows built-in feature:
Step 1. On the PC you want to project to, search for the Connect app by typing “Connect app” in the search box on the taskbar.
Step 2. From the list of results, select the Connect app to launch it.
Step 3. On the device you want to project from, go to the screen mirroring settings or cast settings.
Step 4. Look for the option to connect to a PC and select it.
Step 5. Choose the PC you want to connect to from the list of available devices.
Step 6. Wait for the connection to be established.
Once the connection is established, you can start projecting your device’s screen to the PC.
2. Is screen mirroring the same as AirPlay?
Screen mirroring allows you to see your iPhone’s screen on your TV, displaying any action you take on your phone. While AirPlay enables you to stream media from your phone to your TV without showing your phone’s screen.
3. Why can’t I use screen mirroring?
One of the main causes of screen mirroring not working is when both your devices are not connected to the same Wi-Fi network. This technology works only when the smartphone and the TV screen have the same internet server. So, make sure your TV has the same internet connection as your smartphone.
We have explored various methods to teach you how to mirror Android to Mac. Whether you prefer USB or wireless mirroring, there are options like AnyMiro, MirrorTo, LetsView, and AirDroid Cast to suit your needs. But AnyMiro is the most recommended one compared with other methods. With AnyMiro providing with you strong, smooth, and lag-free mirroring, you can easily share your Android screen on your Mac for presentations, entertainment, troubleshooting, and more.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
