When you stream your iPhone’s screen to a PC or TV via AirPlay, its icon appears on your lock screen. However, sometimes the icon stays there even after you’re done streaming, leaving you wondering, “How to get AirPlay off my lock screen?” In this article, we have discussed how to turn off AirPlay from the lock screen in a few easy steps.
Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
AirPlay is a handy feature that lets you stream audio or video from your Apple device to compatible devices like speakers or TVs.
However, some people might find it a little intrusive to have AirPlay controls always visible on their lock screen. But don’t worry! It’s super easy to customize this feature to suit your preferences and remove its icon from your screen.
So, if you’re wondering, “How to get AirPlay off my lock screen?” keep reading to get your answer!
If you are not a big fan of having AirPlay controls on your lock screen, you’ll be happy to know that you can easily remove them from your Apple device.
While it can be convenient to have quick access to playback settings, a cleaner lock screen can also be quite appealing.
In the following section, we will take you through the steps to turn off AirPlay from the lock screen.
If you are streaming content from your iPhone to a PC or TV, you can turn off the AirPlay icon from the lock screen. Here’s how:
Step 1. Look for the AirPlay icon next to your media’s title and click on it.
Step 2. This will make the overflow menu appear, with the name of the AirPlay device listed under the Speakers & TVs tab.
Step 3. Tap on the iPhone device to disable AirPlay.
It’s as simple as that!
Now that you know how to turn off AirPlay from the lock screen let’s see how we can use AirPlay to cast your iPhone’s screen to a PC or TV.
If you have an iPhone and an Apple TV or Mac, you can easily mirror the iPhone screen via AirPlay. The process is so simple that you can get it done before you finish saying “AirPlay!”
Let’s see how to go about it!
Mirror iPhone Screen via AirPlay on Apple TV
Follow these steps to cast your iPhone screen on an Apple TV via AirPlay:
Step 1. Connect your iPhone and Apple TV to the same Wi-Fi network.
Step 2. Now, open the Control Center on your iPhone by swiping down from the top-right corner and clicking the “Screen Mirroring” icon.
Step 3. Select your Apple TV from the list of available devices.
Now, wasn’t that as easy as pie?
Let’s see how we can do the same on Mac.
Mirror iPhone via AirPlay on Mac
To cast your iPhone screen to Mac via AirPlay, follow these steps:
Step 1. Open the Control Center on your iPhone, and tap the “Screen Mirroring” icon.
Step 2. Select your Mac from the list of available devices.
And with this, you’ll successfully mirror your iPhone screen to your Mac.
However, while AirPlay is convenient and easy, it is not very versatile. For instance, you can only use it across Apple devices, and it does not come with advanced features like screen recording.
So, what to do in that case? Go for AnyMiro!
AnyMiro is an amazing screen mirroring app using which you can share your iPhone screen to a PC without any restrictions.
And the best part is you can use either USB or WiFi to connect your devices and start mirroring! This means you can enjoy your iPhone screen on your Mac even when you’re not connected to WiFi.
Plus, it’s quite versatile and works with Windows, Mac, iOS, and Android, so you can easily mirror your devices with each other.
Features of AnyMiro:
These features of AnyMiro make it one of the best screen mirroring apps out there. Let’s see how to use it.
Steps to Screen Mirror iPhone to PC Using AnyMiro
Here are the steps to screen mirror an iPhone to a PC via AnyMiro. First, we will discuss how to mirror using the USB connection and then the wireless connection.
Via USB Connection
Step 1. Download and launch AnyMiro on your PC, and click “iOS/iPadOS” from the interface.
Step 2. Connect your iPhone to your PC, and select “USB” from the options on the left menu.
Step 3. Once both devices are connected, tap “Trust” on the trust notification on your iPhone.
And that’s how to mirror your iPhone screen to a PC via a USB connection.
Via Wireless Connection
Step 1. Download and launch AnyMiro on your PC, and select “iOS/iPadOS” from the interface.
Step 2. Connect your iPhone and PC to the same Wi-Fi network, and select “WiFi” from the menu on the left.
Step 3. On your iPhone, enable “Screen Mirroring” from the Control Center and select “AnyMiro” from the list of available devices.
And in 3 easy steps, you’ll be able to mirror your iPhone to a PC over a Wi-Fi connection.
1. Why is AirPlay showing up on my iPhone lock screen?
The AirPlay controls will appear on your lock screen in the following instances:
2. How do I stop AirPlay from automatically connecting?
You can stop AirPlay from connecting automatically by disabling it from the iPhone settings.
Go to Settings > General > AirPlay & Handoff and toggle off the “Automatically AirPlay to TVs” switch.
3. Why is my AirPlay automatically playing?
If your AirPlay is automatically playing, it could possibly be due to the following reasons:
Your Device is Set to Automatically AirPlay to TVs
When the “Automatically AirPlay to TVs” feature is enabled, your device will automatically connect to any AirPlay TVs that it is close to and that you have previously used. You can disable this feature by going to Settings > General > AirPlay & Handoff and toggling off the “Automatically AirPlay to TVs” switch.
An App Running on your Device is Using AirPlay
Some apps, such as music and video streaming apps, may use AirPlay to stream content to other devices. You can turn off this option from the Control Center by tapping the AirPlay icon next to your media file.
Whether you’re currently using AirPlay on a nearby Apple device or recently screen mirrored your iPhone screen to a PC or TV, you might see the AirPlay controls appearing on your lock screen.
This can be pretty irritating, especially when you’re not using the feature at the time. So, if you’re thinking, “How to get AirPlay off my lock screen,” you’ll find the solution in this guide. And if you’re looking for an AirPlay alternative with better features, we recommend trying AnyMiro to take your screen mirroring experience to the next level.
