Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Have you ever encountered the situation of AirPlay freezing? AirPlay freezing can impact the transmission and playback of content, potentially causing issues like delayed visuals and playback interruptions. This article informs you about the reasons behind AirPlay freezing and provides solutions to address this problem.
The emergence of AirPlay has revolutionized the way we share and stream content, enabling seamless wireless playback across various devices. Whether it’s streaming music to a sound system or casting movies to a large-screen TV, AirPlay has provided us with unparalleled convenience.
However, there are times when we encounter the frustrating issue of AirPlay freezing. AirPlay not working will lead to symptoms such as stagnant visuals, interrupted audio, playback pauses, visual delays, and content disconnections. In this article, we will delve into the underlying causes of AirPlay freezing, and offer a series of effective solutions.
Before addressing the issue of AirPlay freezing, you need to know why AirPlay might become frozen. AirPlay freezing can have various underlying causes, encompassing factors such as network connectivity, hardware limitations, and software malfunctions, among others.
1. Network Congestion:
Whether for work or leisure, a seamless network connection is crucial. However, inadequate network bandwidth or interference can lead to interruptions in data transmission, resulting in freezing during the AirPlay process.
2. Device Compatibility:
A core feature of AirPlay is seamless connection between different devices. Yet, compatibility issues between sender and receiver devices, particularly with older models, might lead to freezing problems.
3. Software Errors:
In the digital realm, software errors are inevitable. Be it within iOS devices, macOS, or third-party applications featuring AirPlay functionality, errors or glitches within the software can trigger freezing.
4. Overheating and Hardware Limitations:
Modern devices may experience overheating when handling resource-intensive tasks, and insufficient hardware resources can contribute to freezing issues, especially during demanding operations.
5. Interference and Weak Signal
Interference from other electronic devices, such as cordless phones or microwaves, can interrupt the AirPlay connection. Likewise, if there is considerable distance between your Apple device and the AirPlay receiver, or if they are obstructed by walls or other physical barriers, the Wi-Fi signal may weaken, resulting in freezing or buffering problems.
6. Overburdened Wi-Fi Network
When numerous devices are concurrently linked to your Wi-Fi network, it can burden the network’s bandwidth and result in your AirPlay freezing. Activities demanding substantial bandwidth, such as downloading sizable files or streaming high-definition content on other devices, can adversely affect the reliability of your AirPlay streaming.
Tackling AirPlay not working necessitates a systematic approach, from optimizing your network to diagnosing hardware and software issues, gradually pinpointing the root causes.
1. Check network connection
To resolve AirPlay freezing, begin by checking your network connectivity. Ensure that both the sending and receiving devices are connected to stable Wi-Fi networks. Alleviate potential network congestion by disconnecting unnecessary devices that could contribute to bandwidth strain.
2. Check that AirPlay is Enabled
If AirPlay keeps freezing on Samsung TV or Apple TV, make sure that your Apple TV or Samsung TV has enable the AirPlay.
Turn On AirPlay on Apple TV
3. Device and Software Updates
Keeping your devices up-to-date is crucial. Regularly update your iOS devices, macOS, and Apple TV to their latest software versions. Additionally, check if any third-party applications supporting AirPlay have updates available. Updated software often includes bug fixes and improvements that could address freezing issues.
The Setting of Updates
4. Device Reboot
When troubleshooting AirPlay freezing, a straightforward yet effective step is to reboot both the sending and receiving devices. By initiating a reboot, you essentially clear any temporary glitches or hitches that may have inadvertently arisen, ensuring a refreshed state for both devices and enhancing the likelihood of resolving the freezing concern.
5. Hardware Environment Optimization
It’s important to adequately ventilate your devices to prevent overheating, while also confirming that both the sender and receiver devices possess ample available storage and memory. Proper ventilation safeguards against potential overheating issues, promoting consistent functionality, while verifying sufficient storage and memory capacity on both ends facilitates smooth operations during AirPlay sessions.
6. Network Settings Reset
In the event that freezing problems persist on iOS devices, a network settings reset might provide a solution. This step can help address any underlying network configuration issues that could be causing the freezing. Open “Settings” – “General” – “Reset”. Then, tap on “Reset Network Settings”.
Select Reset Network Settings
If the above methods haven’t helped you resolve the issue of AirPlay freezing, you might consider seeking assistance from Apple’s official support. However, there’s a quicker alternative: using third-party screen mirroring software like AnyMiro as a substitute for AirPlay.
AnyMiro is a highly stable and low-latency screen mirroring software. It can mirror both iOS and Android devices to Mac or PC with high compatibility, supporting screen mirroring via Wi-Fi or USB connection. It maintains a stable connection for over 10 hours. Additionally, its screen mirroring quality is exceptionally clear, with 4K resolution ensuring no color discrepancies in your mirrored content.
It can also synchronize audio, enhancing the viewing experience. AnyMiro goes beyond simple mirroring; it assists you in livestreaming your mobile content to popular platforms like YouTube, Twitch, Facebook, making it extremely convenient for content creators.
Here are the steps of how to mirror your iPhone to Mac:
Step 1. Please download AnyMiro on your Mac. You can click the button above to quickly initiate the download.
Step 2. After the download is complete, open AnyMiro and choose iOS/iPadOS to proceed to the next step.
Mirror iPhone to Computer
Step 3. Next, select the Wi-Fi mode. Make sure your iPhone/iPad and Mac are connected to the same Wi-Fi network. Then, on your iPhone/iPad, open the Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name” when it appears.
Step 4. You have successfully connected your device. You can now see your phone screen’s content on your Mac.
Mobile Screen Mirrored on the Mac with AnyMiro
By following the methods above, you may be able to resolve the issue of AirPlay freezing. If not, we recommend using AnyMiro as an alternative to AirPlay for screen mirroring. AnyMiro is more stable than AirPlay and offers better screen quality. Additionally, it allows for USB screen mirroring in case of unstable networks, ensuring a more reliable mirroring experience. Feel free to download and give this software a try.
