How to Cast Android Mobile Screen on Laptop
Download AnyMiro to cast Android screen to laptop.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror How to Cast Android Mobile Screen on Laptop
Learn how to cast Android screen on laptop and break free from the limitations of a small screen. Discover various methods, including a new tool AnyMiro.
Joy Taylor | Last Updated: Nov. 07, 2023
1322 words|4minute
In this digital age, our smartphones are our trusted companions. We store a wealth of information, memories, and entertainment in them. But imagine breaking free from the confines of the small screen and experiencing it all on a big screen.
You must be thinking, is it even possible? Well, it is through screen casting. Whether you want to binge-watch movies or play games on a big display, screencasting is the solution. It can help you enjoy the content with a more immersive viewing experience.
This article will explain how to cast Android screen on a Windows laptop. We will also explore different tools and methods of doing it. Let’s get started!
Table of Contents:
What to Do Before Casting Android Screen
Before casting your Android phone on your laptop, there are a few important steps to take. These steps will ensure you have a smooth experience while screencasting and minimize the chances of disconnectivity.
Ensure that both your Android smartphone and your laptop support screen casting. Some older models of laptops and Androids may not have this feature.
Ensure that both your Android device and laptop are connected to the same Wi-Fi network. This is essential for establishing a connection between the two devices.
If you plan to use a USB connection for screencasting, you may need to enable USB debugging. In the Developer Options settings, find “USB Debugging” and enable it.
Your Android device and laptop should have the latest software updates installed. This helps to optimize performance and ensures compatibility with casting methods.
You may need to install a casting app depending on your chosen method. Many popular options, like Google Home, Miracast, and AnyMiro, are available in the market.
Methods to Cast Android Screen on Laptop
Now that we know what to do before casting an Android screen, let’s see different methods of how to cast Android screen on laptop.
1. Cast Android Screen with Microsoft Wireless Display
Microsoft launched a new Connect app as part of the Windows 10th Anniversary update. It enables users to cast the screen of their Android onto their laptop or PC. This feature eliminates the need for any third-party applications.
Steps to cast Android screen with Microsoft Wireless Display
Follow the instructions below to cast your Android smartphone’s screen onto your laptop.
Step 1: Type Connect in Windows search and select the Connect app shown in the picture below.
Open the Connect App on the Laptop
Step 2: After opening the Connect app, you will see the below display on your screen.
Connect App Interface
Step 3: Now unlock your Android phone, swipe down, and click Cast in the status bar.
Step 4: Turn on the Bluetooth, and it will automatically search for your Laptop.
Step 5: Select your laptop to connect your Android. Then, you will see your Android phone screencasting on your laptop.
2. How to Cast Android on Laptop with AnyMiro
Another great tool that helps cast your Android phone to your Laptop is AnyMiro. It is a new screen mirroring app that is about to release soon. AnyMiro supports both Android and iPhone, allowing you to also cast Android phone to Mac.
Whether you want to play games or watch live streaming on a big screen, AnyMiro has you covered. It is the go-to solution for reliable and efficient screen mirroring.
Key features of AnyMiro
*You need to download both the desktop and mobile apps of AnyMiro in this method.
Step 1. Get AnyMiro on your computer, and enter Android mirroring.
Mirror Android to Computer
Step 2. Connect your Android and computer to the same WiFi.
Download AnyMiro App on Your Phone
Step 3. Download AnyMiro App from Google Play, open it, and tap the WiFi connection.
Tap WiFi Connection
Tap WiFi Connection
Step 4. Select your computer’s name, and a few seconds later the Android screen will be mirrored to your computer’s screen.
3. Using Scrcpy to Cast Android Screen to Laptop
Another answer to how to cast Android screen on laptop is Scrcpy. It is known as one of the best tools for screen mirroring your Android screen to your PC via a USB cable. You can control your Android phone using a keyboard and mouse.
However, Scrcpy requires an understanding of operating the ADB command line. If you are a developer, you must be familiar with it. But if you are a beginner, the below steps will help you set up Scrcpy for Windows.
Steps to set up Scrcpy for Windows
Step 1. Ensure that the Android and laptop are connected to the same Wi-Fi network.
Step 2. Download the latest Scrcpy on your laptop from the official GitHub and extract it into a new folder in C Drive.
Download the Latest Scrcpy
Step 3. Now enable USB debugging mode on your Android device by going to Settings and then Developer options.
Step 4. Connect your Android device to the laptop via a USB cable. Select the “File transfer” or “MTP” option if prompted.
Step 5. Go to the folder where you downloaded the Scrcpy file, right-click on Scrcpy.exe, and select run as administrator.
Scrcpy.exe Run As Administrator
Scrcpy will launch and display your Android screen on the laptop. You can now interact and control your Android device using your laptop’s keyboard and mouse.
Comparison Among Microsoft Wireless Play, AnyMiro, and Scrcpy
Here is a comparison chart of all the mentioned screen mirroring apps. Check the features of these screen mirroring tools and see which one suits you the best.
Qualities Microsoft Wireless Play AnyMiro Scrcpy
Ease of use Moderate Easy Moderate
Connectivity Wi-Fi/HDMI Wi-Fi/USB Wi-Fi/USB
Performance Good Excellent Good
4k Resolution No Yes No
Audio support Yes Yes No
Streaming Tool Integration No Yes Yes
Cost Free (Latest version of Windows) Free for 40 Mins/Day Free
Remember, these qualities may change over time with software updates. Therefore, Checking the official websites for the most up-to-date information is good.
Casting your Android screen on a laptop offers a more immersive viewing experience. With the right tools, you can smoothly enjoy games, movies, and TikTok on a big display. We hope this article has provided you with the answer to how to cast Android screen to laptop.
However, if you want a much smoother and more convenient experience, AnyMiro is for you. It is a new screencasting app in the market with unique features and an easy-to-use interface. You can install it and take your screencasting experience to a new level.
Joy Taylor
