Available for both Win & Mac
Learn how to cast Android screen on Mac easily. Explore different tools that help in screen mirroring with a step-by-step guide, also discover their pros and cons.
Are you an Android enthusiast who is also a proud Mac user? Do you want to experience your favorite games, apps, and content on a larger screen? But you have no idea how to cast Android screen on Mac, right?
Casting an Android screen on Windows is a piece of cake and is very common. But people often think screen mirroring of Android and Mac is impossible. Well, you never know! This article is going to unveil the secret of casting Android screen on Mac. We also will explore different methods and tools that help in joining both. Let’s get started!
Let’s explore more about how to cast Android screen on Mac. You must be thinking, Is it even possible to mirror your Android to your Mac?
Yes, it is possible to mirror your Android device to a Mac computer. Although native screen mirroring functionality may not be available between Android and Mac devices, there are third-party applications and tools that can facilitate this process. One popular option is using third-party software like AnyMiro, Vysor, or ApowerMirror, which provide screen mirroring capabilities between Android and Mac devices.
Mirroring Android Screen on Mac
AnyMiro is a new screen mirroring tool designed by iMobie for gamers and live streamers. With AnyMiro, you can easily cast your Android/iPhone screen to Windows/Mac. It is a fast, secure, and convenient tool for screen mirroring. AnyMiro has improved performance for its users along with unique features. Its simple and easy-to-use interface makes it convenient for everyone to operate it.
Download AnyMiro now and follow the guide here to cast Andriod screen to Mac.
*You need to download both the desktop and mobile apps of AnyMiro in this method.
Step 1. Get AnyMiro on your computer, and enter Android mirroring.
Mirror Android to Computer
Step 2. Connect your Android and computer to the same WiFi, then download AnyMiro app on your Android phone.
Download AnyMiro App on Your Phone
Step 3. Open AnyMiro app, and tap the WiFi connection to search your computer.
Tap WiFi Connection
Step 4. Select your computer’s name, and a few seconds later the Android screen will be mirrored to your computer’s screen.
Mirror Android to Computer via WiFi
Another tool that can help you screen mirror your Android to Mac is X-Mirage. It supports all devices that are compatible with Airplay or Google Cast. You can record screen/audio and also do voiceover via microphone with just one click. X-Mirage supports HD mirroring. Now you can play games and enjoy entertaining content on a bigger screen.
Demo of Screen Mirroring with X-Mirage
Follow the instructions given below to cast the Android screen on Mac:
Step 1: Download and install the X-Mirage app on your Mac. Ensure that your Mac and Android are connected to the same Wi-Fi network.
Step 2: Now unlock your Android device and swipe down to access the quick setting panel.
Step 3: Click on the Cast button and turn it on.
Click on the Cast Button
Step 4: You will see a list of devices. Choose your Mac and connect it.
Step 5: Once the connection is established, you will see your Android screen on your Mac.
Now that we have learned about using X-Mirage, let’s look at its pros and cons.
Pros
Cons
Another tool that is very common for screen mirroring is AirDroid Cast. You can easily cast your Android screen to Mac with AirDroid. It has incredible features with advanced screen mirror technology.
However, the best thing about AirDroid cast is that users can remotely screen mirrors and control the device. You can download and use a free version, but you need to buy it if you want to access all the features.
AirDroid Cast Screen Mirroring
Step 1: First, download and install AirDroid Cast on your Android phone and Mac through Google Play and Website.
Step 2: Now launch the app on your Mac and Android. Then click the wireless option on Mac.
Click the Wireless Option
Step 3: You will see a QR code and a 9-digit code. Scan the QR code with an AirDroid scanner from your Android, or simply enter the 9-digit code to connect both devices.
Step 4: Then click on casting. After clicking, you will see a pop-up on your Mac screen. Grant permission to cast the Android device to mirror.
Step 5: Finally, your Android screen will be displayed on your Mac. You can also control your Android phone on your Mac by tapping the hand icon on the box next to start controlling.
The advantages and limitations of AirDroid Cast are as follows:
Advantages
Limitations
When it comes to screen mirroring, you have two primary options: USB cable and Wi-Fi. Both have pros and cons, and the choice depends on your needs and preference.
Wi-Fi screen mirroring offers convenience, mobility, and multiple device support. Whereas USB cable screen mirroring provides stability and speed. Let’s walk through their pros and cons to understand which is better for your needs.
Pros
Cons
Pros
Cons
Hopefully, this article has helped you to understand what screencasting is and how to cast Android screen on Mac. We have explored various tools that are helpful in screen mirroring. They have a free version but restrict you from utilizing all their features.
However, if you are looking for a tool that should be fast, secure, and easy to use, then look no further. Because AnyMiro has all the features that one could ask for while screen mirroring. So download it now and take your screen mirroring experience to the next level.
