How to Airplay YouTube from iPhone to Mac/PC and TV
Try AnyMiro to mirror iPhone to Mac & PC for free via USB and WiFi.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Home Screen Mirror How to Airplay YouTube from iPhone to Mac/PC and TV
Wondering how to AirPlay YouTube from your iPhone to Mac, PC, or TV? This guide covers step-by-step methods for each device, including options like AnyMiro and built-in AirPlay.
Joy Taylor | Last Updated: Oct. 25, 2024
1776 words|6minute
Are you interested in viewing YouTube videos from your iPhone on a larger screen, such as your TV, Mac, or PC? AirPlay makes it simple! YouTube streaming from your iPhone can significantly improve the experience of viewing a movie or sharing a video with friends. In this guide, we’ll walk you through the easy process of AirPlay YouTube to Mac devices or TVs. We suggest AnyMiro, an all-in-one screen mirroring application that provides quick connections and crystal-clear video, for the most seamless experience. Now, let’s explore how to AirPlay YouTube!
How to AirPlay YouTube from iPhone to Mac
Below are some methods to AirPlay YouTube from iPhone to Mac:
AirPlay YouTube from iPhone to Mac by AnyMiro
AnyMiro is a powerful tool to AirPlay YouTube from your iPhone to Mac, offering 4K quality mirroring for up to 10 hours. It simplifies screen sharing and streaming, allowing you to mirror content seamlessly. AnyMiro supports multiple device mirroring to display different content from various devices simultaneously. Plus, you can take real-time recordings and capture screenshots during your session.
Key Features:
To use AnyMiro for this purpose, follow these steps:
Via USB
Step 1. Free download and install AnyMiro on your Mac and ensure it’s up and running.
Step 2. Launch AnyMiro on your Mac and select the option for “iOS/iPadOS.”
Mirror iPhone to Computer
Step 3. Choose the “USB connection” option to initiate the connection. Plug your iPhone or iPad into your Mac using a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 4. On your iPhone, tap “Trust” when the prompt appears to confirm the connection.
Trust Your Computer on iPhone
Step 5. Enter your device’s passcode if prompted. Once connected, you can begin mirroring your iPhone screen to your Mac for smooth YouTube streaming.
Via Wi-Fi
Step 1. Open AnyMiro on your Mac and select “iOS/iPadOS.”
Step 2. Pick the “Wi-Fi connection” option to proceed.
Step 3. Make sure your iPhone and Mac are connected to the same Wi-Fi network.
Connect to the Same WiFi
Step 4. On your iPhone, open Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name” from the available options.
Step 5. Once the devices are linked, enjoy streaming YouTube from your iPhone to your Mac with high-quality mirroring!
AirPlay YouTube from iPhone to Mac Directly
You may utilize Apple’s AirPlay to mirror YouTube from iPhone to Mac. Apple’s AirPlay is designed to share pictures, videos, and even music on your Apple TV and Mac devices in UHD without any lags. It is a straightforward method of streaming YouTube and other content and is easy to start up by simply connecting both devices to the same Wi-Fi network. Apart from the stated content, you can enjoy a FaceTime experience on a larger screen with the AirPlay feature. For this:
Step 1. Open YouTube on your iPhone and choose the video you want to play.
Step 2. Tap the video to pause it, then tap the “AirPlay” button.
Tap the AirPlay Button
Step 3. Once you tap “AirPlay,” a list of devices will appear. Choose your TV or Mac from the list.
Choose Device
Choose Device
Step 4. Tap anywhere to close the device list, then press “Play” on your iPhone. The video will now play on your Mac screen.
How to AirPlay YouTube from iPhone to PC (Windows)
AirPlay YouTube from iPhone to Windows via AnyMiro
If you’re looking to AirPlay YouTube from your iPhone to a PC, AnyMiro offers a seamless experience. It provides low-latency audio-visual sync, perfect for smooth 4K video streaming and gaming. You can enjoy a flexible and stable connection with Wi-Fi or USB connectivity options. AnyMiro also lets you live stream directly to platforms like YouTube and Zoom.
Key Features:
Check out the simple steps to use AnyMiro to AirPlay YouTube from iPhone to PC:
Via USB
Step 1. Free download and install AnyMiro on your PC, then launch the application.
Step 2. In AnyMiro, select the “iOS/iPadOS” option to begin the setup.
Step 3. Click on the “USB connection” option to establish the connection. Connect your iPhone or iPad to the PC using a USB cable.
Step 4. Tap “Trust” on your iPhone when prompted to confirm the connection.
Step 5. If required, enter your iPhone passcode. After connecting, your screen will start mirroring on your PC, allowing smooth YouTube streaming.
Via Wi-Fi
Step 1. Install and open AnyMiro on your PC. Choose the “iOS/iPadOS” option from the main screen.
Step 2. Select the “Wi-Fi connection” option to start wireless mirroring.
Step 3. Check that the iPhone and PC have the same Wi-Fi network. On your iPhone, open Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name” from the available devices.
Step 4. Once connected, you can seamlessly stream YouTube from your iPhone to your PC with high-quality mirroring.
AirPlay YouTube from iPhone to Windows via AirServer
AirServer is an excellent program that makes it simple to mirror your iPhone to your Mac or Windows computer. It serves as an AirPlay receiver, making it simple to broadcast music and videos. You can effortlessly share images or presentations, enjoy high-definition playback, and mirror the screen of your iOS device with AirServer. Connecting and switching between your iPhone and computer is simple, thanks to the application’s multi-device compatibility. To use this method:
Step 1. Go to the AirServer website to download the app and install it on your Windows PC. Once done, Open the AirServer application on your computer.
Step 2. Swipe down the Control Center on your iOS device and select your Windows PC by tapping the “Screen Mirroring” or “AirPlay” button. The PC will display the screen of your iOS smartphone.
Tap on Screen Mirroring
How to AirPlay YouTube from iPhone to TV via HDMI Cable
If your TV does not support AirPlay, a lightning to HDMI adapter will enable YouTube to be broadcast from your iPhone to your television. First, check if your HDMI cable is inserted correctly and if it’s compatible with your TV. It is a good method for sharing entertaining videos with friends and family on a larger screen.
Pre-Requisites: You’ll need to buy the Lightning to HDMI adapter (also called Lightning Digital AV Adapter) to connect your iPhone to the TV.
Check the simple steps below:
Step 1. Plug one end of the cable (lightning end) into your iPhone.
Step 2. Attach the HDMI side of the adapter to your TV.
Use USB and HDMI Adapter
Use HDMI Adapter
Step 3. Use your TV remote to open the Input source menu and choose the HDMI option to display your iPhone screen.
Choose HDMI
Choose HDMI
Step 4. Launch YouTube on your iPhone and play the video. It will appear on the TV screen.
FAQs on How to Airplay YouTube
Can I AirPlay YouTube to any TV?
Any TV that supports AirPlay, such as Apple TV or smart TVs, may stream YouTube. If your TV doesn’t support it, you can easily watch videos by connecting your iPhone directly with an HDMI adaptor.
Is there a more efficient screen mirroring option?
We suggest AnyMiro, an all-in-one screen mirroring solution if you’re looking for a simple and adaptable approach to mirroring your screen. It enables you to experience high-quality video playback effortlessly, record your screen in real-time, and mirror numerous devices!
Can I use AirPlay with apps other than YouTube?
YouTube is not the only app that supports AirPlay. It works with music apps like Apple Music and streaming services like Netflix and Hulu. To begin streaming, seek the AirPlay icon in any app.
Final Words
In this post, we looked at several ways to AirPlay YouTube from your iPhone to PCs, Macs, and televisions. We talked about wired and wireless choices, highlighting how simple connecting and streaming your preferred videos is. To improve your experience, we also addressed frequently asked issues and offered troubleshooting advice. AnyMiro is a viable option for individuals looking for a dependable and adaptable solution. Features like high-quality playback, multi-device support, and real-time recording make screen mirroring easier and a great choice for smooth streaming.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
