Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
This comprehensive guide provides step-by-step instructions for Mac, iPhone, and iPad users on AirPlay from VLC to various devices, including Apple TVs and Smart TVs. To enable seamless streaming, follow the instructions for how to AirPlay from VLC in this guide. We recommend AnyMiro – the best screen mirroring tool – as an AirPlay alternative to Screen Mirror iPhone/Android to PC & Mac.
Are you curious about how to AirPlay from VLC? It’s a fantastic method for enjoying your preferred music and videos on a larger screen, such as your TV. Using VLC, you can effortlessly stream media to any AirPlay-capable device, including Apple TV, from your Mac or iOS device. With this technique, you can enjoy high-quality playback without complicated cable connections. This guide will explain the process of using AirPlay with VLC to improve your viewing experience. So, let’s begin to explore!
With VLC, Mac, or iOS, media can be broadcasted to an Apple TV or other AirPlay-capable devices by ensuring both are connected over the same Wi-Fi network before streaming. VLC lets you stream your media collection wirelessly and enjoy your favorite media instead of sorting out extra cables or complicated settings.
The media file must be in playable format before you can begin streaming content from your Mac to your TV. Next, make sure your Apple device is configured for Chromecast and AirPlay, and link your Mac and TV to the same Wi-Fi network. This technology has streamlined the process by eliminating the need for physical connections and enabling wireless streaming.
Enjoy your media on a bigger screen easily, control playback from your Mac, and stream HD videos. It’s speedy, easy to use, and ideal for streaming videos, series, or films straight from VLC. For this method:
Pre Requisites
Step 1. Access the VLC application on your Mac.
Step 2. Pick a movie or video to watch, and start playing it. To open a file, click “Media” in the top menu.
Step 3. Access the “Playback” menu and choose “Renderer.”
Select Renderer Option
Step 4. From the list of devices, choose your TV.
Since VLC supports native AirPlay casting, using AirPlay on an iPhone or iPad is significantly simpler. Instead of mirroring your whole screen, like you would on a Mac, you can cast only the video or audio to your TV and continue to use your device for other purposes. This flexibility increases convenience for iOS users. Ensure your device and TV are linked to the same Wi-Fi network for the best streaming experience. To apply this technique:
Step 1. Open the VLC application on your iPhone or iPad. To browse files, tap the “Video” or “Audio” section.
Step 2. Select the video or audio you wish to play and start it.
Step 3. Tap the “Cast” icon in the screen’s top-right corner.
Select Cast Icon
Step 4. From the menu, choose “AirPlay or Bluetooth.”
Select AirPlay or Bluetooth
Step 5. Select your smart TV from the list of devices shown.
Step 6. If prompted, enter the 4-digit AirPlay code that appears on your TV.
Step 7. Wait for the connection to be finalized. Once connected, your video will begin playing on the TV.
If you’re looking for a great alternative to AirPlay, consider AnyMiro for screen mirroring. With AnyMiro, you can stream multiple devices, allowing you to display different content simultaneously — ideal for presentations and teamwork. You can also record your screen in real-time or take high-quality screenshots. It’s easy to live stream your screens, audio, cameras, and mics to platforms like YouTube and Zoom.
You can choose between a stable USB connection or flexible Wi-Fi, depending on what suits you best. Mirror your phone or tablet screens with synced audio for a smooth experience, and turn your phone camera into a movable HD webcam with up to 4K resolution. You can use your phone’s microphone for audio or quickly cast photos, videos, PDFs, and documents to your computer with just one click. With multi-device mirroring, customizable layouts, and real-time annotation tools, AnyMiro is great for meetings, teaching, live streaming, demos, and entertainment.
Key Features:
Now, let’s explore the simple and easy steps to screen mirror iPhone/Android to PC & Mac:
Step 1. Begin by downloading and installing AnyMiro on your computer.
Step 2. Continue by connecting your iPad to the computer with a USB cable.
Step 3. Open AnyMiro on your computer and select “iOS/iPadOS” to proceed.
Mirror iPhone to Computer
Step 4. Choose the option for “USB connection.”
Connect Your iPhone/iPad with a USB Cable
Step 5. Connect your iPad to the computer with the USB cord. A prompt on your iPad asks you to tap “Trust.”
Step 6. Tap “Trust” on your iPad and enter your passcode. Your iPad will now be linked, and you can start high-quality screen mirroring immediately.
Trust Your Computer on iPhone
Step 1. Open AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Choose the option for “Wi-Fi connection.”
Step 3. Check that your iPhone/iPad and computer have the same Wi-Fi network.
Step 4. On your iPhone or iPad, access the Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name” from the available options.
Select AnyMiro to Mirror iPhone to MacBook Bluetooth
Step 5. Once your device is detected, you can enjoy high-quality screen mirroring immediately!
Step 1. First, free download and install AnyMiro on your computer and open the application.
Step 2. Select the “Android” option from the main menu.
Mirror Android to Computer
Step 3. Click on the “Wi-Fi” icon to start the wireless connection.
Mirror Android to Computer via WiFi
Step 4. On your phone, locate AnyMiro on Google Play or scan the QR code to download the app.
Download AnyMiro App on Your Phone
Step 5. Open the AnyMiro app on your phone and select “Wi-Fi Connection.” Choose your computer’s name from the list to mirror your phone’s screen.
Tap WiFi Connection
Which version of VLC should I use for AirPlay?
Version 3.0 is the minimum accepted VLC version for using the AirPlay feature. Keep your application up-to-date for smooth access.
What if VLC does not detect my AirPlay device?
If VLC doesn’t see your AirPlay device, reboot both the source device and the TV and ensure that the Wi-Fi connections from both ends are turned on. We recommend AnyMiro for trusted mirroring options.
What types of files can I stream via AirPlay and VLC?
You may need to listen to or watch video files, audio files, podcasts, and almost everything else using AirPlay and VLC, which should support the most common file formats for easy play.
AirPlaying from VLC is an excellent way to view movies and listen to audio on a larger screen. The methodology is simple and easy to understand; it works both with a Mac and an iPhone or iPad. This guide has shown you how to make it work smoothly. If you want an even better experience, we recommend AnyMiro. It lets you mirror your screen wirelessly or with a USB, stream high-quality audio and video, and connect multiple devices easily. With AnyMiro, sharing your favorite content is simple and fun!
