Have you ever encountered a problem with the AirPlay icon not showing on Mac? Sometimes, on a Mac, we may not find the AirPlay icon, which could be due to system issues or certain settings. You need to know how to add AirPlay to menu bar. Reading this article will guide you on how to display AirPlay in the menu bar.
Screen mirroring your iPhone with AirPlay alternative – AnyMiro.
Available for both Win & Mac
AirPlay is a convenient feature that wirelessly transfers audio, video, and screen content from Mac computers or iOS devices to compatible devices. However, sometimes users may encounter a perplexing issue where the AirPlay icon not showing on Mac. This can be due to certain settings or system-related reasons, and in such cases, it’s essential to know how to add AirPlay to menu bar.
In this article, we will explore the reasons behind this issue and how to add AirPlay to menu bar on a Mac. Additionally, we will offer fundamental information about AirPlay, covering its definition, and various AirPlay versions.
If you find out that your Mac doesn’t show AirPlay in menu bar, there could be several reasons behind this issue. The following factors may be responsible for the missing AirPlay icon on Mac:
From the previous text, we can understand that there are many reasons why the AirPlay icon not showing on Mac. However, the first thing we should do is check the AirPlay settings, as this is the most direct and quickest solution, often a primary reason. Many times, the issue arises because we haven’t properly configured AirPlay display settings within the system. Therefore, you need to know how to add AirPlay to menu bar.
This is the step-by-step guide to help you understand how to add AirPlay to menu bar.
Step 1. Click on the Setting on Mac.
Step 2. Choose “System Preferences.” Select “Displays.”
Step 3. In the “Displays” window, navigate to the “AirPlay Display” option. Check the box next to “Show mirroring options in the menu bar when available.”
Set to Show Mirroring Options in Menu Bar
Step 4. And don’t forget to Navigate to “System Preferences” select “Dock & Menu Bar” and choose “Screen Mirroring”. Click on “Show in Menu Bar.”
Enable AirPlay in Mac Menu Bar
AirPlay is a technology developed by Apple that enables wireless streaming of audio, video, and screen content from your Mac or iOS device to compatible devices such as Apple TV, AirPlay-enabled TVs, and AirPlay speakers. Here are some key points to know about AirPlay:
Understanding these fundamentals should assist you in getting started with AirPlay and addressing any problems you may come across. Don’t worry about the AirPlay icon not showing on Mac.
While AirPlay offers many benefits for wireless streaming and mirroring, it also comes with some disadvantages. Here are some of the cons of using AirPlay:
So we recommend AnyMiro as an alternative to AirPlay to mirror screens on Windows or Mac to fix AirPlay icon not showing on Mac. AnyMiro is a cost-effective third-party screen mirroring tool. It depends on robust technology to enable cross-system screen mirroring, making it effortless to transmit content between iOS and Android devices, among others.
When considering the use of AnyMiro, there are some additional advantages and details worth noting.
100% Clean & Safe
100% Clean & Safe
Given these advantages, AnyMiro offers a robust and versatile solution suitable for a wide range of purposes, including high-definition video playback and real-time game streaming. You don’t need to be upset about how to add AirPlay to menu bar.
1. Is screen mirroring the same as AirPlay?
No, screen mirroring is not the same as AirPlay. AirPlay is Apple’s technology for wireless streaming and screen mirroring is a broader term for displaying one device’s screen on another.
2. How to add AirPlay to my iPhone menu?
You can’t directly add AirPlay to your iPhone menu. AirPlay options become available when you have compatible devices on the same Wi-Fi network. You can access these options through the Control Center by swiping down or to the right (depending on your iPhone model) from the top-right corner of your screen.
Now that you know how to add AirPlay to menu bar, you’ll be better equipped to address the issue of the AirPlay icon not showing on Mac. While AirPlay is convenient for screen mirroring, it still has some limitations. Therefore, using AnyMiro for screen mirroring is a better choice, as it can provide you with a lag-free and smooth mirroring experience. Moreover, it supports a wider range of devices. So, feel free to download it and give it a try.
