Wondering how to access Telegram on PC? This guide covers two main options: the desktop app or the web version. You’ll also learn the differences between the mobile and desktop apps. For the best experience, we recommend using AnyMiro—a reliable screen mirroring tool—for seamless access, smooth performance, and easy setup when connecting your mobile to a PC.
Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
Available for both Win & Mac
Want to access Telegram on your PC? Suppose you are using your phone to talk to friends, but now you want a larger screen. It’s easy! There are 3 ways to use Telegram on your computer. First, you must access the app site and download the Telegram desktop application. Do you not wish to download anything? Telegram also has a browser version that can be accessed using any browser just by visiting the website and logging in.
Both are easy and quick and thus always make messaging on your PC exciting. For even better access, we suggest using AnyMiro – a tool that lets you easily mirror and view your mobile screen on your PC! So, let’s begin to explore how to access Telegram on PC!
It is very simple and efficient to utilize the availability of Telegram on your PC to have larger-screen messaging. Whether you use a desktop application or a web-based method, getting started is as swift as a blink of an eye. Now, let’s turn to the process for this!
One method to use Telegram on a PC is to install it on a Desktop. It’s fast and allows you to use telegram from your computer without fuzziness. After installation, one can conveniently use all the features, including instant messaging & calling, without a browser. The most prominent ones are desktop notifications, rapid file sharing, compatibility with large files, and offline mode, which lets you read messages without the Internet. This method is suitable for anyone who wants to share work-related documents or utilize Telegram for professional purposes and desires an application on the desktop. To use this method:
Step 1. Download Telegram for Desktop
Go to the official Telegram website and click the “Get Telegram from Windows” button for the desktop version.
Download Telegram for Windows
Step 2. Install the Software
Once the download is complete, open the file and follow the installation instructions on your screen.
Step 3. Launch the Telegram Software
After the installation, find the Telegram icon on your desktop or in your applications folder and double-click to open it.
Step 4. Login to your Account
Click on “Start Messaging” to continue. Enter your phone number and click “Next.” You’ll receive a confirmation code on your phone.
Start Messaging
Step 5. Enter the confirmation code
Type the code into the app to log in, and you’re all set to start chatting!
Working with Telegram’s web version is incredibly simple and suitable if you do not want to install anything. You can sign in through any browser and start chatting immediately. It comes in handy when using another person’s computer or when you don’t want to install the app. The great thing is that it allows immediate access to all messages, is easily synchronized with other devices to ensure you’re always updated, and doesn’t require any downloads, which makes it very convenient. Here are the simple steps to use Telegram in the Web Version:
Step 1. Launch your preferred web browser and Telegram website.
Step 2. Click on the “Country” option and select your country from the provided list. You can use the search bar to find it faster.
Select Country
Step 3. Enter your phone number. Type your registered phone number (without the country code) in the “Phone number” field, then click “Next.” Confirm your phone number on the pop-up screen.
Step 4. Input the confirmation code. Telegram will send a code to your phone. Enter this code in the “Enter your code” box.
Enter Your Code
Step 5. Once you’ve entered the code correctly, you’ll be redirected to your account automatically.
AnyMiro is a versatile tool that enhances your experience when accessing the Telegram app on a PC. First and foremost, it enables you to display Android and iOS screens and their contents, including audio, cameras, and microphones, on your computer. You can enjoy up to 4K resolution for your phone camera, ensuring crisp visuals while high-quality audio is synchronized without delay.
AnyMiro also lets you record on-screen activities and take high-quality screenshots while mirroring. Plus, you can live stream your screens, audio, and video straight to platforms like YouTube and Zoom. The flexible connection options via Wi-Fi or USB provide stability and convenience for your needs.
Key Features:
Now, let’s explore the steps to use AnyMiro for accessing the Telegram App on a PC:
Mirror iPhone to PC & Mac Via USB:
Step 1. Begin by free download and install AnyMiro on your computer.
Step 2. Open AnyMiro on your computer and select “iOS/iPadOS.”
Mirror iPhone/iPad to Computer
Step 3. Click on the “USB connection” option. Connect your iPhone or iPad to the computer using a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 4. When prompted on your iPhone or iPad, tap “Trust” to establish the connection.
Trust Your Computer on iPhone
Step 5. If required, enter your passcode. Your device is now connected, and you can start high-quality screen mirroring.
Mirror iPhone to PC & Mac Via Wi-Fi:
Step 1. Launch AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Select the “Wi-Fi connection” option.
Step 3. Ensure your iPhone, iPad, and computer are on the same Wi-Fi network.
Computer and iPhone Connect to the Same WiFi
Step 4. On your iPhone or iPad, open the Control Center, tap “Screen Mirroring,” and choose “AnyMiro_Computer Name.”
Step 5. Once your device is detected, you can enjoy high-quality screen mirroring immediately!
Mirror Android to PC & Mac Via USB:
Step 1. Begin by free downloading and installing AnyMiro on your computer, then open the application.
Step 2. Choose the “Android” option to start the connection process.
Mirror Android to Computer
Step 3. Click the “USB” icon and connect your Android phone to your computer with a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 4. On your mobile, enable “USB debugging” and select “MTP Mode” when prompted.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Your phone’s screen will now display on your computer, confirming that the mirroring is successful!
Step 1. First, install AnyMiro on your computer and launch the application. Select the “Android” option from the main menu.
Step 2. Click the “Wi-Fi” icon to start the wireless connection.
Mirror Android to Computer via WiFi
Step 3. On your Android phone, find AnyMiro on Google Play or scan the QR code to download the app.
Download AnyMiro App on Your Phone
Step 4. Open the AnyMiro app on your phone and choose “Wi-Fi Connection.” Select your computer’s name from the list to mirror your phone’s screen.
Tap WiFi Connection
Feature | Telegram App for Mobile | Telegram for Desktop |
Device Compatibility | Available on Android and iOS | Available on Windows, macOS, and Linux |
User Interface | Optimized for touch screens | Designed for mouse and keyboard use |
Notifications | Push notifications on your phone | Desktop notifications for new messages |
File Sharing | Share files easily from your device | Supports drag-and-drop for file sharing |
Media Capture | Capture photos and videos directly | Requires external camera for video calls |
Synchronization | Syncs messages in real-time | Syncs seamlessly with mobile app |
Storage | Limited by device storage | Utilizes computer storage for larger files |
Access | Access anywhere via mobile network | Requires internet connection via Wi-Fi or Ethernet |
Customization | Limited themes and settings | More customization options available |
Voice and Video Calls | Supports voice and video calls | Also supports voice and video calls |
Is it secure to access Telegram on my PC?
Yes, using Telegram on your PC is safe. It securely encrypts your messages to ensure that nobody can read them. It can also be accessed with a web version, but always ensure that you install it from the official website to protect your account.
What are the benefits of using Telegram on a PC?
Telegram on a PC allows for easier typing and a bigger screen, making conversations more comfortable. You can also share files quickly and manage chats efficiently. For enhanced features, we recommend AnyMiro—an all-in-one screen mirroring solution—for live streaming, high-quality audio, and real-time annotations.
Can I use Telegram on multiple devices?
Yes, Telegram users can use the app with different devices simultaneously. Sign in on your PC and mobile using the same phone number. All your messages will sync automatically, allowing you to chat seamlessly across devices.
This article reviewed various means of accessing Telegram on your PC – either through the official Telegram application or an online web-based application. We also provided a comparison of the mobile and desktop versions of the app and its key features. For an improved experience when using Telegram on your PC, we suggest AnyMiro. This tool solves your screen-sharing needs and provides better audio quality, real-time annotation, and live streaming, making your conversations and presentations more efficient.
