FaceTime screen sharing lets you share moments and presentations, but sometimes, you encounter issues. In this FaceTime screen share not working guide, discover practical solutions to effectively troubleshoot FaceTime screen share problems. Learn why screen sharing might fail and explore eight easy methods to resolve it. Plus, find a helpful tip on using FaceTime on a larger screen.
Try AnyMiro to mirror Android & iPhone to PC/Mac for free via USB and WiFi.
Consider yourself on a FaceTime call to discuss a project, a humorous video, or some pictures on your screen, but screen sharing doesn’t work when you try to start it. That is frustrating. This problem can ruin productivity, but thankfully, there are simple FaceTime screen share not working fixes. In this guide, we’ll go over the possible causes of FaceTime screen-sharing issues and provide easy solutions so you can get back to sharing and using calls without any problems.
FaceTime screen sharing can stop working for different reasons. Here are some common FaceTime sharing screen not working reasons that may cause this problem:
Outdated iOS Version
FaceTime screen sharing needs iOS 15 or a newer version. If your iPhone or iPad uses an older version, it may not support screen sharing, which can cause problems.
Weak Internet Connection
FaceTime requires a strong internet connection. If your Wi-Fi or mobile data is weak or slow, FaceTime screen sharing may not work smoothly, causing it to disconnect or freeze.
Settings Restrictions
Your device settings may block screen sharing. FaceTime cannot share your screen as expected if restrictions are set in your “Screen Time” settings.
Device Compatibility
Not all Apple devices support FaceTime screen sharing. Older models may have a different feature, which can prevent screen sharing even if FaceTime itself works.
FaceTime Glitch
Sometimes, FaceTime has temporary glitches that can interfere with screen sharing. These bugs may cause screen sharing to stop working unexpectedly.
Now, let’s explore 8 methods to make FaceTime Sharing Screen Working:
A robust and dependable internet connection is essential for FaceTime screen sharing. Switching to another Wi-Fi network may occasionally be helpful if your existing connection is having issues. FaceTime is less likely to stop or disconnect when the network is steady, guaranteeing uninterrupted screen sharing. Try a different Wi-Fi network to rapidly determine whether a weak or unstable connection causes the problem.
SharePlay is an essential feature for FaceTime screen sharing. If it is off, screen sharing will not function. This feature guarantees you can easily share your screen with other call participants and lets you share content during calls. Double-checking that SharePlay is active can resolve screen-sharing issues by enabling all the settings for FaceTime to work effectively. For this method:
Step 1. Open “Settings” and go to “FaceTime.”
Step 2. Tap “SharePlay” and turn it on.
Turn On SharePlay
FaceTime screen sharing requires iOS 15.1 or later, so your device’s iOS version matters. Running an outdated version could prevent screen sharing from working properly. Confirming that you have the latest version ensures compatibility and often resolves software-related issues affecting FaceTime. By keeping your iOS up-to-date, you ensure that FaceTime screen sharing works with all the latest fixes and improvements. To verify your phone version:
Step 1. Click “Settings,” select “General,” and then select “About” to see what version of iOS you are on.
Step 2. Go to “Software Update” and select “Download and Install” to upgrade if it is less than iOS 15.1.
Check iOS Version
FaceTime might run into temporary glitches that interfere with screen sharing. Closing and reopening the app refreshes its settings and can fix these minor issues. Restarting FaceTime helps clear out any background problems or temporary bugs that could be stopping the screen share function. This simple step can make a big difference and is often enough to get screen sharing working again smoothly. To use this method:
Step 1. To access the app switcher, navigate to the “Home” screen and slide up (or click the Home button).
Step 2. From the list of open apps, locate the “FaceTime” app.
Step 3. Tap the FaceTime symbol to reopen the app after swiping to close it.
Sometimes, the performance of FaceTime can be affected by unusual characters, such as emojis in contact names. Emojis in the contact name of the person you call may result in unforeseen screen-sharing issues. Removing these characters can help FaceTime run more smoothly. This small change can prevent minor software issues and is worth trying if screen sharing isn’t working. To remove emojis:
Step 1. Select the contact you wish to modify by opening the “Contacts” app.
Step 2. Remove emojis from the name by tapping “Edit” in the upper right corner, then click “Done” to save.
Rename Contact
Re-logging into FaceTime refreshes your account connection, which can help resolve any issues with screen sharing. Sometimes, small login issues or errors can cause problems with certain features. By signing out and back in, you’re resetting your FaceTime connection, which can eliminate any account-related glitches affecting screen sharing. To re-login:
Step 1. Open “Settings,” go to “FaceTime,” and tap your Apple ID.
Step 2. Select “Sign Out.”
Step 3. Tap “Use Your Apple ID for FaceTime” and sign in again.
A forced restart can clear temporary bugs or background issues on your device. It’s a bit stronger than a normal restart and can fix small problems affecting FaceTime. By restarting your iPhone this way, you’re refreshing all system settings and apps, which can help restore screen sharing if it was interrupted by a minor glitch or system error. To restart your iPhone:
Step 1. Press and hold the “Power” and “Volume Up” buttons on iPhones without a Home button until the shutdown slider appears.
Step 2. Press and hold the “Side” button for iPhones with a Home button until the slider shows up.
Step 3. Slide to power off, wait 30 seconds, then press and hold the “Power” button to restart your iPhone.
Slide To Power Off
Resetting your network settings can fix connectivity problems that may stop FaceTime screen sharing. This option removes saved Wi-Fi networks and reconnects your device, which can resolve network issues. If the problem with FaceTime is network-related, resetting these settings can provide a fresh start and often improves connectivity, making screen sharing more reliable. To reset network settings:
Step 1. Open “Settings” on your device.
Step 2. Go to “General” and select “Transfer or Reset [Device].”
Step 3. Choose “Reset” and then tap “Reset Network Settings.”
AnyMiro is the ideal screen mirroring tool for experiencing FaceTime on a bigger screen. With high-quality resolution, AnyMiro ensures your FaceTime calls appear clearly, even up to 4K resolution. You can enjoy low-latency audio and video, making your calls feel natural and synced in real time. AnyMiro also offers easy streaming to popular platforms like YouTube, Twitch, or Facebook, allowing you to share your FaceTime calls live.
It also features real-time annotation to mark important points on your screen, making interaction easier. Plus, you can capture and record your FaceTime sessions with the screenshot and screen recording features, saving important moments. Whether you’re using it for personal calls or professional meetings, AnyMiro provides a seamless experience for using FaceTime on a larger screen.
Key Features:
Here are the simple steps to use AnyMiro:
Screen Mirroring Facetime to PC Via USB:
Step 1. Free download AnyMiro on your computer. Open AnyMiro on your computer and choose “iOS/iPadOS.”
Mirror iPhone to Computer
Step 2. Choose the “USB connection” option. Through a USB cable, link your phone to the computer.
Connect Your iPhone/iPad with a USB Cable
Step 3. Continue by tapping “Trust” to make the connection.
Trust Your Computer on iPhone
Screen Mirroring Facetime to PC Via Wi-Fi:
Step 1. Open AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Select the “Wi-Fi connection” option.
Step 3. Check that your device and computer are on the same Wi-Fi network.
Step 4. On your iPhone or iPad, open the Control Center, tap “Screen Mirroring,” and choose “AnyMiro_Computer Name.”
Step 5. Once detected, you can enjoy high-quality screen mirroring immediately!
Why is my screen share on FaceTime blurry?
Poor Wi-Fi connectivity or network congestion usually causes a fuzzy screen when you share. This should be sorted by ensuring that the firmware of all your devices is up to date and that the connectivity to your Wi-Fi is strong.
If FaceTime screen sharing is disconnecting, what can I do?
Check the stability of your Wi-Fi connection if FaceTime is constantly disconnecting. You can also restore your iPhone and update iOS and apps to smooth screen-sharing process during face-time calls.
Can I mirror my iPhone screen through FaceTime to my computer?
It can mirror your iPhone screen to your computer while FaceTime chats with AnyMiro. This provides a larger and smoother viewing experience. Follow the setup steps to connect your devices.
FaceTime screen sharing works well, but issues like a weak connection or outdated software can be fixed by updating, checking your network, or restarting. If you still have problems with FaceTime screen sharing, a third-party tool can be useful. AnyMiro is a great choice since it makes it simple to mirror your iPhone screen to your computer, giving you a quality, seamless FaceTime or other call experience.
