Download AnyMiro to AirPlay iPhone without WiFi
Available for both Win & Mac
Do you need Wi-Fi for AirPlay? You may get the answer from this article.
Can I AirPlay Without WiFi? Yes!
For many Apple users, AirPlay is a powerful tool that allows them to stream content from their Apple devices directly to an Apple TV, a Mac, or other compatible devices. You might think that a stable Wi-Fi connection is essential for mirroring your device’s screen, but what if I told you there are other ways to achieve the same result without relying on a functional Wi-Fi network? Can you still use AirPlay to mirror your device’s screen on your TV what if you don’t have access to Wi-Fi?
In this article, we will explore ways to use AirPlay without a Wi-Fi connection, so you can enjoy your favorite content on your TV, no matter where you are or what type of internet connection you have available. Let’s find out!
AirPlay is a feature of Apple devices that allows users to stream media from their iPhone, iPad, Mac, or iPod touch directly to an Apple TV or other AirPlay-enabled device. This technology uses a wireless connection to send audio and video data between the user’s device and the receiver, allowing for high-quality playback without any loss.
AirPlay supports remote control so you can use your Apple device as a remote control for your smart TV. In addition, AirPlay is compatible with all Apple devices, therefore, Apple users don’t have to worry about compatibility issues.
However, AirPlay also has some drawbacks such as streaming the same content across multiple receivers without allowing them to access separate content and so on.
The short and straight answer to this question is Yes! To use AirPlay, users must first ensure that their device and the receiver are connected to the same Wi-Fi network or have an active internet connection. Once connected, users can select the media they want to share, whether it’s photos, videos, or audio clips. From there, they can either mirror their screen or play the media through the receiver’s speakers.
Here are the steps to AirPlay content from your iPhone or iPad to a TV or Mac:
Step 1. Connect both of your devices to the same Wi-Fi network.
Connect both Devices to the Same Wi-Fi Network
Step 2. Find the video that you want to stream and tap the AirPlay icon in the app ( In some apps, you might need to tap a different button first. For example, in the Photos app, tap Share, then tap AirPlay).
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Step 3. Select your TV or Mac name from the available device list.
Step 4. Once connected, you can see your iPhone/iPad content is mirrored to the TV or Mac screen.
To stop streaming, tap AirPlay in the app that you’re streaming from, then tap your iPhone or iPad from the list.
As you can see in the title, it tells you the answer to the question “Do I need WiFi to AirPlay?” is Yes and No. The above part has already told you the common AirPlay method using a WiFi connection, then how to AirPlay without WiFi? Keep reading and check the two methods here:
Using peer-to-peer AirPlay allows for streaming without the need for both devices to be connected to the same Wi-Fi network. In this part, we’ll take TV as an example to tell you how to AirPlay to TV without WiFi. Here’s how to do it:
Step 1. Turn on the Bluetooth and Wi-Fi but don’t let your devices get connected to any Wi-Fi.
Step 2. Launch the Control Center and click on the Screen Mirroring icon. Select your TV from the list of available devices.
Step 3. If you have never paired your iPhone and TV, the phone will ask for a four-digit code. You will see this code appear on your TV screen.
Step 4. Enter this code and click on OK. Now your phone screen will be cast to your TV and you have successfully AirPlayed to your TV without WiFi.
You can also use an Apple Lightning Digital AV Adapter to connect your iOS device to an Apple TV without Wi-Fi:
The Apple Lightning Digital AV Adapter
Step 1. Connect the Lightning digital AV adapter to your iPhone.
Step 2. Plug in one end of an HDMI cable into the HDMI port of the AV adapter and connect the other end to the HDMI port of your TV.
Step 3. After performing the above steps, you will get your screen on the TV.
AirPlay iPhone actually mirrors the iPhone’s screen to a bigger one. Besides using the traditional method, you can also rely on a third-party screen mirroring tool. What’s more, AirPlay doesn’t provide service for Android users.
Therefore, the third-party screen mirroring tool recommended here is AnyMiro, which can share the screen from your phone to your PC without limit.
AnyMiro is a screen mirroring app that enables screen mirroring of both Android and iPhone screen to PC using a USB and wirelessly. It’s simple and easy to use. You can enjoy the service provided by AnyMiro for the following reasons:
Steps to Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Connect Your iPhone/iPad with a USB Cable
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Steps to Mirror Android to PC via USB
Step 1. Download to get the AnyMiro desktop version, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro that tells you how.
Enable USB Debugging
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your PC.
Enable USB Debugging and MTP Mode for a USB Connection
1. Does AirPlay affect sound quality?
AirPlay doesn’t affect sound quality. In fact, AirPlay supports playing high-quality lossless audio files.
2. Why is my AirPlay not working?
You may wonder why your AirPlay not working. Here are several reasons for this problem. First, AirPlay-compatible devices are turned off and far away from each other. Second, the devices are not updated with the latest software. And third, they are not on the same Wi-Fi network.
3. What devices are compatible with AirPlay?
Apple has published a list of compatible airplay devices, which includes the following:
Devices You Can Stream Audio From Using AirPlay
Devices You Can Stream Video From Using AirPlay
Does AirPlay need WiFi? The answer is yes and no. You can use AirPlay with or without a Wi-Fi network to enjoy a mirroring experience. Peer-to-peer AirPlay and Apple Lightning Digital AV Adapter are two methods mentioned in this article for using AirPlay without Wi-Fi. We also recommend using the AnyMiro app to achieve screen sharing between two different devices, as its compatibility is better and more convenient.
