How to Cast Safari to Chromecast
Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror How to Cast Safari to Chromecast
Wondering how to cast Safari to Chromecast? This guide shows you how to stream from your Mac, iPhone, or iPad to your TV with easy steps. You’ll learn the basics and get useful tips. We recommend using AnyMiro—an efficient screen mirroring tool—for fast connection, high-quality 4K display, and smooth performance when casting from iPhone to PC.
Joy Taylor | Last Updated: Oct. 22, 2024
1467 words|5minute
Ever want to watch something from Safari on your TV? Perhaps you wish a video you’re watching on your Mac or iPhone could be seen on a larger screen. This is feasible with Chromecast and Safari! However, there is quite an easy way to do this, even though Safari does not have a cast button. In this guide, we will show you the best way to cast Safari to Chromecast. Suppose you require a rapid and effective method to directly mirror your iPhone to a PC while getting great image quality and continuous streaming. In that case, AnyMiro is the perfect screen mirroring software we recommend. Now, let’s get going!
What You’ll Need: Chromecast and Compatible Devices
The Chromecast streaming device can be connected to the HDMI port at the back of the television, making it possible to share any form of content on your different devices on the television. It supports Android, iOS, Mac OS, and Windows. This implies that streaming from cellphones, tablets, and PCs is convenient. Make all your devices connect to the same Wi-Fi network, so Chromecast streaming does not stop. Some widely used streaming sites can easily stream to Chromecast, thus making it easy to view on a big screen. To get the greatest performance, make sure your devices are updated.
Casting Safari from Your Mac to Chromecast
If you desire to cast Safari on your Mac to your Chromecast TV, you can do this using Google Chrome. Unfortunately, Safari does not offer a cast option directly; however, this technique helps extend Mac’s browser tabs, videos, and even other applications straight to the TV. It’s simply a matter of opening Google Chrome, enabling the casting of the entire desktop, and then opening Safari. This way, all you see on your Mac’s screen – including Safari – will be mirrored on your TV. To cast from Safari to Chromecast:
Step 1. Open Chrome on your Mac, click the three-dot icon at the top right corner, and choose “Save and Share.”
Step 2. Click “Cast” to open the casting menu in the sharing options.
Select Save And Share and Choose Cast
Step 3. Click on “Sources” and then select “Cast screen” to mirror your entire display.
Step 4. From the list of available devices, select your Chromecast TV, and your Mac’s screen will start casting.
Step 5. Now, switch to the Safari browser on your Mac, and you can enjoy viewing your Safari content on the TV screen.
Casting Safari from Your iPhone/iPad to Chromecast
If you want to cast Safari from your iPhone or iPad to Chromecast, you can use an application named MomoCast. This app allows you to cast the Safari browser directly onto the television with the least complexity.
One of its strengths is the easy video navigation, which enables you to access video from different sites on the internet and display it on your TV. Furthermore, MomoCast allows you to display your web page full-screen. Hence, it suits the purpose of sharing content during a presentation or with family members. Check out the steps below to use MonoCast for casting Safari from your iPhone/iPad:
Step 1. Begin by installing the MomoCast app on your iOS device.
Step 2. Launch the Safari app on your device.
Step 3. Tap the “Share” button at the Safari screen’s bottom.
Tap on Share
Tap on Share
Step 4. From the options, choose “Cast with MomoCast.” This will take you to the MomoCast browser.
Select Cast with MomoCast
Step 5. Tap on your Chromecast device to establish the connection.
Step 6. Tap the Cast icon in the top right corner, then select “Mirror Screen” to display your Safari browser on the TV.
Select Screen Mirror
[Bonus Tip] Cast iPhone to PC Easily with AnyMiro
AnyMiro is an excellent solution that can assist if you’re looking for a simple approach to cast Safari from your iPhone to your PC. It allows you to mirror your iPhone’s screen to your PC in 4K quality for 10 hours non-stop. You can easily mirror your screens, audio, cameras, and microphones using AnyMiro.
It supports multi-device streaming, allowing you to connect several devices at once, each displaying different content. You can even make real-time recordings and take high-quality screenshots while mirroring. Additionally, AnyMiro lets you live stream directly to platforms like YouTube and Zoom. Whether you prefer a Wi-Fi connection or a stable USB cable, AnyMiro offers flexibility in how you connect.
Key Features:
Now, let’s explore the steps to use AnyMiro for casting iPhone to PC:
Mirror iPhone to PC Via USB:
Step 1. Start by free downloading and installing AnyMiro on your computer.
Step 2. Using a USB cable, connect your mobile to the computer.
Step 3. Open AnyMiro on your computer and select “iOS/iPadOS.”
Mirror iPhone to Computer
Step 4. Click on the “USB connection” option.
Connect Your iPhone/iPad with a USB Cable
Step 5. Continue the process by tapping “Trust” to make the connection.
Trust Your Computer on iPhone
Step 6. If needed, enter your passcode. Your device is now connected, and you can start high-quality screen mirroring.
Mirror iPhone to PC Via Wi-Fi:
Step 1. Launch AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Select the “Wi-Fi connection” option.
Step 3. Ensure your iPhone, iPad, and computer are on the same Wi-Fi network.
Step 4. On your iPhone or iPad, open the Control Center, tap “Screen Mirroring,” and choose “AnyMiro_Computer Name.”
Select AnyMiro to Mirror iPhone to MacBook Bluetooth
Step 5. Once your device is detected, you can enjoy high-quality screen mirroring immediately!
FAQs on Cast Safari to Chromecast
What should I do if I can’t connect to Chromecast?
If you are facing connection issues with Chromecast, you need to ensure that your devices are connected to the same Wi-Fi. Turn off Chromecast and the casting device and turn them on again. You must also check for any software updates.
Is there a recommended tool for easier screen mirroring?
We recommend AnyMiro as an all-in-one screen mirroring solution. It makes it simple to stream videos from the internet, mirror devices in 4K quality, and capture screen activity. Its easy-to-use interface makes connecting via USB or Wi-Fi a breeze.
What if I experience lag while casting?
If you notice lag when casting, try reducing the distance between your router and Chromecast. Make sure no other heavy devices are using the same Wi-Fi. Using a wired connection for your computer can help, and we recommend AnyMiro—an all-in-one screen mirroring solution—for its features like high-quality recording, low latency audio-visual synchronization, easy device connection, and multi-device support.
Final Words
Finally, casting Safari to Chromecast is great for watching your favorite shows and videos on a larger screen. Through the easy steps described above, you can thus share your online experiences with friends and family. Tools like MomoCast simplify this process, but AnyMiro stands out for its high-quality 4K screen mirroring, support for multiple devices, and flexible connection options. We recommend using AnyMiro to enhance your streaming experience, making it easy to connect and enjoy your content seamlessly!
Joy Taylor
