Casting from Chrome on Android to various devices can make viewing easier and more enjoyable. This article covers simple techniques for casting to a PC, Mac, or TV. These cast from Chrome Android options include Chromecast for TVs and AnyMiro for a smooth screen mirroring experience on PCs. Anyone can easily follow the step-by-step directions for useful guidance and cast anything on a bigger screen for entertainment!
Try AnyMiro to mirror Android & iPhone to PC for free via USB and WiFi.
Imagine you want to share a picture, movie, or website with others from your Android phone, but everyone is huddled together, straining at the little screen. What if it was simple to project onto a bigger screen, such as a TV, Mac, or PC?
Being capable of casting content from one device to another has revolutionized media consumption in today’s digital world. Casting from your Android device with Chrome offers options, whether you want to share presentations, stream videos, or display images. This cast from Chrome Android tutorial explains how to use Chrome on your Android device to mirror mobile screens to TV or AnyMiro for PCs for a better visual. These instructions make it easy to share your favorite content with others, whether using Chromecast to connect to a TV or AnyMiro to cast to a computer.
Wi th the help of the robust screen mirroring tool, i.e., AnyMiro, you can effortlessly project your Android screen onto a Mac or Windows PC. AnyMiro has amazing features and is made for gamers, content creators, and anybody who wants to share a mobile display on a bigger screen. A stable and smooth connection ensures up to 10 hours of continuous, lag-free streaming, ideal for extended gameplay or live presentations. Up to 4K is supported by the high-resolution quality, which keeps every detail crisp and visible on your computer screen.
Your game sounds, and on-screen movements will always be perfectly synced thanks to audiovisual synchronization, which makes it ideal for live streaming on websites like Twitch or YouTube. Screenshot and recording features make it easy to capture special moments, while live annotation enhances tutorials and presentations by enabling real-time involvement.
Key Features:
Now, let’s explore the simple and easy steps to use AnyMiro for casting Android to PC & Mac:
Step 1. Free download AnyMiro on your computer and open the application. Choose the “Android” option to begin connecting.
Mirror Android to Computer
Step 2. Continue by choosing the “USB” icon and connecting your phone to the computer through a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 3. On your phone, turn on “USB debugging” and select “MTP Mode” when prompted.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Your phone’s screen will now appear on your computer, indicating successful mirroring!
Mobile Screen Mirrored on the Computer with AnyMiro
Step 1. Free download and install AnyMiro on your computer and launch the application.
Step 2. From the main menu, select the “Android” option. Click the “Wi-Fi” icon to start the wireless connection.
Mirror Android to Computer via WiFi
Step 3. Download the AnyMiro app from Google Play or scan the QR code on your Android phone.
Download AnyMiro App on Your Phone
Step 4. Open the AnyMiro app on your phone and select “Wi-Fi Connection.”
Select the Connection Method
Step 5. Choose your computer’s name from the list to mirror your phone’s screen.
Select Your PC to Access Android from PC
Watching videos on a bigger screen is easy and exciting when you use Chromecast to project content from Chrome on your Android device to your TV. With a few clicks, you can share some of your favorite content onto a larger screen to enhance the viewer experience and make it more suitable for presentations.
It easily streams photos, movies, and even your favorite websites from your phone. So you can share what is on your phone with friends and family. Chromecast gives your digital content a new perspective on life by enabling you to stream straight from your Android device’s Chrome browser. Additionally, casting allows you to continue using your phone for other purposes, which makes it a practical entertainment choice. Here’s how to cast from Chrome mobile to TV:
Step 1. Plug the Chromecast into your TV’s HDMI port and connect the other end to a USB port on your TV (if available) or a power outlet.
Step 2. If the Google Home app is not already on your phone, install it from the app store.
Step 3. Open the app, go to the “Devices” tab, and tap “Add.”
Step 4. Select “Google Nest or partner device,” then pick a home for your Chromecast.
Choose Google Nest Or Partner Device
Step 5. Wait as the app searches for your Chromecast. If it’s found, tap “Yes” or select “Chromecast / Google TV” from the list if needed.
Choose Chromecast / Google TV
Step 6. When a QR code appears on your TV, scan it with your phone to connect.
Step 7. Review the terms, select where the Chromecast is located, and follow the prompts to connect to Wi-Fi.
Step 1. Open the video page in Google Chrome on your Android device.
Step 2. Tap the video player to show the controls. Look for the “Cast” icon in the bottom right corner.
Step 3. Tap the “Cast” icon and select your TV to start casting the video.
Select TV Model
Step 4. To control the video, tap the player to access the controls. You can tap on the progress bar to jump to different video parts.
Step 4. If the controls are hidden, a “Casting” message will show where the video is playing.
Step 5. To stop casting, tap the “Cast” icon and select “Stop casting.”
What to do if the Cast icon doesn’t show up?
If the Cast icon doesn’t appear, check if your Android device and TV are on the same Wi-Fi network. If the icon still doesn’t appear, restart both devices. This usually helps solve the issue quickly.
Can I cast from any app on my Android device?
No, you cannot cast from every app. You can only cast to TV from apps that support Chromecast. Most popular streaming apps, like YouTube and Netflix, have this feature. If you want to cast more apps easily on your PC, consider using AnyMiro. It allows you to mirror your screen from any app, giving you more options to share content.
Do I need Wi-Fi to cast from Chrome Android?
To cast your Android handset to your TV, you need Wi-Fi. Make sure the TV and your device are linked to the same wireless network. Casting will not work without a shared network.
To sum up, casting content from Chrome on your Android device to your Mac, PC, or TV provides a simple way to see your favorite media on a larger screen. Your viewing experience can be improved by using apps like AnyMiro or by following the easy instructions for Chromecast. If you want to mirror your full screen smoothly, AnyMiro is a great option. It provides low-latency streaming, high-quality screen mirroring, and support for Wi-Fi and USB. You can easily share games, videos, and pictures with AnyMiro, making it ideal for all your casting requirements!
100% Clean & Safe
100% Clean & Safe
