Screen mirroring app you can try: AnyMiro
Available for both Win & Mac
Discover how to cast Android screen to PC without Chromecast. Our complete guide offers simple yet effective solutions.
Android screen mirroring with Chromecast has been popular for years. But not everyone has access to this device.
Nor is it always the most practical solution.
So are you looking for an alternative approach?
In this article, we’ll show you how to cast Android screen to PC without Chromecast. We’ll show you how to do it via both USB and Wifi. And then, as a bonus tip, we’ll show you how to cast an Android screen on a TV.
Cast Android screen to PC without Chromecast
But before we start the stepwise guide, let’s first explore what a Chromecast is.
Chromecast is a media player developed by Google. These devices are designed as small dongles.
Chromecast lets users play content on a high-definition television or home audio system. Its primary function is to stream from the internet directly onto your TV. Chromecast does this by plugging directly into the HDMI port of your TV. Then you can connect it to your home Wi-Fi network to stream from Netflix, YouTube, Spotify, and more.
But the functionality of Chromecast doesn’t end here! It’s another useful feature to cast the mobile screen onto TVs.
Chromecast Device from Google
Now you may be thinking,” What are the situations where we may need to cast Android screen to Chromecast?”
So let’s explore some of these situations!
Why do Android Users Need Chromecast?
Chromecast’s screen mirroring feature offers users a variety of benefits. Here are some of the most important ones.
However, all these benefits are when we consider TVs. And we all know that computers provide much more controlling features than televisions.
So if you want to cast your Android screen to a PC, Chromecast is powerless.
But the world doesn’t end just on Chromecasts, does it? There are still many ways to achieve this feat.
Let’s see how to cast Android screen to PC without Chromecast.
If you want to cast Android screen to PC without Chromecast, you’ll need some third-party tool. With the right tool, this process is simpler than you think. And that’s where AnyMiro steps in!
AnyMiro is a powerful tool that bridges your Android device and your PC. This tool enables you to cast Android screen to PC without Chromecast.
It supports both Windows and Mac operating systems. Moreover, it offers various amazing features for your screen mirroring needs. And the best thing of all, you can enjoy all these features with a 40-min limit for free.
You can use AnyMiro for screen mirroring Android to PC free in two ways. The first method requires a USB, while the other just needs a wifi connection.
Cast Android Screen to PC via USB
Here’s a step-by-step guide to cast Android screen to PC via USB.
Step 1. First, download & install AnyMiro on your PC. Once you launch the software, select the “Android” option from the opening interface.
Select “Android” from the Opening Interface of AnyMiro
Step 2. Connect your Android device to your PC using a USB cable. On the AnyMiro interface, select the USB icon.
Connect Your “Android” Phone with a USB Cable
Step 3. On your Android device, ensure that “USB debugging” and “MTP Mode” are turned on.
Enable USB Debugging and MTP Mode for a USB Connection
And your Android device screen will be mirrored on your PC.
Mobile Screen Mirrored on the Computer with AnyMiro
Now that you have seen how to cast Android screen to PC via USB, let’s move on to the wifi method.
Cast Android Screen to PC via WiFi.
For a wireless connection, follow the steps below:
Step 1. Launch the AnyMiro software on your PC and select the “Android” option from the opening interface.
Step 2. For a WiFi connection, select the WiFi icon on the AnyMiro interface.
Once installed, open the app and select the “Wi-Fi Connection” option.
Connect Your “Android” Screen via Wi-Fi
Step 3. Select the name of your PC from the list of available devices in the AnyMiro interface. Ensure your PC and Android device are connected to the same network.
Once done, your Android screen will be mirrored on your PC.
And that’s all! Isn’t it easy?
If you are still considering whether to use AnyMiro, let’s look at its key features.
Then you’ll definitely choose AnyMiro to cast Android screen to PC without Chromecast!
Key Features of AnyMiro:
Here are the key features that AnyMiro provides.
What? Still don’t want to use AnyMiro?
No worries! Let’s look at an open-source tool that can cast Android screen to PC without Chromecast.
Scrcpy is a potent open-source tool that efficiently casts your Android screen to your PC. This remarkable application operates using an ADB connection over USB. So there’s no need for a rooted device.
Scrcpy distinguishes itself with its excellent features. Firstly, it offers very low latency with minimal delay. Secondly, it also enables direct recording of gameplay onto the PC. Developers can use Scrcpy for real-time app testing. Plus, being open-source, Scrcpy is accessible to everyone.
Steps for Screen Mirroring Android to PC Free
To use Scrcpy, follow these steps:
Step 1. Download Scrcpy on your PC. You can find the files on GitHub. Depending on your OS, you can download either bit32 or bit64 version.
Download the Scrcpy File from GitHub
Step 2. A Zip file will be downloaded. Go to your “Local Disk (C) “ and then make a new folder with the name “scrcpy.” Unzip the downloaded file in this folder. Then create a desktop shortcut of the “scrcpy” file.
Unzip the File in Local Dis (C) and Create a Desktop Shortcut
Step 3. Enable USB debugging on your Android device. You can do this in the Developer Options menu in the Settings app.
Enabling USB Debugging in an Android Phone
Note: If you don’t see the Developer option in Settings, go to About Phone > Software Information. Then click on the “Build Number” seven times.
Step 4. Install the Universal ADB drivers on your PC if you don’t have them.
Install the Universal ADB Drivers on Your PC
Step 5. Now connect your Android device to your PC using a USB cable. Then select “Transfer files” from the USB settings on the Android phone.
Select the “Transfer file” Option from Your Android Device
Step 6. Now go to the desktop and right-click on the “scrcpy” file shortcut” Then click on “Run as Administrator.”
Run the Scrcpy File as an Administrator
And that’s all! A black screen will appear first, and then your screen mirroring Android to PC free will be successful.
Android Screen Mirrored to the PC
You have learned how to cast Android screen to PC without Chromecast.
But Chromecast is still a better solution if you want to cast your mobile screen to a smart TV. Therefore, before our guide ends, let’s give you a bonus tip. We’ll now see how to cast Android screen to Chromecast.
You can cast your Android screen directly to a Smart TV for a larger display than a PC. And it will utilize the free Google Chromecast feature.
Steps to Cast Android Screen to TV
Here’s how to do it.
Step 1. Connect a Chromecast device to your smart TV using the HDMI port.
Step 2. Ensure that your Android device and Chromecast-enabled TV are connected to the same Wi-Fi network.
Step 3. Download & install the Google Home app from the Google Play Store on your Android device.
Install Google Home on Your Device
Step 4. Launch the Google Home app. The app will display the available devices on your network. Tap on the name of your Chromecast-enabled TV.
Step 5. Now, tap on the “Cast my screen” button at the bottom of your screen.
Cast Your Screen Using Google Home
Step 6. A prompt will appear on your device. Tap on “Cast screen” to start mirroring.
Your Android screen should now be visible on your TV. Everything you do on your Android phone will now be mirrored on the TV screen.
To stop casting, return to the Google Home app and tap “Stop mirroring.” Remember that the smoothness of the mirrored content will depend on the speed & stability of your Wi-Fi connection.
Are you wondering how to cast Android screen to PC without Chromecast? Using tools like AnyMiro and SCRCPY, you can easily achieve this feat!
Both these tools offer unique advantages. AnyMiro is popular for its remarkable performance and extensive feature set. In comparison, SCRCPY is known for its open-source accessibility. So if you want to cast your Android screen to your PC, AnyMiro and SCRCPY are excellent options.
