How to Fix AirPlay Won’t Show Video Only Sound
A full guide on troubleshooting AirPlay won’t show video for IOS users. A step-by-step solution and an ideal alternative app are provided.
Joy Taylor | Last Updated: Nov. 23, 2023
1804 words|6minute
“Suddenly when I attempt screen mirroring from iPad and iPhone through Apple TV to smart TV, the screen goes completely black with the sound is still there though. Yesterday I updated the software – everything is fine except I still can’t mirror my devices. How come when I do screen mirroring no video only audio?”, is an IOS device user question on the internet. Have you ever encountered the same situation when AirPlay won’t show video?
As we are all aware, AirPlay is a crucial feature of the Apple ecosystem that enables effortless sharing of media, expanding entertainment experiences, and promoting collaboration. It has a significant impact on entertainment, productivity, and communication, enhancing the way users interact with their devices and media content. If you are experiencing issues with screen mirroring on your device, reading this article carefully can help you acquire some skills or knowledge to solve the problem.
Why Does AirPlay Have Sound But No Picture?
AirPlay won’t show video when trying to mirror content. There are several reasons why screen mirroring sound but no picture iPhone:
- Network issues: A weak or unstable Wi-Fi connection can cause inconsistent data transfer, resulting in delays or interruptions in the video stream while the audio continues to play.
- Device compatibility: Incompatibility between the sending device (e.g. iPhone, iPad, Mac) and the receiving device (e.g. Apple TV, AirPlay-enabled TV) can cause problems with the transmission of both audio and video. Some older devices may have limitations in handling certain video formats.
- Software bugs: Software glitches or bugs in the operating system of either the sending or receiving device could cause inconsistencies in how audio and video are processed during AirPlay streaming.
- Hardware limitations: Older hardware may have difficulty processing both audio and video streams simultaneously. This can lead to scenarios where one element of the stream is prioritized over the other.
- Interference: Interference from other electronic devices, such as microwave ovens or cordless phones, can interrupt the video signal while allowing the audio to continue uninterrupted.
- Settings or configuration: Incorrect settings or configurations on either the sending or receiving device can cause audio to be transmitted while the video is blocked or not displayed properly.
- Updates required: Outdated software on either the sending or receiving device may not be fully compatible with the latest AirPlay features, resulting in video transfer problems.
Fixes You Can Try: Make AirPlay Show Video Again
Resolving the issue of AirPlay won’t show video during AirPlay streaming often involves troubleshooting network connectivity, updating devices and software, checking compatibility, and ensuring correct settings. If the problem persists, you may need an individualized solution such as addressing problems of airplay on Apple TV, Samsung TV, and iPhone/Mac. In this part, a troubleshooting guide can help pinpoint and address the specific causes.
1. Basic Troubleshooting
- Network issues: Make sure both devices (e.g., Apple TV, and AirPlay-enabled TV) are connected to the same Wi-Fi network. If your AirPlay won’t show video either After checking they are both on the same Wi-Fi connection. Then you can power cycle your Wi-Fi router by unplugging it, waiting for a minute, and then plugging it back in. But if the problem still exists, you may need to Change the Wi-Fi Channel.
Connect to the Same WiFi
- Device compatibility: If you have verified that both the sending device (e.g., iPhone, iPad, Mac) and the receiving device (e.g., Apple TV, AirPlay-enabled TV) are officially listed as compatible with AirPlay. Then you need to ensure that both devices have the latest software updates installed and confirm that the video format you’re trying to AirPlay is supported by both the sending and receiving devices.
- Hardware limitations: Hardware limitations can sometimes be challenging to overcome, especially if the devices do not meet the necessary requirements for smooth screen mirroring. So, you need to check the hardware requirements for the specific screen mirroring technology you’re using. Ensure that your devices meet the necessary specifications for smooth mirroring. Keep in mind that if you are using wired screen mirroring, ensure that you’re using compatible cables and adapters. Using non-standard or faulty cables can lead to video issues.
- Software bugs: Make sure both the sending and receiving devices have the latest software updates installed.
Software Updates on iPhone
Resolving the issue of AirPlay won’t show video during AirPlay streaming often involves troubleshooting network connectivity, updating devices and software, checking compatibility, and ensuring correct settings. The part below aims at specific cases. You can refer to the solution according to your circumstances.
2. Solutions for AirPlay Won’t Show Video on Apple TV
If you’re experiencing issues where AirPlay won’t show video on your Apple TV, there are several troubleshooting steps you can take to resolve the problem. Here’s a framework guide to help you out:
- Check Network Connection
- Verify Device Compatibility
- Update Software
- Restart Devices
- Restart Network Equipment
- Check AirPlay Settings on Apple TV
- Adjust Resolution Settings
- Disable VPN or Proxy
- Check Router Settings
- Disable Bluetooth
- Check Other AirPlay Sources
- Test with a Different App
- Test with a Different Apple TV
*Contact Support: If none of the above steps resolve the issue, contact Apple Support for further assistance.
3. Fix AirPlay Won’t Show Video on Samsung TV
Apple TV’s AirPlay is seamless for Apple users, while Samsung TV’s AirPlay offers limited features for Samsung users. Their differences in hardware, software, and ecosystem priorities affect the user experience. If you screen mirroring sound but no picture iPhone on a Samsung TV, try solutions here below:
- Check Device Compatibility: Ensure that your sending device (iPhone, iPad, Mac) and your Samsung TV are compatible with AirPlay. Check that your TV model supports AirPlay.
- Update TV Firmware: Make sure your Samsung TV has the latest firmware update installed. Outdated firmware can cause compatibility issues with AirPlay.
- Update Sending Device: Ensure your sending device (e.g., iPhone, iPad, Mac) is running the latest version of its operating system.
- Restart Devices: Restart both your sending device and Samsung TV to clear any temporary glitches.
- Connect to the Same Wi-Fi Network: Make sure your sending device and Samsung TV are connected to the same Wi-Fi network.
- Check AirPlay Settings on TV: On your Samsung TV, go to the AirPlay settings and make sure AirPlay is enabled. Ensure that your TV is set to allow connections from all devices or from your specific sending device.
- Disable Bluetooth on Sending Device: Sometimes, Bluetooth interference can affect AirPlay connections. Try disabling Bluetooth on your sending device.
- Check Other AirPlay Sources: Test AirPlay from a different sending device to determine if the issue is specific to one device.
- Restart Router: Power cycle your Wi-Fi router by unplugging it for about 30 seconds and then plugging it back in.
- Check TV Input Source: Ensure that your Samsung TV is set to the correct input source where the AirPlay signal is being received.
*Contact Support: If none of the above steps resolve the issue, you can contact Samsung customer support for further assistance.
4. Solve AirPlay Won’t Show Video on iPhone/Mac
If you’re experiencing issues where AirPlay won’t show video on your iPhone or Mac when trying to mirror or stream content, you can follow this guide to troubleshoot and resolve the problem:
- Update Software
- Check AirPlay Settings: On your sending device, open the Control Center (iPhone/iPad) or menu bar (Mac) and select the AirPlay icon. Make sure the correct receiving device is selected.
- Check Content Compatibility
- Disable Bluetooth
- Test Different Content
- Test Different Receiving Device
- Restart Wi-Fi Router
AirPlay Alternative for Computer: AnyMiro
The content above has provided you with a comprehensive solution for screen mirroring sound but no picture iPhone. But what if AirPlay iPhone/iPad to a computer, AirPlay won’t show video? There might be various scenarios including presentations or workshops, content sharing or collaboration and creativity, etc., when users want to AirPlay content from their iPhone or iPad to a computer (Mac or Windows PC). It would be terrible if you encountered the issue of an AirPlay error on your computer. Don’t worry, a third-party software – AnyMiro will be your ideal alternative since AnyMiro can provide you with:
- Stable and lag-free connection for mirroring
- The best resolution – up to 4K
- Immersive audiovisual streaming experience
Screen mirroring on the computer through AnyMiro, you will experience:
- Stream your favorite mobile games with stable, smooth, lag-free screen mirroring. Bring your game live streaming to the next level.
- Effortlessly screen mirror your creation session and live stream them to any live platform to shout out your talent and creativity.
Come on, don’t hesitate to download this wonderful App to decorate a better life.
AnyMiro – Real-Time Screen Mirroring Tool
- More than 10 hours of stable screen mirroring connection.
- Up to 4K resolution providing a stunning visual experience.
- Integrates with live streaming tools such as OBS and Streamlabs.
- Auto-sync video and background audio with timestamp adjustments.
Screen mirroring is indeed important for us to share our creations and ideas with friends, colleagues, audiences, etc. However, AirPlay won’t help with these activities. Not only AirPlay won’t show video, but also won’t work at all. You can troubleshoot the issues one by one according to the solutions above. But, if you want a once-for-all way to solve troubles brought by AirPlay, you should try AnyMiro, your reliable, stable, and trustworthy screen mirroring friend.
Joy Taylor
