Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Encountering AirPlay unable to connect issue can be frustrating for many users. In this article, we will explore various troubleshooting techniques to fix this problem and help users enjoy uninterrupted media streaming.
AirPlay is a convenient feature that allows Apple users to wirelessly stream media from one device to another using a local connection, typically via a home WiFi network. It’s a popular wireless tool that provides users larger screen view and improves their mirroring experience. Technology changes lives.
However, there are times when users encounter the “AirPlay Unable to Connect” issue, preventing them from establishing a connection between their iPhone, iPad, or Mac and Apple TV or AirPlay-compatible TVs. Don’t worry. In this article, we will explore several troubleshooting techniques to help you fix the AirPlay Unable to Connect issue and enjoy uninterrupted media streaming.
Before we start fixing the problem, we should know first why it is occurring. AirPlay may be unable to connect due to various reasons. Here are some possible causes for this issue:
AirPlay is not compatible with all devices. Therefore, you should ensure that all your devices involved in the AirPlay connection, such as iPhones, iPads, Apple TVs, and TVs, are compatible with AirPlay. Refer to the list of compatible devices provided by Apple or the device manufacturers.
It is possible that AirPlay is unable to connect because your mirroring device and receiving device are not connected to the same WiFi network, or they are too far apart. Confirm that all the devices trying to connect to AirPlay are connected to the same WiFi network and keep them close.
Sometimes, outdated software versions and device systems can cause AirPlay not working issue. It is necessary to ensure that all devices involved, including iPhones, iPads, Apple TVs, and other AirPlay-compatible TVs, have the latest updates installed.
Some users may not enable Airplay from their devices. Users should check and verify that AirPlay is enabled on the devices they want to connect.
Check if there are any firewall settings or restrictions on your network that might block the AirPlay connection. Adjust the firewall settings or network restrictions to allow the AirPlay connection.
Bluetooth devices or other electronic devices in close proximity to your AirPlay setup can cause interference. Try turning off or moving away from such devices to improve the AirPlay connection.
It’s necessary to ensure compatibility with all devices involved in the AirPlay connection, such as iPhones, iPads, Apple TVs, and AirPlay-compatible TVs. You can refer to the list of compatible devices below provided by Apple.
Devices You Can Stream Video From Using AirPlay
Devices You Can Stream Audio From Using AirPlay
To check the WiFi connection and ensure that both the streaming device and the receiving device are connected to the same network, follow these steps:
On iOS Devices (iPhone/iPad):
Step 1. Go to Settings > Wi-Fi.
Step 2. Check the network name under “Choose a Network.” Ensure that both devices are connected to the same network. If not, select the correct network on both devices.
Connect both Devices to the Same Wi-Fi Network
On macOS Devices (MacBook, iMac, Mac Mini):
Step 1. Click on the Wi-Fi icon located in the menu bar at the top right corner of the screen.
Step 2. In the drop-down menu, you will see the name of the currently connected network. Make sure both devices are connected to the same network.
macOS WiFi Setting
On Apple TV:
Step 1. Navigate to the home screen of your Apple TV.
Step 2. Select “Settings.”
Step 3. Go to Network Menu. The network name of your Apple TV will be displayed. Ensure that it matches the network name of the iOS or macOS device you are streaming from.
Apple TV WiFi Setting
To fix the AirPlay unable-to-connect issue, it’s necessary to keep your software and Apple devices up to date. Regularly updating the software on your iOS devices, Mac, and Apple TV, ensures that you have access to the latest features, security patches, and bug fixes. By doing so, you can potentially resolve any software-related issues that might be responsible for any AirPlay connectivity problems you’re experiencing.
The Setting of Updates
If you’re using a firewall, you can either turn off your Firewall or make sure AirPlay is enabled to connect.
Here’s how to Disable the Firewall in MacOS Ventura
Step1. Go to the Apple menu and choose “System Settings”
Step 2. Click on “Network” in the sidebar list
Step 3. Click on “Firewall”
Step 4. Toggle the switch for the Firewall to the OFF position
Turn off the Firewall Button
Restarting your Apple devices can often resolve various issues, including AirPlay unable to connect problems. Here’s how to restart different Apple devices:
iPhone or iPad:
Step 1. Press and hold the Power button (also known as the Sleep/Wake button) until the power-off slider appears on the screen.
Step 2. Slide the power-off slider from left to right to turn off the device.
Step 3. After the device is completely turned off, press and hold the Power button again until the Apple logo appears, indicating that the device is restarting.
Step 4. Once the device has restarted, try using AirPlay again to see if the connectivity issue is resolved.
Apple TV:
If you’re looking for a simple and easy way to mirror your screen, we recommend using a third-party screen mirroring tool AnyMiro, which is the best alternative to AirPlay.
AnyMiro is a powerful screen mirroring app that supports screen mirroring iPhone/Android to Windows/Mac using a USB and wirelessly. We have put this incredible mirroring tool on our list of recommendations for the following reasons:
To mirror your iPhone on your PC using a USB connection, you can follow these steps:
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
If you prefer to mirror your iPhone to your PC using a WiFi connection, the following steps can be followed:
Step 2. Go to iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Connect to the Same WiFi
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring iPhone.
Mobile Screen Mirrored on the Computer with AnyMiro
1. How do I reset my Apple AirPlay?
To restart your AirPlay device or Apple TV, connect it to the power supply and turn it off. To restart your iPhone, hold the Side button and either the Volume or Power buttons while sliding to turn off the device. Ensure that no more than one device attempts to stream at the same time.
2. How do I get AirPlay to work?
Step 1. Connect your device to the same Wi-Fi network as your Apple TV, AirPlay-compatible smart TV, or Mac.
Step 2. Find the video that you want to stream.
Step 3. Tap AirPlay. Choose your TV or Mac from the list.
3. Can you AirPlay from Netflix?
No. It is no longer AirPlay compatible. Netflix removed the in-built AirPlay support in 2019.
AirPlay is a convenient and versatile tool that allows users to easily project videos, audio, and more from their iOS devices to compatible TVs or Apple TVs. It quickly and easily lets you mirror your devices. Throughout this article, we have explored the various issues that may prevent AirPlay from connecting or appearing on your devices. By following the solutions discussed, you can resolve the “AirPlay unable to connect” problem and enjoy seamless casting experiences. What’s more, if you’re looking for an alternative to AirPlay, we highly recommend AnyMiro. With its efficient and user-friendly features, AnyMiro provides a reliable solution for AirPlay and screen mirroring on your PC or Mac.
