How to Fix AirPlay Option Not Showing Issue
Try out the besr AirPlay alternative – AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror How to Fix AirPlay Option Not Showing Issue
It’s pretty common not to see the AirPlay option on your iPhone. No matter what the reason for it missing, in this article, we have discussed 5 ways to fix the AirPlay option not showing on iPhone issue.
Joy Taylor | Last Updated: Nov. 23, 2023
2191 words|7minute
Have you ever encountered the frustrating issue of the AirPlay option now showing on iPhone?
It’s a common problem that many iPhone users face, and it can really put a damper on the seamless and easy streaming experience that AirPlay is meant to provide!
AirPlay is a great feature that enables you to effortlessly mirror your iPhone screen to compatible devices, such as Apple TV, AirPlay-enabled speakers, or smart TVs. But when you can’t find the AirPlay option on your iPhone, it can disrupt your ability to enjoy your favorite multimedia content on a bigger screen or through external speakers.
However, in this guide, we have discussed the reasons for the AirPlay option not showing on iPhone and how to get it back.
So, let’s get started!
What Is AirPlay?
AirPlay is a built-in feature created by Apple that lets you easily stream audio and video content from one Apple device to another. It’s perfect for sharing your favorite stuff from your iPhone or iPad to your Apple TV, smart TV, or any other device compatible with AirPlay.
AirPlay Features
Some of AirPlay’s key features include:
Why the AirPlay Option Is Not Showing on iPhone?
It can be frustrating when the AirPlay option fails to appear on your iPhone. However, there are many reasons why this could happen.
Here are some common reasons why the AirPlay option is not showing on iPhone:
Regardless of why the AirPlay option is not showing up on your Apple device, or you’re unable to use it, here are 5 tried and tested solutions for it:
Method 1: Restart Your iPhone
Restarting a device can fix most of the minor glitches; therefore, before you try anything else, simply restart your iPhone.
For iPhones 8 and later:
For iPhone 7 and iPhone 7 Plus:
Long-press the volume down and power button simultaneously till you see the Apple logo.
For iPhone 6 and Earlier:
Long-press the home and power buttons (side/top) until you see the Apple logo.
Restart Different Modes of iPhone
If you start seeing the AirPlay option after restating your iPhone, well and good; otherwise, try this next quick fix…
Method 2: Check Your Wi-Fi Connection
One reason for the AirPlay option not showing on iPhone could be an unstable or disconnected internet connection. Therefore, try restarting your Wi-Fi device or connecting to any other available Wi-Fi network.
Additionally, make sure that your iPhone and the AirPlay-compatible PC or TV are also connected to the same Wi-Fi network.
Method 3: Reset Network Settings
If the Wi-Fi connection works fine, there might be an issue with the network settings at the backend. Therefore, resetting the network settings could possibly solve the issue.
Here’s what to do:
Step 1. Go to “Settings > General > Transfer or Reset Phone.”
Go to Transfer and Reset Phone
Step 2. Tap “Reset > Reset Network Settings” and enter your passcode to confirm your selection.
Step 3. This will reset your network settings, after which you can check whether the AirPlay option is appearing.
Method 4: Enable AirPlay
If resetting the network settings also goes in vain, it’s time to check whether AirPlay is enabled on your iPhone and other devices. Here’s how to enable it:
For iPhone/iPad
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Make Sure Screen Mirroring is Enabled on iPhone
For Mac
Enable the AirPlay feature on Mac
For Apple TV
Stop AirPlay Screen Mirroring on TV
Enable AirPlay on AppleTV
Method 5: Software Update
If you still see the AirPlay icon not showing on Macbook or iPhone, your devices have an outdated OS version. Therefore, make sure that you’re running the latest version of iOS, iPadOS, macOS, or tvOS on your device and the latest version of the firmware on your AirPlay receiver.
Now that you know how to fix the AirPlay option not showing on iPhone let’s see how to connect an iPhone to a PC or TV using this feature.
How to AirPlay iPhone to TV/PC
If you have fixed the AirPlay option not showing issue, you can go ahead and cast your iPhone’s screen to your PC or TV.
Screen Mirror via AirPlay on Apple TV
To AirPlay your iPhone to an Apple TV, follow these steps:
Step 1. Connect your iPhone and Apple TV to the same Wi-Fi network.
Step 2. Open the Control Center on your iPhone, and click the “Screen Mirroring” icon.
Tap the “AirPlay/Screen Mirroring” Button and Choose the Name AnyTrans_XXX
Step 3. Select your Apple TV from the list of available devices.
And that’s it!
Screen Mirror via AirPlay on Mac
To screen mirror your iPhone to Mac via AirPlay, here’s what you have to do:
Step 1. Open the Control Center on your iPhone, and tap the “Screen Mirroring” icon indicated by two rectangular boxes.
Step 2. Select your MacBook from the list of available devices.
And that’s how to AirPlay your iPhone to your Mac. However, if, for some reason, this method is not working, you can also use a third-party app as an alternative to help you cast your iPhone’s screen.
AnyMiro: Best Alternative to AirPlay
AnyMiro is a tool that lets you mirror your phone screen on your computer. It doesn’t matter if you use an iPhone or Android or if you have a PC or Mac; AnyMiro makes it easy to project your phone screen right onto your computer.
Plus, you can connect wirelessly or with a USB cable, so it’s perfect for all types of smartphones, old or new!
Why is AnyMiro the Best Alternative to AirPlay?
While AirPlay has its upsides, it also comes with several limitations. For instance, it only works with Apple devices. However, AnyMiro tops the list as the best alternative to AirPlay for multiple reasons:
With that sorted, let’s see how to screen mirror your iPhone to PC via AnyMiro.
Steps to Screen Mirror iPhone to PC Using AnyMiro
Here are the super easy steps to screen mirror your iPhone’s screen to a PC using the USB and wireless feature of AnyMiro:
Via USB Connection
Step 1. Download and launch AnyMiro on your PC, and click “iOS/iPadOS” from the interface.
Mirror iPhone to Computer
Step 2. Connect your iPhone to your PC using a USB-to-lightening cable, and select “USB” from the options on the left menu.
Mirror iOS Device to Computer via USB
Step 3. Once both devices are connected, you will receive a trust notification on your iPhone. Tap “Trust” to enable USB connectivity.
Trust Your Computer on iPhone
And that’s how you can cast your iPhone screen to a PC using a USB connection.
Via Wireless Connection
Step 1. Download and launch AnyMiro on your PC, and select “iOS/iPadOS” from the interface.
Step 2. Ensure that your iPhone and PC are connected to the same Wi-Fi network, and select “WiFi” from the menu on the left.
Step 3. Now, on your iPhone, launch the Control Center, enable “Screen Mirroring,” and select “AnyMiro” from the list of available devices.
With 3 easy steps, you have successfully screen mirrored your iPhone screen to your PC wirelessly using AnyMiro.
Frequently Asked Questions (FAQs)
1. Do all iPhones have AirPlay?
That would be a no because AirPlay is only limited to iPhone 7 or later models.
2. How do I turn on AirPlay on my iPhone 14?
To turn on AirPlay on iPhone 14, swipe from the top-right corner to open the control center and tap the “Screen Mirroring” icon with two rectangular boxes.
3. What are the requirements for AirPlay?
Here are the basic requirements for using AirPlay:
If you want to cast your iPhone screen on your PC or Mac but notice the AirPlay option not showing on iPhone, there’s no need to panic! It’s a common issue that can easily be resolved using one of the 5 methods discussed in this article.
And if you’re looking for an AirPlay alternative with better features, we recommend using AnyMiro. We hope this guide helps you with all your screen mirroring needs!
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
