Download AnyMiro to help you access Android screen from PC
Available for both Win & Mac
Bridge the gap between your smartphone and computer. Discover three easy and efficient methods to access Android from PC seamlessly.
Have you ever wanted to access Android from PC? It can be a hassle to switch between devices just to manage files or reply to messages. But don’t worry; you’re not alone! Many users like you have been searching for ways to connect their Android and PC with ease.
We’ve got your back!
In this article, we’ll introduce you to three fantastic methods that will help you access Android device from PC. It’s a game-changer! You’ll be able to transfer data, use Android apps on a bigger screen, and have complete control over your phone right from your computer.
So, if you’re excited to experience this convenient and efficient integration, stay with us. We’ll explore these simple and user-friendly techniques that will undoubtedly make your life easier!
There are several great advantages of accessing your Android device from your PC. It can really boost your productivity and overall digital experience.
Here are some of the key benefits:
So, now that you know how beneficial it is to access Android from PC, let’s get straight to how to do it!
Mirroring your Android screen to PC is not difficult; however, if you’re looking for a stable and smooth mirroring experience, we recommend using iMobie AnyMiro for it.
AnyMiro is a screen-mirroring app that enables you to access phone from computer with high-quality visuals.
Here are some of its features to help you better understand how it works:
Steps for Mirroring Android to PC using AnyMiro
Here are the detailed steps to mirror your Android device to your PC with AnyMiro:
Via USB Connection
Step 1. Download and install AnyMiro on your PC, and select “Android” from the interface.
Select Android to Access Phone from Computer
Step 2. Now connect your Android device to your PC using a USB cable, and click on “USB” from the menu on the left.
Select USB to Access Android from PC
Step 3. You will get a notification on your device asking to “Allow USB Debugging?” Tap “Allow” to continue.
Enable USB Debugging and MTP Mode for a USB Connection
And that’s it! In 3 simple steps, you can easily access Android from PC with a USB using AnyMiro!
Via WiFi Connection
To access Android from PC wirelessly using AnyMiro, here’s what to do:
Step 1. Download AnyMiro on your PC and select “Android” from the interface.
Mirror Android to Computer
Step 2. Make sure your Android phone and PC are connected to the same WiFi network, and click on “WiFi” from the menu on the left.
Connect Both Devices to the Same Wi-Fi Network
Step 3. Scan the QR code displayed on your PC screen with your phone to get the AnyMiro mobile app.
Download AnyMiro App on Your Phone
Step 4. Launch the mobile app and select “WiFi Connection” from the options.
Select the Connection Method
Step 5. Tap your PC’s name from the list of connectable devices to pair both devices and initiate screen mirroring.
Select Your PC to Access Android from PC
And that’s how you can easily access your Android device from your PC for ultimate ease and convenience.
Mirroring your Android device to a PC is one thing, but being able to control it from your PC is different, and not many apps offer this feature.
So, if you are looking for a third-party screen mirroring app that not only casts your phone’s screen on PC but also lets you remote control it using a mouse and keyboard, we suggest giving AirDroid Cast a try.
In short, AirDroid Cast is a good option for presentations, gaming, or just to show someone else what’s on your device.
Steps to Use AirDroid Cast to Access Android from Windows 10
Here are the steps to use access Android from PC using AirDroid Cast:
Step 1. Download and install AirDroid on your PC and Android Device.
Step 2. Launch AirDroid Cast on your PC and choose the “Wireless” option from the interface. At the same time, make sure that your Android phone and PC are connected to the same Wi-Fi network.
Step 3. Launch the AirDroid app on your Android and scan the QR code from your PC.
Scan QR Code to Access Android from PC
Step 4. You will get a notification on your PC requesting to cast the Android screen. Accept it.
Accept Casting Request to Access Phone From Computer
Step 5. At the same time, enable casting permission on your Android device.
Enable Casting to Access Android on PC
Once both the devices are paired and the permissions granted, you’ll be able to access Android on Windows 10 and even remote control it with your mouse and keyboard.
If you don’t want to get into the hassle of downloading apps, we suggest going for a web-based screen-mirroring tool like Vysor. This incredible app effortlessly projects your Android device screen onto your PC, providing seamless integration between both devices.
With Vysor, you gain full control over your smartphone or tablet right from your desktop, and it even allows you to play games with ease.
One of Vysor’s standout features is its compatibility as both a desktop and web app, making it accessible across all operating systems. Whether you’re using Windows, macOS, or Linux, Vysor ensures a smooth and consistent experience.
Steps to Access Android from PC using Vysor
Here’s how to set up and use Vysor to access Android from Windows 10:
Step 1. Download the Vysor Chrome Extension and install it on your browser.
Step 2. Now connect your Android device to your PC using a USB cable.
Step 3. Launch Vysor. It will automatically detect your connected Android device.
Connect Both Devices to Access Android from PC
Once both devices are connected, your Android screen will start streaming on your PC.
These were the 3 easy methods to access Android from PC using a USB connection or Wi-Fi connection via third-party screen-mirroring tools.
And there you have it; three ways to access Android from PC!
However, the best method for you will depend on your specific needs and preferences. If you need to mirror your screen, you can go for iMobie AnyMiro. Not only does it provide a stable mirroring experience, but with its USB connection, you can mirror for 10 hours straight!
But, if you’re looking for screen-mirroring tools that let you remote control your Android from the comfort of your PC, AirDroid Cast and Vysor are also good options.
So, no matter which method you choose, accessing Android from PC can be a great way to get more out of your phone!
