5 Ways to Transfer Notes from Samsung to iPhone 16
If you’re switching from Samsung to an iPhone, you may need to transfer notes from Samsung to iPhone. If you don’t know how to do it, this article will show you step by step.
Author Avatar Joy Taylor Last Updated: Oct. 21, 2024
Free download AnyTrans to transfer notes from iPhone to your iPhone 16/15/14 in just seconds. Moreover, AnyTrans supports transferring all data from Android to iPhone quickly and easily. Support the latest iOS 18 and iPhone 16.
The process of transferring Samsung videos, photos, documents, or any other content is pretty simple and doesn’t take a lot of time. When it comes to notes, your options are not so great. Samsung Notes isn’t a cross-platform app, so you can’t transfer the entire content in one click to the iPhone.
Considering this situation, you may wonder how to transfer Samsung notes to iPhone. No worries, we will help you to understand everything about the necessary steps for successfully transferring content from Samsung Notes to iPhone.
Transfer Notes From Samsung to iPhone in Seconds – AnyTrans
If you want to transfer other data from a Samsung device to an iPhone, you can download specialized software to do so. We recommend you try AnyTrans. With this iPhone manager, you can transfer all the data on your Samsung phone to your iPhone, including transferring photos, WhatsApp chats, call logs, music, ringtones, files, etc. and AnyTrans is not going to erase the data on your iPhone and it will transfer notes from Samsung to iPhone in seconds.
In addition to the above data, you can transfer WhatsApp data from Android to iPhone quickly and securely as well. Now, let’s have a look at the tutorial on transferring data from a Samsung phone to an iPhone.
Step 1. Download and launch AnyTrans on your PC/Laptop. Select the Phone Switcher option > Tap on the Phone to iPhone button > Click Migrate Now.
Go to Phone Switcher and Choose Migrate Now
Step 2. Connect your new iPhone and Android mobile to your computer via cables. Confirm your Android phone as a source device and iPhone as a target device, then tap on the Next.
Connect Android and New iPhone
Step 3. Now, select the file categories that you wish to transfer. Here we Select All, and you can skip duplicates on your Android. Once done, click on the Next button.
Select All Data on Android to Transfer
Transfer Notes from Samsung to iPhone with Google Sync
iPhone has a default Apple Notes application, which means transferring the Notes app from Android, including Samsung, isn’t possible. But with Google Sync you can bridge the gap. Google account and its sync feature can be used to store notes from a Samsung, and later you can access them from any iPhone. Google sync allows you to automatically store important content from your Android in the Google account.
Step 1. Open Settings on your Samsung phone and find Accounts. In this section, you will see the Google tab.
Step 2. After you open Google, enable the Sync Now option to enable your calendar, contact, and notes to be stored in the cloud. Or you can choose partial syncing and just turn on Keep Notes.
Step 3. Open the Settings menu on the iPhone. Select Mail, contact & calendar and click on Add accounts.
Step 4. Enter valid Google account details and log in.
Step 5. Click on the Next button and enable the notes option. In a few minutes, all notes will be transferred from the cloud to your iPhone.
Transfer Notes with Google Keep
Transfer Notes with Google Sync
Transfer Samsung Notes to iPhone with Google Keep
Since Samsung and iPhone are different phone systems, it is not feasible to try to transfer notes between Samsung and iPhone directly. In this case, the help of third-party software is needed. Here, we introduce a free and easy-to-use software – Google Keep.
You only need a few simple steps:
Step 1. Please install Google Keep both on your Samsung and iPhone. And then, please sign in with the same Google account on both phones.
Step 2. You need to enable the sync feature to Keep Notes. On your Samsung phone, go to Settings > Accounts and backup > Accounts. Tap on your Google account and make sure the Keep notes option is on.
Step 3. After that, please open the Samsung Note app, open each of the notes you want to transfer to your iPhone, and click the Share icon.
Step 4. Select Keep notes from the list of applications. Click the Save button.
Step 5. Now open Google keep on iPhone, and select the Apple Notes application from the sharing table. After completing the above operation, your notes will be successfully transferred from Samsung to iPhone.
You may also like: How to get messages record on phone
Use Email to Transfer Notes from Samsung to iPhone
In this way, you can transfer all notes from Samsung to iPhone, but it takes quite a long time and requires a lot of patience. However, e-mail can be a useful option for transferring if a particular Note can’t be synced otherwise. Here is how to transfer it manually by using the Sharing via Mail option in Note Settings:
Step 1. Open Notes on your Samsung phone and choose which note you want to transfer to iPhone.
Step 2. Find the Share icon and then select As email in the popup window.
Step 3. In the next field, enter your email account.
Step 4. Click on the Send button.
Step 5. From the iPhone, visit your email and download the note.
Transfer Samsung Notes to iPhone with Email
Transfer Samsung Notes to iPhone with Dropbox
Dropbox is a commonly used cloud storage service for Android and iOS devices. In practice, that means you can access it from both devices – Samsung and iPhone. Just provide a stable internet connection and the job will be finished quickly.
Step 1. Open the Notes app on your Samsung phone.
Step 2. Select the notes you want to transfer to iPhone and click on the three vertical dots in the corner. Now you will see the Share icon.
Step 3. Choose Send or Share option and then click on the Dropbox icon from the popup window.
Step 4. Open Dropbox on your iPhone, and access the storage. Your note will be saved in a folder.
Transfer Notes with Dropbox
All of the listed ways are perfectly capable to transfer notes from Samsung to iPhone, without concerns about content size or possible file damage. But if you want to transfer more data from Samsung, such as contacts, messages, WhatsApp, etc., AnyTrans is suitable for any smartphone user, regardless of experience and level of technical skill. Just download AnyTrans and have a try!
