How do I transfer data from my old iPhone to my new iPhone without iCloud or computer? Are you finding the methods to transfer messages from iPhone to new iPhone without iCloud? Don’t worry, you can find the answer in this article.
If you buy a new iPhone, how do you transfer data from Android to iPhone, especially after setup? Don’t worry. Free download AnyTrans to transfer messages from iPhone to iPhone without iCloud. Never reset your device. Existing data on your iPhone will not be erased. Supports all iPhone models, including iPhone 16.
Getting a new iPhone to replace the old one is exciting, but transferring data, such as text messages, from one old iPhone to a new iPhone 16 is a thorny task. As we all know, you can not only transfer one type of data such as messages to a new iPhone with iCloud or iTunes. What’s more, using iCloud and iTunes to transfer data will erase the data on your new iPhone.
So, you may ask: Can I transfer messages from iPhone to iPhone without iCloud? The answer is YES. This article shows 3 effective methods to transfer messages (including iMessage) from iPhone to iPhone without iCloud.
You may also like: How to transfer contacts from iPhone to iPhone
How do I transfer messages to new iPhone without backup? As a professional phone-to-phone transfer utility, you can use AnyTrans – iPhone Data Manager to complete the messages move from iPhone to iPhone, especially when you find there is no storage space in iCloud for you to backup and restore the messages and you do not want to pay for more of it. With this approach, you can accomplish more by spending less time.
AnyTrans allows you to only get messages from the old iPhone to the new iPhone with just a few clicks. It’s compatible with all iPhone models including iPhone 16 and iOS 18. It can perfectly handle all your needs while using an iPhone, including transferring data from Android to iPhone, iPhone to iPhone, iOS to computer, managing iTunes/iCloud data, and more. Check some of its main features on iPhone Messages management:
You can try AnyTrans to transfer Text Messages from iPhone to iPhone if you seek to switch iPhone to iPhone and get your data transferred ever after setup.
Now, please follow the steps below to learn how to transfer messages to new iPhone without iCloud / backup:
Step 1. Free download AnyTrans and launch it on your computer > Connect your two iPhones to the computer and tap Phone Switcher at the left control panel > Choose Phone to iPhone.
Choose Phone to iPhone to Migrate
Step 2. Make sure the transfer is correct by checking the target device (the right one). And then click “Next”.
Transfer Data from One iPhone to Another with AnyTrans
Step 3. Choose Message and click “Next” to transfer all messages to your new iPhone.
Select Messages to Transfer
Since there is no storage limit, iTunes is a good iCloud alternative for iPhone users to export their important data such as messages to a new iPhone. The main disadvantage of iTunes is that you have to restore all data in your old iPhone to the new one when you want to restore text messages. At the same time, the existing data on your new iPhone will be erased. If you think that’s OK, you can do it through the following steps:
Backup your device with iTunes
Backup iPhone to iTunes
You May Like: How to Transfer Photos from iPhone to PC without iTunes >
Restore the backup to new iPhone
Restore Backup via iTunes
Also Read: How to Transfer Messages from Android to New iPhone >
If both your old iPhone and new iPhone are using iOS 12.4 or later, you can use the Quick Start function to transfer all your data and settings wirelessly from your old device to your new one. Please keep your two devices close and follow the steps below to start the transfer process:
Move Messages from iPhone to iPhone via Quick Start
Both devices will be occupied during the Quick Start process, so you can not use your iPhone for a period of time. And it will migrate all the data to your new device.
Usually, the network problem will cause the transfer messages from iPhone to iPhone to fail. You need to make sure both of your two devices are connected to a stable network during the transfer process.
That’s all about how to transfer text messages to new iPhone without iCloud. As you can see, AnyTrans is the easiest way for you to transfer messages from one iPhone to another. Without further ado, let’s download AnyTrans to have a try! If you think this guide is helpful, please share it with your family and friends.
