When you switch to a new iPhone 16 from the old Android phone, the most troublesome thing is to transfer data, especially messages from Android to iPhone. Don’t worry, you can find the solutions in this guide.
Can I transfer my text messages from Android to iPhone? Yes, free download AnyTrans to transfer all messages from your Android phone to your new iPhone 16 with a few clicks.
We all know that exporting data from an Android to a iPhone is a headache, because two phones with different operating systems just like transferring messages from Android to iOS devices. Especially when your smartphone stores a lot of important data, such as messages, which are equivalent to a miniature mobile computer.
Don’t worry, this article explains how to transfer messages from Android phones to the new iPhone in 7 ways, including the latest iPhone 16.
The first way to transfer text messages from Android to iPhone is using the Apple official app “Move to iOS“. With this app, you can transfer important data such as email accounts, web bookmarks, messages, and media files, contacts from Android to iPhone. But there are some prerequisites that you have to fulfill before you can transfer SMS from Android to iPhone.
To use this app for free, your Android phone needs to run Android 4.0 or later. A steady Wi-Fi network is also needed. Do note that you can only use the app to handle the text transferring when you are setting up your iPhone. If you’ve already used your iPhone, you’ll need to erase it and set it up again. You may follow the instructions below.
Transfer Data with Move to iOS
If text messages didn’t transfer from Android to iPhone with Move to iOS, or you want to move messages to an already set up iPhone, AnyTrans can meet your demands. It supports cross-platform data migration. Only simple clicks are needed for it to transfer Android messages to your iPhone. No data will be erased.
Besides, AnyTrans is an all-in-one manager for your iPhone, iPad, iPod, iTunes, and iCloud content. With this app, you can transfer, manage, and back up iOS data with ease.
Steps to move text messages from Android to iPhone with AnyTrans:
Step 1. Download AnyTrans on your PC/Mac, and launch it to connect both your Android phone and iPhone.
Step 2. When your devices are detected, choose “Phone Switcher”, tap on the “Phone to iPhone” button, and click “Migrate Now” to start transferring.
Transfer Messages from Android to iPhone via AnyTrans
Step 3. Choose the source phone(Android) and target phone(iPhone), click the “Next” button to continue.
Confirm Source and Target Devices
Step 4. Choose “Messages”, and click the “Next” button to start the transferring process. If you want to transfer other data, just choose that category and click “Next”.
Select Messages to Transfer
Next, you will check some methods to transfer text messages from Android to iPhone without computer:
Does SMS backup and restore work from Android to iPhone? Actually it’s possible. Although iPhone and Android phones are based on different systems, you can not transfer data between them directly. Instead, you may employ the SMS Backup & Restore app to sync messages to your Gmail account over the web, then access the saved messages file on your iPhone.
After syncing, you can view Android messages by signing in to the same account or by using some program that can read them. Download SMS Backup & Restore on your Android phone from Google Play, and follow the guide below to add Android text messages from Gmail to iPhone.
Transfer Messages with SMS Backup and Restore
Now, you can set up a Gmail account on your iPhone and access the messages transferred from Android.
Further Reading: Transfer Messages from iPhone to iPhone without iCloud >
Email your messages from an Android phone to an iPhone is an easy way for those people who have only several messages to transfer. However, it is a time-consuming task if there are lots of messages that need to be transferred. What you should know is that you can only move or send one message at a time. Just follow the detailed steps below to transfer messages from Android to iPhone via Email:
Long Press and Choose Share
Email Android Message to iPhone
There is another app that can move messages from Android to iPhone, it is called Send Anywhere. This app is available on both Android and iOS devices. Since the app supports a cross-platform transfer of data, you can easily download it respectively from Google Play Store and App Store to your Android phone and iPhone.
Migrate Messages with Send Anywhere
After that, just connect both the devices with the same WiFi. And it can transfer text messages from Android to iPhone and can also move your photos, videos, and contacts as well. Follow the tutorial below and start exporting Android messages to iPhone.
As its name indicated, PhoneTrans is a phone data transferer, which can switch across iPhone, iPad, and 20,000+ Android devices freely. It bridges the gap between iOS and Android systems and makes it one-click easy to transfer messages freely from Android phones to iPhone.
Features of PhoneTrans:
Steps to move text messages from Android to iPhone with PhoneTrans:
Step 1. Download PhoneTrans and launch it on your computer. Connect your Android and iPhone to the computer.
Step 2. You need to first backup your Android messages with PhoneTrans, and then restore the message to your iPhone (No data erase). Choose “Phone Backup” >”Selectively Backup” > Click “Back Up” > Choose “Messages” > Click “Back Up Now”.
Backup Android Messages
Step 3. Go to “Phone Restore”, click “PhoneTrans Backup”, and select the backup you just made with PhoneTrans.
PhoneTrans – Extract Android Backups
Step 4. Choose “Messages” > “Confirm your iPhone” > Click “Restore Now”. Wait for messages to transfer to your iPhone.
Choose Messages to Restore
If you backed up Android messages on Google Drive and need to restore them to your iPhone, you need to first restore messages from Google Drive to Android, then transfer from Android to iPhone with the above methods. Because Google Backup is running for Android phones.
All the methods above can help you transfer messages from Android to iPhone with a few clicks. However, some of them have limits. For example, Move to iOS can transfer messages from Android to iPhone only when you first set up this iPhone. Among the other four applications, AnyTrans and PhoneTrans are more comprehensive. Download AnyTrans you can transfer data to iPhone now and start moving messages to your new iPhone!
