3 Ways to Fix Transferring Data to New iPhone Stuck
If your iPhone is stuck when transferring data to new iphone, you can read this article to find feasible solutions.
Author Avatar Joy Taylor Last Updated: Aug. 12, 2024
Getting a new iPhone is an exciting moment, and most people can’t wait to start using it. Before you can go play with your new gadget, you first need to get all of your personal data on a new phone. There is a known issue where the process becomes stuck with approximately one minute to go. Knowing a few practical tricks that have a chance of resolving the issue is a valuable skill for every iPhone owner.
How to Fix the Problem with Data Transfer Getting Stuck
From the user side, all instances of data transfers getting stuck may look similar, but the underlying reasons for the failure could be different in each case. Since it can be difficult to deduct what caused the problem in the first place, it makes sense to try out a few possible solutions to see whether the problem goes away. If it doesn’t, you should try another tip from this list.
Transfer iPhone Data
1. Ensure that Your Wi-Fi is Working Properly
Since data transferring during the iPhone setup process is routed through the cloud, the availability and speed of your internet connection are crucial. In some cases, you could think that the process is stuck even if it’s actually progressing very slowly due to poor Wi-Fi or a 4G signal at your location.
You should be patient and give it a few more minutes to go through, but if it doesn’t complete in a reasonable timeframe you might have to reconnect to a more stable network and repeat the setup once more.
2. Try Transferring Data with iCloud
If the primary phone migration feature is not producing the expected result and you are repeatedly getting stuck on this step, it might be a better idea to bypass it altogether and import your backup from another place. If you uploaded your old iPhone’s content to iCloud, it will be very easy to send everything to your new smartphone. Follow the simple steps below, and you can transfer your data successfully with iCloud.
Step 1. On your iPhone, tap on Settings apps > Click your Apple ID’s profile > Select iCloud.
Step 2. Select the categories you want to transfer like, Photos, Contacts, Calendars, Reminders, Notes, etc., and then tap on them to turn them on one by one.
Transfer Data from iPhone to iPhone with iCloud Syncing
3. Transfer iPhone Data with AnyTrans
Sometimes the native methods for data transfers are not sufficient, so downloading an app designed specifically to manage iPhone data could be a better solution. There are numerous apps that could be used for this purpose, with AnyTrans by iMobie as one of the best and most versatile packages in the market.
with AnyTrans, you can transfer contacts, photos, messages, videos, music, ringtones, and other iPhone data from your old iPhone to your new iPhone. And it lets you selectively transfer data to your new iPhone. Now, just follow the steps below to transfer iPhone data.
Step 1. Install and launch AnyTrans > Connect your iPhones to the computer via USB cables > Choose “Phone Switcher” > Click on “Phone to iPhone” mode.
Choose Phone to iPhone to Migrate
Step 2. Select the source device and target device > Click the “Next” button to continue.
Choose the Source and Target Phones and Click Next
Step 3. Select the file categories you want to transfer, here we take Contacts as an example (Or you can Select All to move) > Click the “Next” button to start transferring data from the old iPhone to the new iPhone.
Check Contacts Box to Transfer
Even if you experience some problems while setting up a new iOS device, there is no reason to fear for the safety of your data. Equipped with knowledge on how to fix transferring data to a new iPhone stuck, you will be able to find a solution that allows you to start using the smartphone with all your personal data already loaded. Stay calm, try the recommended AnyTrans from this article, and your ordeal will soon be over.
