7 Ways to Transfer Data from OPPO to Samsung
Gone are the days when switching from one mobile brand to another is a problem, as you cannot transfer data. Now you can easily change your Android mobile phone and be sure your data is moving to the new device with you. Here, we explore the top 7 ways to transfer data from OPPO to Samsung without hassles.
Author Avatar Joy Taylor Last Updated: Aug. 12, 2024
Hi there, I’m considering switching my OPPO phone to Samsung S21+. However, I’m scared of losing my data files. Is there any way I can take my data along with me to my new device? Please, kindly help with how to transfer data from OPPO to Samsung.
Undoubtedly, there’s so much joy switching from one mobile brand to another. But it becomes disheartening when you think about your data. Many folks find it difficult to move or migrate data between mobile devices, especially OPPO to Samsung, just like the scenario above.
However, that’s now history, as you can now take your OPPO data along with you to your Samsung device without stress. We’ve compiled the 7 effective ways to transfer data from OPPO to Samsung right from the comfort of your home. Read on as we demonstrate each of the techniques in the next sections of this post.
How to Transfer Data from OPPO to Samsung with Simple Clicks
The simplest way to transfer data from OPPO to Samsung is via the professional Android transfer tool- DroidKit. This software ensures the safe migration of over 15+ types of Android data from your OPPO phone to any Samsung model with high-end quality.
DroidKit boasts outstanding performance, as it migrates photos, videos, documents, and several gigabytes of data simultaneously from one Android brand to another. This software is simple and easy to install on any computer system, whether Mac or Windows.
Key Features
  • 1-Click to transfer data from OPPO to Samsung and other Android brands.
  • Transfer gigabytes of photos, videos, documents, and more simultaneously without quality loss.
  • No technical skill is required to operate the DroidKit Android transfer tool.
  • Advanced functions: data recovery, Android screen unlock, system fix, FRP bypass, and several others- all in a centralized platform.
Stepwise Guide to Transfer Data from OPPO to Samsung with DroidKit
Step 1. Download and launch DroidKit on your computer. On the main screen, choose Android Mover in Data Manager Mode.
Choose Android Mover
Step 2. You need to choose the Android to Android mode on the next screen.
Choose Android to Android
Step 3. Then you should connect your devices to the computer. Once done, click on the Migrate Now button.
Click on Migrate Now
Step 4. You can select the data types and then click Next to transfer.
Select Data You Want to Transfer
Step 5. All you need to do is waiting for a while. Once DroidKit completes the data transfer, you can unplug the Android devices and find out the old Android device’s data which are already on the new Android device.
Data Transferred Successfully
Copy Data from OPPO to Samsung via Samsung Smart Switch
Wondering if Samsung Switch works with OPPO? Definitely!
With the Samsung Smart Switch, you can also perform data transfer operations from OPPO to any Samsung device conveniently. This Samsung data transfer app copies and pastes over 5+ Android data from one phone to another with high speed.
You can bank on this app to move data like photos, documents, music, etc., from your OPPO to your Samsung phone. It doesn’t matter whether you are transferring data from an older Android version to a newer one, the Samsung Smart Switch will connect and move data from OPPO to Samsung smoothly.
Transfer your data from OPPO to Samsung with Samsung Smart Switch using the steps below:
  • Firstly, on your OPPO and Samsung devices, download and install the Samsung Smart Switch app via the Google Play Store.
  • Launch the app on your OPPO. For  Samsung, just go to Settings > Cloud and Account, then select Smart Switch.
  • Connect your OPPO to your Samsung phone. There are two connection modes for Smart Switch. If you choose WiFi, kindly ensure both devices are in proximity. However, if its USB connection, make sure you have a USB type C cord.
  • On your OPPO phone, choose the data to transfer, and hit Transfer to proceed. Data transfer will commence right away.
Transfer Data with Smart Switch
Limitations
  • Not a suitable option for transferring gigabytes of data.
  • The transfer speed is very slow compared to DroidKit.
How to Move Data from OPPO to Samsung via Bluetooth
Bluetooth is one of the premier tools available for migrating content from one mobile device to another. Whether you want to transfer photos, videos, or files, it’s a fantastic option to use.
With this in mind, you can also try Bluetooth out for data transfer from OPPO to Samsung phones. You can use this option to transfer several kilobytes of data with minimal stress. No data or wired connection needed for you to use this approach. Connectivity is easy and quick, so far you have both devices in the same proximity.
Move data from your OPPO device to Samsung with the instructional guide below:
  • Swipe down your OPPO phone to access the Notification panel.
  • Tap on the Bluetooth icon to activate it on your OPPO phone.
  • Next, head to the Settings menu on your Samsung phone, and select Bluetooth
  • Kindly enable Bluetooth, then proceed to pair your Samsung phone with your OPPO smart device.
  • Choose the data you want to move on your OPPO, and click on the More (usually signified as three vertical dotted lines) button at the top-right corner of your screen.
  • Select Import/Export and choose Bluetooth as your preferred transfer option.
  • Tap on your Samsung phone name, and wait patiently for the transfer to finish.
Transfer Data from OPPO to Samsung via Bluetooth
Limitations
  • You cannot transfer contacts via Bluetooth.
  • Moving megabytes or gigabytes of data via this data transfer option is impossible.
How to Transfer Contacts from OPPO to Samsung via Gmail Account
Gmail, also known as Google Account is a mailing service established for communication purposes. Whether you need to connect formally or informally, this app comes in handy. It lets you share information and exchange data without difficulty.
This mailing service is also useful for data transfer, especially when you need to move contacts from OPPO to Samsung. Gmail transfers several contacts simultaneously. You can apply the procedures below to transfer contacts from OPPO to Samsung via your Gmail Account:
  • Launch the Contacts app on your OPPO smartphone.
  • Next, click Contacts at the bottom of the screen, and select More at the upper right corner of the interface shown.
  • Tap on Import/Export, then hit the Share Contacts button, so your OPPO device understands that you want to transfer contacts.
  • Mark the contacts you want to transfer, click Share and select Gmail from the transfer options displayed.
  • Enter the recipient mail address in the To field and hit the Send button.
  • Now, log into the recipient account on your Samsung phone, go to Inbox and download the contacts.
Send Data from OPPO to Samsung via Gmail
Limitations
  • Requires data network for you to successfully move contacts from OPPO to Samsung.
  • There’s a limit to the size of data you can transfer via this option.
Send Data from OPPO to Samsung via Email
Email addresses are also great for moving data from OPPO to Samsung. Regardless of the mailing service you are using, you can migrate content like videos, photos, links, and others between both devices easily and quickly. All you need is a good data connection, the recipient and sender’s mail address and you are good to proceed.
Transfer your favorite data from OPPO to Samsung via Email by following the steps down here:
  • Open a mailing service on your OPPO phone, and sign in to your account.
  • Click on the Send icon to launch a messaging tab.
  • Next, click on the Attachment icon, and choose the data you would like to transfer from your OPPO device.
  • Enter the mailing address of the recipient in the right field, and click on the  Send icon to transfer the data.
  • Now launch the mailing app on your Samsung phone, and sign in to your profile. After that, click on the Inbox icon, then download the shared data.
Transfer Data with Email
Limitations
  • Without a data connection, you cannot move content with Email.
  • You must have the matching email address and password to use this approach.
Transfer Data from OPPO to Samsung by USB
With USB, you can transfer data from OPPO to Samsung. This is a free yet simple approach to migrate content. However, there are certain prerequisites you must put in place, some of which include:
  • Connect the OPPO phone to your computer using the right USB, then launch the ‘This PC’ panel.
  • Select your OPPO device on the left sidebar to launch the internal storage.
  • Grab your Samsung phone and connect to the same computer with the authentic US, and launch the “This PC’ panel again. Select the Samsung phone on the left sidebar to access the internal storage.
  • Now drag-and-drop the data in your OPPO to Samsung phone using your cursor.
Limitations
  • Lengthy stepwise guide.
  • Can only transfer a limited number of data from OPPO to Samsung.
  • If not done carefully, you can interchange the source device for target device.
How to Send Data from OPPO to Samsung via Send Anywhere
Lastly, we suggest the Send Anywhere app to transfer data from OPPO to Samsung. This app transfers multitudes of data across both devices in high quality. As the name implies, the app isn’t limited to OPPO and Samsung transfer. You can also use it for other mobile brands, including iOS.
You can follow the steps below to transfer data from OPPO to Samsung via Send Anywhere by following the steps below:
  • Launch Google Play Store on your OPPO and Samsung phones. Enter Send Anywhere in the search tab and click the appropriate buttons to download the app.
  • Install and run the app on your OPPO phone, then select Send and choose the data you will like to transfer.
  • Next, a 6-digit code will be displayed on your OPPO phone screen. Copy somewhere, as you will need it to establish a connection with your Samsung phone.
  • Now grab the Samsung device, and launch Send Anywhere on it. Tap on Receive to proceed.
  • Now enter the 6-digit code that was displayed on your OPPO device on the Samsung phone to commence data transfer between both phones.
Migrate Messages with Send Anywhere
Limitations
  • Not all types of data can be moved with the Send Anywhere app.
  • The transfer speed is pretty slow.
Final Words
This article has provided the top 7 ways to transfer data from OPPO to Samsung devices. Choose any one of the methods, and follow the stepwise guide underneath to transfer your OPPO data today. DroidKit is the best option from the list, and we strongly recommend it for the smooth and quick transfer of OPPO data to Samsung. The software moves data between both Android brands without limitations.
